I acquired a Nonin O2 monitor a while back and Saturday took it out for
a test ride. I'm 68, mild heart disease, annual special issue medical, exercise regularly. With regular deep breathing, I was able to retain 90% or more O2 level as indicated by the monitor up to 13,500, and felt fine. Given that one of the early symptoms of hypoxia is euphoria, however, I'd appreciate if any of you who have tested this stuff would share what you know about where hypoxia begins for most people? |
In persons without chronic respiratory disease, in healthcare settings
we aim to keep oxygen saturations above 90-90%. The oxygen content of the blood drops sharply below sat's of about 90%, so the difference between 90% and 88% is greater than 92% and 90%. You would be best off to use oxygen for flights in that area. Dave Paul kgyy wrote: I acquired a Nonin O2 monitor a while back and Saturday took it out for a test ride. I'm 68, mild heart disease, annual special issue medical, exercise regularly. With regular deep breathing, I was able to retain 90% or more O2 level as indicated by the monitor up to 13,500, and felt fine. Given that one of the early symptoms of hypoxia is euphoria, however, I'd appreciate if any of you who have tested this stuff would share what you know about where hypoxia begins for most people? |
Thanks, Dave. I just read the directions that came with the monitor
(always read the directions LAST :-() and that says to use 90% of your "customary" level. e.g. people who live at 5000 feet don't normally show 100% but have developed tolerance so 85-86% is probably OK if your normal level is 95%. |
Paul kgyy wrote:
Thanks, Dave. I just read the directions that came with the monitor (always read the directions LAST :-() and that says to use 90% of your "customary" level. e.g. people who live at 5000 feet don't normally show 100% but have developed tolerance so 85-86% is probably OK if your normal level is 95%. That's probably not a very good plan. Most people don't show 100% at sea level, and if your usual resting O2 saturation is 95% at sea level, you still don't want to drop below 90% in the air for the reason that Dave S. mentioned -- the oxygen content of the blood drops off rapidly below a saturation of 90%. -- David Rind |
![]() "Paul kgyy" wrote in message oups.com... Thanks, Dave. I just read the directions that came with the monitor (always read the directions LAST :-() and that says to use 90% of your "customary" level. e.g. people who live at 5000 feet don't normally show 100% but have developed tolerance so 85-86% is probably OK if your normal level is 95%. When mountaineering we normally see resting numbers in the high 80s when first arriving at a new altitude, this usually goes to the low 90s within two days. Most people are not feeling very well in the low 80s. I have never used an oximeter in an airplane but I imagine that it would be about the same.. Mike MU-2 |
David Rind wrote:
That's probably not a very good plan. Most people don't show 100% at sea level, and if your usual resting O2 saturation is 95% at sea level, you still don't want to drop below 90% in the air for the reason that Dave S. mentioned -- the oxygen content of the blood drops off rapidly below a saturation of 90%. We will routinely put anybody with an SaO2 of less than 90% on oxygen in the hospital where I work. I generally run around 95% myself on room air. -- Mortimer Schnerd, RN VE |
Mortimer Schnerd, RN wrote:
We will routinely put anybody with an SaO2 of less than 90% on oxygen in the hospital where I work. I generally run around 95% myself on room air. What you do in the hospital is one thing, what you need to be able to safely fly is an entirely different thing. In our glider club, we have equipped all gliders with an EDS pulse demand oxygen system. We think we have been flying noticeably better since we've routinely used it as low as 7000ft and certainily are less tired in the evening. Stefan |
Stefan wrote:
What you do in the hospital is one thing, what you need to be able to safely fly is an entirely different thing. In our glider club, we have equipped all gliders with an EDS pulse demand oxygen system. We think we have been flying noticeably better since we've routinely used it as low as 7000ft and certainily are less tired in the evening. I only mention it (90%) as a reference to what physicians consider minimally acceptable for folks basically at sea level (~700' msl). I recognize that our needs as pilots are different in that we generally do nothing more physical than sit on our butts and push buttons. We do need a clear head though.... Above 10,000 feet I get a momentary twinge of lightheadedness if I cough. I can't really define any other obvious change though. I've never explored higher than 12,000 feet without pressurization so I can't say how rapidly I'd fall apart as I go higher. -- Mortimer Schnerd, RN VE |
Stefan wrote: Mortimer Schnerd, RN wrote: We will routinely put anybody with an SaO2 of less than 90% on oxygen in the hospital where I work. I generally run around 95% myself on room air. What you do in the hospital is one thing, what you need to be able to safely fly is an entirely different thing. In our glider club, we have equipped all gliders with an EDS pulse demand oxygen system. We think we have been flying noticeably better since we've routinely used it as low as 7000ft and certainily are less tired in the evening. What do you do in the evenings that you would not be too tired to do? ;-))) |
slow roll in a super decathlon | Nobody | Aerobatics | 4 | August 24th 05 02:36 AM |
Displaced AFSS "controllers" heading for BIL and GRB | Chip Jones | Instrument Flight Rules | 12 | April 10th 05 09:22 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
