Starting new C172s
Old September 9th 05, 09:17 PM
Larry Dighera
On Fri, 09 Sep 2005 14:10:12 -0600, Newps wrote
in ::
I went flying today and saw that my mechanic had fixed the rheostat,
don't yet know what he did. I have Nulites and now the panel looks
really cool.
Great.
I'll bet it was an easy fix; it's a very simple system:
http://www.nulite.net/electrical.htm
  #62
Old September 9th 05, 09:19 PM
Larry Dighera
On Fri, 09 Sep 2005 14:06:20 -0600, Newps wrote
in ::
Robert M. Gary wrote:
No different from Mooney or probably any other.
-Robert
What?
I think he was referring to the enormously inflated price of aircraft
parts.
  #63
Old September 9th 05, 10:05 PM
john smith
in ::
really cool.
Great.
Another high priced product.
Google "electroluminescent rope"
  #64
Old September 9th 05, 10:38 PM
Larry Dighera
On Fri, 09 Sep 2005 21:05:39 GMT, john smith wrote in
Oh, you mean this stuff:
http://www.glowire.com/basic_glowire_information.htm
Cleaver.
Here
http://www.talkingelectronics.com/Pr...itELine04.html
they say it operates at 120V 500Hz, there might be some interaction
with the ADF at that frequency and its harmonics. Or perhaps Nulites
chose another frequency for their inverter.
  #65
Old September 9th 05, 10:53 PM
Montblack
("Larry Dighera" wrote)
[Robert M. Gary wrote]
What?
parts.
You seldom know what R.M.G. is talking about because he "over-trims."
Montblack
  #66
Old September 9th 05, 11:03 PM
Michael
Alot of bonanza parts are expensive.
Aircraft parts in general are expensive; Beech parts are simply
outrageous.
My injected engines have one way valves that allow fuel to drain in
case it was overprimed. They are Piper parts, and are $50 each. They
are functionally equivalent to automotive valves that cost $10 each.
But that's nothing. My friend has a Baron, and his valves are $600
each. That's the Beech way.
Similar example - rod ends for trim tab actuators. Normally an AN
part, about $15. On the Baron, it's $120.
Most of the Beechcraft parts are very well built and don't need changing
very often.
Many of my friends own Bonanzas and Barons. I have not noticed them
replacing parts less often than I do on my Piper, same vintage. Beech
parts are no better (or worse) than any other aircraft parts. They are
more expensive.
Once the aircraft is up to snuff, the maintenance isn't much different
than other aircraft of the same type.
That's true. Mostly, the parts that wear out are engine, not airframe
parts. Fortunately, the engines are Continental - not Beech/Raytheon.
By the time you figure in all the other expenses - labor, engine parts,
fuel, insurance, hangar, engine overhaul - the high cost of Beech parts
isn't really a significant factor in owning a Beech. It's only when
you buy something that needs a lot of airframe work that the Beech
parts cost hits you hard. That's why you can get such a great deal on
an old Bonanza, Baron, or TravelAir.
Nothing flys like a Bonanza!!!
Actually, lots of things fly like a Bonanza. It's an airplane.
Nothing special.
The real truth is, nothing lands like a Bonanza. Most airplanes in its
class require some skill to land. The Bonanza really doesn't. It's
easier to land than a C-172. It makes you look good. That's why so
many pilots love it.
Michael
  #67
Old September 9th 05, 11:19 PM
Jon Kraus
I hope their parts prices are better than their websight. It is pretty
much worthless. I bookmarked it anyway, just in case :-)
Jon Kraus
'79 Mooney 201
4443H @ TYQ
On Fri, 09 Sep 2005 14:51:56 -0400, Roger
wrote in
So what has been the experience of other Bonanza owners with regard to
maintenance costs?
As of 5 years ago:
Sisors pin for nose gear: Was over $300 (It's 1/4 inch drill rod)
Shimp pack for nose gear: Varies, but bout $170 give or take.
Nose gear strut: $7000
Gear Door hinges: About $470 each and there are two per door.
Outer gear door: About $500
Throttle cable: A tad less than $300, but you'll probably have to
find a supplier for the older Bos as Ratheon doesn't carry them.
Those prices are similarly outrageous to the generator brushes I
mentioned. I presume they are retail prices. The brushes were
wholesale presumably, as I was picking them up for an A&P. Or does
Raytheon offer wholesale pricing at all?
Have you had any luck in mitigating parts costs by shopping at
Wentworth Aircraft, Inc: http://www.wentworthaircraft.com/home.htm
  #68
Old September 9th 05, 11:44 PM
Larry Dighera
On Fri, 09 Sep 2005 22:19:53 GMT, Jon Kraus wrote
in ::
Well, used aircraft parts are quite functional in some applications,
and given they are genuine, you shouldn't run afoul of the FAA as
might occur if automotive parts are substituted. I have found
Wentworth prices to be reasonable, about half of the cost of new.
  #69
Old September 9th 05, 11:46 PM
Robert M. Gary
I have a newsreader that puts replys under the associated posts w/o
regard to time. If you're just reading news sorted by date, I can see
how you can be confused.
  #70
Old September 9th 05, 11:47 PM
Robert M. Gary
BTW: A friend of mine just replaced the tire and wheel on his
Gulfstream. $40K!!
-Robert
Starting Prop Engines in FS2002 [email protected] Simulators 3 August 30th 04 02:54 PM
Starting Engine Question (O-320, Warrior) Lisa Piloting 13 April 1st 04 06:45 AM
New A&P: Typical Starting Salary Range ? Robert11 General Aviation 1 February 6th 04 09:02 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
Boeing 307 Starting Up! Jay Honeck Piloting 5 August 8th 03 06:53 PM
