Do you use the template to trace the pattern on the tube, or do you
glue the template to the tube and keep it there while cutting? - Mike |
Michael Horowitz wrote in
: Do you use the template to trace the pattern on the tube, or do you glue the template to the tube and keep it there while cutting? - Mike Which ever works for you. I just wrap it around the tube, tape it in place, and grind to the line on the paper. |
Michael Horowitz wrote:
Do you use the template to trace the pattern on the tube, or do you glue the template to the tube and keep it there while cutting? - Mike Wrap the paper tight, lining up the marks and tape across the joint. Twist the paper around to clock it right. Slap on another piece of tape, with about 1/8" laying on the tube. Cheap scotch tape wants to come apart rahter than off, and you just need a little to hold it in place. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() Michael Horowitz wrote: Do you use the template to trace the pattern on the tube, or do you glue the template to the tube and keep it there while cutting? - Mike I cut out the template and tape it to the tube, then use a Sharpie marker to trace the pattern. Then take off the template and grind away. Dave www.davewilson.cc |
I know this is a late response, but (for what it's worth) my trick is
to wrap the pattern around the tube (in the correct place?) and spray a little white krylon on the exposed tube. Then grind off the painted area. Richard |
Richard Lamb wrote:
I know this is a late response, but (for what it's worth) my trick is to wrap the pattern around the tube (in the correct place?) and spray a little white krylon on the exposed tube. Then grind off the painted area. Richard Richard, that will work just fine, but it requires that you carefully cut out the template. Rough cut and tape to the tube, then just cut to the line. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Problem is ----
The paper catches on fire! OOOps! Richard (call the fire dept) Lamb |
