#31
Agreed. My reference was to flying simulated (under the hood) in vmc without
a SP "Ron Rosenfeld" wrote in message ... On Tue, 13 Sep 2005 16:34:11 -0400, "pgbnh" wrote: If I am flying VMC, other than simulated (with appropriate SP), then flying by instrument reference is wrong (and stupid). Except for a moonless. cloudy night over water (or desert), where you may be legal VFR, but with no outside references. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#32
![]() Steven P. McNicoll wrote: Make up your mind. In your initial message you said you were in VMC the whole time. That means you never got closer to any cloud than allowed by FAR 91.155 and had at least 3 miles visibility at all times. I don't see any need to harass him about that. It's quite clear to me after reading his initial post only once that at some point during the approach he was below the cloud clearance requirements for VMC. |
#33
![]() wrote in message ups.com... I don't see any need to harass him about that. It's quite clear to me after reading his initial post only once that at some point during the approach he was below the cloud clearance requirements for VMC. What in his initial post indicated that to you? |
#34
Ron Rosenfeld wrote: On Tue, 13 Sep 2005 16:34:11 -0400, "pgbnh" wrote: If I am flying VMC, other than simulated (with appropriate SP), then flying by instrument reference is wrong (and stupid). Except for a moonless. cloudy night over water (or desert), where you may be legal VFR, but with no outside references. Been there. Done that. I agree. It is actually possible to have IMC with no clouds around at all. ![]() Out here in the desert southwest (NM, AZ), on a moonless night away from the cities and towns, the ground is, quite literally, invisible. No lights. No roads. No nothin'. It's pitch black. And given the irregularity of the horizon due to mountains and hills, it's almost impossible to tell if you're level by looking outside and trying to judge the horizon by the stars. While it may be technically VMC, and "legal" VFR, it's not safe. Filing IFR and "going on the gauges" is the right thing to do in that case. -- Dane |
#35
#37
On Thu, 15 Sep 2005 22:03:26 -0400, Wizard of Draws
wrote: I would say that you don't need to, but if you're on the gauges, your outside scan is minimal and it just might be prudent to have a second set of eyeballs looking out for you with radar. FF is good too, but they may not be able to handle you as VFR traffic. I sure don't object to someone filing IFR whenever they have to "go on the gauges". However, when I'm on an IFR flight plan, I really don't have much difficulty including the outside in my scan. When VMC on a moonless, dark night, the ability to see other traffic is enhanced, in my experience. Flying from, let us say, PVC (Provincetown) to Nashua (ASH), going VFR gives one a lot of flexibility that IFR does not. I've never had a problem with flight following in that area. And I can imagine that other areas IFR flight would also be unneccessarily restrictive in terms of routes or altitudes, especially if in a non-radar environment. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#38
Well, you're right it's not actually too clear. Although assuming he's
not lying, it seems likely that he's misusing the term VMC. He says "I was in VMC the whole time yet it probably would have been illegal to fly in VFR as I would have been close to the clouds". This tells me he thinks he was too close to clouds at some point to be legal for VFR. This further implies he is aware there exists a cloud clearance requirement for legal VFR. So assuming he's not lying when he estimates he was too close to them for VFR, then he must have mistakenly used the term VMC to mean he remained clear of clouds. At least that's the way I read it. The first time through. |
#39
On 17 Sep 2005 01:50:53 -0700, wrote:
Well, you're right it's not actually too clear. Although assuming he's not lying, it seems likely that he's misusing the term VMC. He says "I was in VMC the whole time yet it probably would have been illegal to fly in VFR as I would have been close to the clouds". This tells me he thinks he was too close to clouds at some point to be legal for VFR. This further implies he is aware there exists a cloud clearance requirement for legal VFR. So assuming he's not lying when he estimates he was too close to them for VFR, then he must have mistakenly used the term VMC to mean he remained clear of clouds. Special VFR? It's still VFR rules, but just clear the clouds in the airport area. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com At least that's the way I read it. The first time through. |
#40
Would the approach controller be able to give him a special VFR
clearance? I've only ever gotten one from a tower. Roger wrote: On 17 Sep 2005 01:50:53 -0700, wrote: Well, you're right it's not actually too clear. Although assuming he's not lying, it seems likely that he's misusing the term VMC. He says "I was in VMC the whole time yet it probably would have been illegal to fly in VFR as I would have been close to the clouds". This tells me he thinks he was too close to clouds at some point to be legal for VFR. This further implies he is aware there exists a cloud clearance requirement for legal VFR. So assuming he's not lying when he estimates he was too close to them for VFR, then he must have mistakenly used the term VMC to mean he remained clear of clouds. Special VFR? It's still VFR rules, but just clear the clouds in the airport area. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com At least that's the way I read it. The first time through. |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
Contact approach question | Paul Tomblin | Instrument Flight Rules | 114 | January 31st 05 06:40 PM |
Logging Flight Time Question | Phoenix Pilot | Piloting | 1 | June 13th 04 06:23 PM |
Where is the FAF on the GPS 23 approach to KUCP? | Richard Kaplan | Instrument Flight Rules | 36 | April 16th 04 12:41 PM |
Study pilot workload during approach and landing | Freshfighter | Piloting | 5 | December 7th 03 04:06 PM |
