A friend has some Apollo unit that is capable of enroute and terminal
navigation. How do I know if the installation is actually approved for IFR flight ? Thanks |
navigation. How do I know if the installation is actually approved for IFR flight ? AFM Supplement ? |
"Doug" wrote: A friend has some Apollo unit that is capable of enroute and terminal navigation. How do I know if the installation is actually approved for IFR flight ? AFM Supplement ? Also, if it's not, it will have a placard saying "VFR use only" or something to that effect. |
![]() Roy Smith wrote: In article , "Doug" wrote: A friend has some Apollo unit that is capable of enroute and terminal navigation. How do I know if the installation is actually approved for IFR flight ? AFM Supplement ? Also, if it's not, it will have a placard saying "VFR use only" or something to that effect. I would qualify that by saying it is *supposed* to have such a placard.~ |
AFM Supplement ?
Not to be found. |
something to that effect. True, with Tim's caveat noted. ;-) |
If your unit is IFR approved, then it will be listed on the type certificate
(if it came that way from the factory), or if the unit was installed in the field there will be a 337 with a FSDO's signature approving the unit for IFR use. You can get a CD from the FAA that lists all the 337s for that airplane on it. Jim Howard "Scott Draper" wrote in message ... AFM Supplement ? Not to be found. |
Not legal to fly then. If there is a 337, you can get a new AFM supplement
issued. "Scott Draper" wrote in message ... AFM Supplement ? Not to be found. |
![]() Paul Lynch wrote: Not legal to fly then. If there is a 337, you can get a new AFM supplement issued. There is a 337, has to be to get installed, assuming of course it was installed legally. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
