CAP gridding
Old September 13th 05, 01:16 PM
Hotel 179
"Robert M. Gary"
wrote in message Our squadron still requires old style gridding. Perhaps
its just a
right-of-passage.
-Robert
Well, there you have it....when I was taught to grid charts, we would draw
the lines with a straight-edge and a "sharpie" but only label the grids on
the extreme left hand side of the chart....you then cut down on the amount
of writing on the chart which gives it a cleaner look. But....that was then.
Have you noticed the de-brief on the back of the CAPF-104? You list the
"grids searched" using the new method. It's good to know how things used to
be, but CAP once used little yellow planes....don't see many of those at the
missions that I fly these days.
Semper vi.,
Stephen
Old September 13th 05, 05:18 PM
Robert M. Gary
Having just finished, I think I would buy the pre-gridded if I were to
do it again. It look me about 1.5 hours to do it. My time is worth much
more than that (I could have been billing clients during that time).
However, that was the first time I had ever even seen a gridded
sectional so I was trying to put it together from reading the CAP
manual. It probably would have been easier if I'd actually seen a
gridded chart before.
-Robert
Old September 13th 05, 08:23 PM
Peter Duniho
oups.com... Having just
I'm still waiting for someone to explain to me what it is about the gridding
that takes so much time.
Granted, no one has any real reason to care whether I understand or not, and
maybe that's why the people who apparently ought to know have been skirting
the issue. "Not my problem, go away". But the best description I've seen
so far involves drawing a grid, and writing some numbers. A straight-edge,
a ruler (or plotter), and a writing implement, and nowhere near 1.5 hours of
time are all I can see.
Why did it take you 1.5 hours to draw some lines?
Pete
Old September 13th 05, 11:03 PM
Robert M. Gary
For me it was a combination of learning how to do it while doing it and
trying to draw long lines with a 12" ruler. There are also a LOT of
grids. On the SF sectional it was something like 500 all told if you
miss one, the entire chart is messed up. Sometimes hunting for the
little 5 tick mark on the lat/long lines took some time when lining up
the ruler because the feds seem to put the tick marks in the background
anytime there is anything else interesting in the area. The sectional
is broken up with large marks for every 10 degrees but CAP uses the
much smaller 5 degree marks to split 30 degrees into two 15 degree
sections. I'm told that CAP is slowly moving to a new method that does
not require gridding. In truth the whole idea seems very silly and
error prone. Rather than assign grid numbers to sectionals, it makes
more sense to refer to the lat/long of the grid. That is basically what
the new method is.
-Robert
Old September 13th 05, 11:17 PM
Hotel 179
grids. -Robert
Robert and All,
You should use a Scientific Wild-Assed Guess (SWAG) method for gridding.
Draw the lines on the lat/long marks.....eye-ball the half-way, then half
that. The grid sizes are 7.5 x 7.5 and can be divided smaller if needed.
Number ONLY the outside grids on the far left....if you need to find grid
number 32, go to grid 25 on the far left and count east for 7 grids.
In a situation where aircraft are working adjacent grids, the planners will
make an effort to have the aircraft work in the same direction so that both
creep east (or any heading) and thus avoid coming near each other at the
grid edges....If you are the mission pilot, one of your jobs is to make your
turns so that you remain within the confines of your assigned grid(s).
Once you get the hang of it, a sectional can be marked in about 10
minutes....the best thing is to come into the modern era and use the new
system.....no sharpie needed!
Semper vi,
Stephen
Old September 13th 05, 11:41 PM
Peter Duniho
Okay, so how about using a yardstick instead? One time purchase
significantly less than $30.
There are also a LOT of grids.
Grids? Or lines?
That's definitely true...I've had problems in the past where the lat/long
ticks aren't even visible because of other stuff on the chart. But I could
always refer to adjacent lines to find the correct position.
The sectional
sections.
Degrees? Or minutes? Is the main problem that the sectional has 10 degree
intervals, while the CAP grids use 15 degree intervals? Or is it simply the
sheer number of lines? Why does missing a line mess the whole chart up? If
the other lines are on their correct locations, couldn't you just add the
missing line?
the new method is.
I guess I'm still not getting it. I suspect this is one of those "a picture
is worth one thousand words" situations. If only someone had a picture they
could show me, I suspect all would be clear to me.
Anyway, thanks for trying.
Pete
Old September 14th 05, 01:09 AM
Robert M. Gary
Actually, aren't they marked in 15 minute intervals. The 7.5's are not
typically marked but are the ABCD regions of a 15 minute area?? Do you
actually draw the 7.5 minute lines too and mark each grid ABCD???
i..e grid 425A
-Robert
Old September 14th 05, 01:12 AM
Robert M. Gary
Probably two issues. First, I didn't have one last night. Second,
the lines are not really that straight. The horizontal lines bow down
in the middle of the chart.
But I could always refer to adjacent lines to find the correct position.
Sometimes that worked. Remember 12" ruler. It takes a few minutes to
hunt around looking for the line that is clear. Sometimes you don't
find one w/i 12"s.
Grids? Or lines?
Both. The lines were part of the work. Numbering 500 grids also takes
time though.You can't just go straight through because if you get one
off, they'll all be off. You'll want to find a reference (usually an
index that tells you what the first grid for each row is) to verify
before begining each row. Add to that ensuring that you don't number a
grid that you shouldn't (partial grids on the sides aren't numbered,
some are pretty close to not being partial though) and handling overlap
of sectionals and its a bit more work.
If someone walked up to me, asked me to work the LA sectional area
(I've not done LA) and offered to have me sit down and grid one or hand
me a professional looking one for $30, I'd pull out the $30. They also
probably use better ink. I used dark brown which shows up well on water
but not so well in the mountains.
-Robert
Old September 14th 05, 05:39 AM
Hotel 179
"Robert M. Gary"
i..e grid 425A
-Robert
Robert,
You are right....I shouldn't be typing stuff so early in the morning. I
don't use gridded charts anymore, but when I did it was as I described
before....I'd number the outside edge and count across to the grid that I
needed.
Pete....sorry to not express the units....minutes is the answer. As you
described in your question, I'd use a yard stick and zip down and across the
sectional with a sharpie. Split those and you have the 15 minute by 15
minute grids. Begin the numbering in the upper left-hand corner and count
to the east for 24 grids (I think that's about right). There is a
publication that lists the numbers of grids on the different sectionals.
The system now is much simpler in that you use the existing lat/long lines
and name the grid by the lower right hand corner lat/long intersection. As
with anything else, the more you work with it the easier it is to
manipulate.
V/r,
Stephen
Stephen
Old September 14th 05, 08:46 AM
Peter Duniho
"Hotel 179" wrote in message
the sectional with a sharpie. Split those and you have the 15 minute by
15 minute grids. Begin the numbering in the upper left-hand corner and
count to the east for 24 grids (I think that's about right). There is a
So, if I understand correctly...
The grid is simply lines drawn at 15 minute intervals latitude and
longitude, with each box in the grid labeled starting from the first
complete box found on the sectional in the upper left corner?
I get 34 boxes across for the Seattle sectional, by 20 boxes down. More
importantly, as I think someone else did point out, the lines aren't
actually straight across. You can use a yardstick, but it has to be
adjusted as you progress across the chart, at least for the horizontal
lines. It's theoretically only 54 lines, but I can see how that could jump
to almost 700 lines if you're doing the horizontal ones one box at a time.
That curved line bit, assuming the pre-gridded charts line up perfectly with
the projection used for the sectional, is probably the real sticker in terms
of value of the $35 per chart cost. Thank you for those with the patience
to keep trying to explain it to me.
Pete
