Why no new diesel radials?
Old September 12th 05, 05:11 AM
Drew Dalgleish
If I won the lottery I'd buy a machine shop. My fist project would be
to machine a radial case to accept cylinders off a deutz engine
There are excavators using those, screaming full tilt all day
long with next to no airflow!
Yeah I work in an underground mine. I've seen first hand what kind of
abuse these engines can endure in the hands of union personel that
hate the things.
Old September 12th 05, 05:13 AM
Drew Dalgleish
Most gas radials I've seen/flown had around 8:1 compression,
that's food for thought. Just wondering though, are the german
aircooled diesel cylinders intergral with the block?
Nope as far as
I know separate cylinders and heads
Old September 12th 05, 05:15 AM
Drew Dalgleish
On 11 Sep 2005 15:58:58 -0700, "EAA TC 1441"
Zoche had displayed his radial Diesels at Oshkosh for some twenty
years.They were extremely smooth running two stroke turbocharged single
or twin row configurations. Compact, light, and well designed. Zoche
was most likely ahead of the market.
See back issues of Sport Aviation.
Don Black
I think Zoche was the origional inventor of vaporware.
Old September 12th 05, 07:06 AM
mike
the WWII era Guiberson and Cat D-200A Radials had 14.3:1 and
15.5:1 respectively. The Guiberson weighed about 1100 pounds
in Tank trim, And that Cat engine started out as an Wright R-1820,
but weighed over 3000 pounds by time Cat beefed it up enough
to be reliable.
mike
Old September 12th 05, 07:03 PM
EAA TC 1441
The "Lycoming-Detroit" opposed motor is actaually the Italian V-M of
V-M Motori, a onetime company owned by AlfaRomeo. This is the 2nd time
that americans have attempted to market this line in the US. It is
modular and very economical. Back in the 70's the attempt to
distribute failed due to lack of experience and a serious investment in
the future. When FIAT "bought" AlfaRomeo, they did not want the sister
companies of Alfa, so they were sold off, along with AlfaAvio. V-M
automotive motors are very successful due to their low noise levels and
extremely low untreated exhaust emissions.
Further to the radial comments, Dont forget that the Packard radial
Diesel was built in Detroit and was not popular with airframe designers.
Old September 14th 05, 04:33 AM
On-Condition
to be reliable.
Diesels are heavy, I know. Just got my tractor
up to about 35mph on the runway, but the damned
thing wouldn't stay in the air.
(2-stroke) aircooled diesel radials:
70 hp 121 lbs
150 hp 185 lbs
300 hp 271 lbs
http://www.zoche.de/specs.html
Old September 16th 05, 02:47 AM
On-Condition
Thanks for the details; it's most interesting. I had presumed that
a brand new engine was in the oven.
Yeah, there's that one thing that turns designers right off: weight.
  #28
Old September 19th 05, 10:22 PM
On-Condition wrote:
Just wondering, exactly why are radial diesels not part of the
diesel revival? You can't beat radials on airplanes for smooth
reliability. I once saw a cracked-off jug pounding through the
cowling as the engine was still running (the single Otter had
just landed).
Guiberson: 4 stroke 9 cylinder radial, 2 valves per cylinder, 300HP.
Packard: 4 stroke 9 cylinder 1 valve per cylinder (Neato) 225HP.
Zoche is a ported 2 stroke, if I recall it was supposed to be available
in 2 4 and 8 cylinders.
There is an V4 in development in the US, a piston-opposed 2 cyclinder 2
stroke 100HP engine in the UK that is apparently shipping, and 150HP
engine (I think in france?) that is also shipping and I believe is
either certified or approaching certification in the 172. (Anybody know
whether the ICAO agreements make that a certifiable install in the
USA?)
One thing I always wondered about the old radial diesels was how prone
these engines were to hydraulic lock? I mean you can take a plug out of
a gas radial and drain oil, but at the lower compression ratio you
should just have to walk a couple blades through once in a while to
prevent it. At 15 to 1 compression ratio, I would think diesel radials
would be much more susceptable to overpressuring the jugs. Looking at
the zoche engine this seems doubly odd, since there are no valves to
let excess engine oil out of the lower cylinders. Anybody know how they
deal with this?
I've read quite a bit of conflicting information about diesel radials.
One account said that the packard had good high altitude performance
because the nature of a diesel is to always have a lean air/fuel ratio,
so it it would richen the mixture into a better ratio as it climbed.
I've read in usenet other accounts that said that the high altitude
performance sucked. Guess we'll just have to take one out and fly it to
see :-)
The packard was 1 valve per jug, (reasonable since it is just air, not
fuel) ran on stove oil. The arrangement has a donut flange on the top
of the cylinders and uses ram air to clear the exhaust gasses. The side
effect though is that your exhaust is not funneled, so the pilot and
pax of a single engine bird end up sucking diesel exhaust. Obviously
hanging the engines under the wings fixes that, but in the thirties
that was easier said than done.
Then you have fuel considerations. Stove oil and summer diesel can gel
at altitude, requiring some fairly complex added equipment to correct
the problem, which I am guessing is why all the new ones are designed
to run on Jet-A. Somebody else mentioned a priming issue as well in a
previous thread. In essence, if you stop the engine from fuel
starvation, the fuel injectors suck air out of the cylinders instead of
sucking fuel out of the fuel line, so you can't restart. (Am I
understanding that problem correctly?) old diesels have hand priming
pumps to fix this. Look under the hood of Mercedes 240D for example, it
looks like a little accordion on the drivers side of the engine. I
believe common rail injection solves this problem though.
So the system infrustructure for using a diesel is a bit more complex
even though you don't need magnetos. Complex = weight. Though in
general I expect if it had ever become a reasonably standard practice
the kinks would have been worked out a long time ago. Actually it
probably would have been become more practical as the number of jugs
grew because of the increase in mechanical efficiency native to the
radial configuration. (Can you imagine an 18 cylinder diesel WASP sized
engine?) But now there are turbines for that kind of power, so theres
no reason to do it.
Weight is an issue with smaller engines yes. The packard made 2/3's of
the rated power of a comparable gas engine of the era at the same
weight. (And that is an educated guess, I don't feel like looking it
up, but it is probably generous.) Higher pressure in the jugs requires
more steel to be reasonably reliable. No way to get around that. Like
all things diesel, you have to accept some derated performance if you
want the benefits.
I read an article about a PT6A that was tested with B100 mixed into the
fuel. If I remember they noted no significant change in performance up
to about 20% blend or so. Though I have to wonder, since the PT6A is
sometimes configured to derate its max power whether this was accurate.
(Am I correct there? Isn't the one in the Caravan derated to 600HP from
1000?)Also the test was relatively short compared to the actual
lifespan of turbine so the results though positive, were not conclusive
in my humble interpretation of the report. But it was a while ago that
I read that.
So that about sizes up my understanding of the current situation
What I'd like to see someone work out a new turbine design with an
injector and hot section suitable for running on SVO or B100. Stick
that on a couple of 747's, diesel trains, and cruise liners and you
save thousands of tons of net-CO2 emissions a year.
Anybody is welcomed to jump in and correct me where I'm wrong. I'm sure
some of this in misinformation. This is usenet after all.
-Matt
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Owning 1 January 4th 04 04:04 AM
