Hey Guys,
I'm looking at at 172 that has 1100 hours since overhaul, holding 73/90 ++ on all cylinders...the only thing holding me back, last overhaul was 1976... I've talked to several seasoned pilots / aircraft owners that say as long as it's holding good compressions, don't sweat it.... Any opinions? Thanks, Jamie A. Landers PP-ASEL Looking for a 172 |
In a previous article, said:
I'm looking at at 172 that has 1100 hours since overhaul, holding 73/90 ++ on all cylinders...the only thing holding me back, last overhaul was 1976... 1100 hours in 29 years? That's 38 hours a year. The insides of that engine are full of rust and everything is going to go to hell all at once. -- Paul Tomblin http://xcski.com/blogs/pt/ Heuristics are bug ridden by definition. If they didn't have bugs, then they'd be algorithms. |
++ on all cylinders...the only thing holding me back, last overhaul was 1976... Don't pass yet! Are you sure that's not supposed to read 73 / 80 compressions on all cylinders? How many hours has it flown in the last year? In the last 6 months? Does it have chrome cylinders? Does the static run-up meet the type certificate minimum rpm? How many major overhauls and was the last one a quality job? Is the engine on a low to mid time airframe? Is the price discounted enough to account for the fact you may need an overhaul soon? I'm gonna get flamed here, but if it has been flying quite a bit recently, makes good static rpm, has chrome cylinders and good logbooks, you may be on to a good buy. I'd have a pre-buy inspection done including a borescope of the cylinders. You should also consider asking the trusted A&P to pull a jug and inspect the camshaft. If everything checks out okay make an offer based on the above considerations. -- Joe Schneider 8437R (Remove No Spam to Reply) ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
That is patent bull****.
Jim 1100 hours in 29 years? That's 38 hours a year. The insides of that engine are full of rust and everything is going to go to hell all at once. |
I'd probably want to get a look at the camshaft. That sits out of the oil
and can get pitted by lack of use. Might want to take off a jug and have a look. mike "RST Engineering" wrote in message ... That is patent bull****. Jim 1100 hours in 29 years? That's 38 hours a year. The insides of that engine are full of rust and everything is going to go to hell all at once. |
Start it, get it warm and pull an oil sample. If the cam it tits up,
the metal will be visable in the sample. Also, pulling a single jug won't get ALL the lobes visable, and I've never seen ALL the lobes have trouble at the same time. |
Don't ask us if it's any good. The ONLY way to tell that is with a
thorough pre-buy inspection by someone who knows what they are doing. How long since annual? If you are serious it may be worth negotiating with the owner to put it through annual and you pay the prebuy portion. As you describe it, the plane may be in great shape - it may not - thaqt's why you need at least the pre-buy. But you do have a great bargaining chip! Good luck with it. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE In article .com, wrote: Hey Guys, I'm looking at at 172 that has 1100 hours since overhaul, holding 73/90 ++ on all cylinders...the only thing holding me back, last overhaul was 1976... I've talked to several seasoned pilots / aircraft owners that say as long as it's holding good compressions, don't sweat it.... Any opinions? Thanks, Jamie A. Landers PP-ASEL Looking for a 172 |
whats the recient history.
Time sucks for normal things, but an engines history can tell a lot. When was the time put on? was it all in the first years or was it in the last years? If it was in the first few years, i would be more suspect. if it was in the last few years, i would feel very comfortable. If it was mostly old time, that should reflect in the asking price, ie engine rebuild time may be near. Fly it and then get a good prebuy Dave tony roberts wrote: Don't ask us if it's any good. The ONLY way to tell that is with a thorough pre-buy inspection by someone who knows what they are doing. How long since annual? If you are serious it may be worth negotiating with the owner to put it through annual and you pay the prebuy portion. As you describe it, the plane may be in great shape - it may not - thaqt's why you need at least the pre-buy. But you do have a great bargaining chip! Good luck with it. Tony |
++ on all cylinders...the only thing holding me back, last overhaul was 1976... What year 172? Does it have the H2AD engine? How many hours in RECENT years is most important. If it got 1000 hours from '76 to '86, and then 100 hours since '87, run like hell. If, on the other hand, it's flown a lot in the last five years, you may be okay. Study the logs, young Grasshopper, as they will tell the tale. :-) (And get a thorough pre-buy inspection!) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On 9/10/05 15:28, " wrote:
Hey Guys, I'm looking at at 172 that has 1100 hours since overhaul, holding 73/90 ++ on all cylinders...the only thing holding me back, last overhaul was 1976... I've talked to several seasoned pilots / aircraft owners that say as long as it's holding good compressions, don't sweat it.... Any opinions? Thanks, Jamie A. Landers PP-ASEL Looking for a 172 1100 hours in 30 years. Can you say, "Rust"? I knew you could... - Don To confine our attention to terrestrial matters would be to limit the spirit - Stephen Hawking |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
| AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 03:13 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
