I have noticed that a lot of panels look as though the gyros are not
shock mounted. They appear to be mounted directly on a fixed panel. Is it advisable to shock mount them? I'm getting ready to start building my panel and need some advice. Thanks! David |
flyhighdave(at)aol(dot)com wrote:
I have noticed that a lot of panels look as though the gyros are not shock mounted. They appear to be mounted directly on a fixed panel. Is it advisable to shock mount them? I'm getting ready to start building my panel and need some advice. Thanks! David Gyros will last a lot longer if their itty bitty bearings are protected from vibration,---one way is to make a separate panel with all the gyros in it, and suspend this panel from the rest of the Inst. panel. Make provision to add more vibration mounts---sometimes you can get a resonant vibration at cruise RPM |
"jerry wass" wrote Gyros will last a lot longer if their itty bitty bearings are protected from vibration,---one way is to make a separate panel with all the gyros in it, and suspend this panel from the rest of the Inst. panel. Make provision to add more vibration mounts---sometimes you can get a resonant vibration at cruise RPM Your post's wording was a little unclear to me. Are you saying to mount the gyros in their own shock mountings, then add even more vibration mounts, or were you just re-stating that the initial addition of vibration mounts is a good thing? -- Jim (confused, as usual) in NC |
If you are talking about a panel (dash) mount DG, or an electric AH, do not
shock mount them as they are designed to move with the frame (read dash). If it is a remote gyro (for a compass), the housing should have adequate shock mounting. A decent gyro should last 10,000Hrs http://seaerospace.com/sperry/c14a.htm remote DG http://seaerospace.com/rcallen/rca15ak.htm Panel DG Regards Blue "jerry wass" wrote in message ... flyhighdave(at)aol(dot)com wrote: I have noticed that a lot of panels look as though the gyros are not shock mounted. They appear to be mounted directly on a fixed panel. Is it advisable to shock mount them? I'm getting ready to start building my panel and need some advice. Thanks! David Gyros will last a lot longer if their itty bitty bearings are protected from vibration,---one way is to make a separate panel with all the gyros in it, and suspend this panel from the rest of the Inst. panel. Make provision to add more vibration mounts---sometimes you can get a resonant vibration at cruise RPM |
Morgans wrote:
"jerry wass" wrote Gyros will last a lot longer if their itty bitty bearings are protected from vibration,---one way is to make a separate panel with all the gyros in it, and suspend this panel from the rest of the Inst. panel. Make provision to add more vibration mounts---sometimes you can get a resonant vibration at cruise RPM Your post's wording was a little unclear to me. Are you saying to mount the gyros in their own shock mountings, then add even more vibration mounts, or were you just re-stating that the initial addition of vibration mounts is a good thing? OK--Fer instance--lets mount 2 instruments in a 4" X 8" pc of whatever you like---then put four of the little Lord rubber-baby-buggy-bumpers , one in each corner of the panel---if it vibrates badly at cruise RPM, then add one or two more--this will change the resonant frequency and move it somewhere else in the RPM band--maybe even above Red-Line. |
| Horizon Gyro internal lighting? | Chad Lemmen | Owning | 2 | September 6th 04 04:38 AM |
| Instrument mounting question | Rob Turk | Home Built | 4 | July 19th 04 11:33 PM |
| Turn and Bank - RC Allen vs Electrical Gyro Corp | Kevin Horton | Owning | 7 | December 4th 03 12:34 AM |
| Turn and Bank - RC Allen vs Electrical Gyro Corp | Kevin Horton | Home Built | 0 | December 1st 03 01:46 AM |
| Gyro Copter for Sale on EBAY | EC155 Pilot | Home Built | 0 | November 2nd 03 12:34 AM |
