#21
On Wed, 14 Sep 2005 23:46:10 GMT, Chris Kennedy
wrote in :: but the issue is with uncommanded roll as a consequence of turbulence. If the aircraft is not maneuvering (or even if it were), the electronically augmented control system would detect an incipient wing displacement before a human could detect it, and issue the appropriate control input to counter it. These commands would occur so rapidly as to be virtually undetectable by the occupants. Think of the electronic suspension systems available on some of today's automobiles*. They are capable of providing a smooth ride over the roughest of roads by sensing body dip, and immediately extending the suspension to prevent further excursions. These corrections happen in milliseconds; it verges on magic. If the roll rate is brisk, there may be some increase in G felt by passengers in the rising wing, and decrease in G felt by those in the descending wing, but with today's computerized fly-by-wire control systems, all these concerns could be largely eliminated in nearly all cases. Unless you're suggesting that fly by wire could automatically limit the roll rate to limit the acceleration felt by outboard passengers I'm unclear how it would address the problem. I'm confident that an electronic control system could dampen all but the most severe turbulence induced excursions, in addition to seeing that the commanded roll rate was strictly met. There's also the roller coaster effect -- being on the high side and looking down the width of the cabin at what seems like an exaggerated angle -- but I suppose one could deal with that with dividers of some sort. Exactly. First class would be along the longitudinal axis with coach toward the wing tips with obscure partitions separating them. There's also the issue of just how one evacuates such an aircraft. Umm... Crashworthyness would be an issue less amenable to resolution than evacuation. As I said, good for freight, but I'd take some convincing before I flew in one. In the event of an in flight electrical failure disabling the electronic control augmentation, it could get "interesting." What does Airbus use to overcome that issue? Of course I'm not too thrilled with the idea of riding in an A380, either. Right. In the event of a 800+ passenger stampede, one would likely be trampled before he could clear the aircraft. :-) * http://tinyurl.com/ah236 http://www.edmunds.com/insideline/do...ticleId=100444 The optional F55 Magnetic Selective Ride Control suspension adjusts the shock damping rates instantly in response to changing conditions. http://www.corvettecenter.com/magneticrc.htm http://www.modernracer.com/history/c...c6history.html optional F55 Magnetic Selective Ride Control suspension features magneto-rheological dampers able to detect road surfaces and adjust the damping rates to those surfaces almost instantly for optimal ride and body control. Magnetic Ride Control debuted on the 2003 50th Anniversary Edition Corvette, and is the world’s fastest reacting suspension, replacing mechanical valves with nearly instantaneous reactions of magneto-rheological fluid. The system has been improved for the 2005 Corvette, allowing drivers more differentiation in character between the system’s two settings, “Tour” and “Sport.” |
Larry Dighera wrote:
but the issue is with uncommanded roll as a consequence of turbulence. If the aircraft is not maneuvering (or even if it were), the electronically augmented control system would detect an incipient wing displacement before a human could detect it, and issue the appropriate control input to counter it. These commands would occur so rapidly as to be virtually undetectable by the occupants. Most contemporary transport aircraft have gust alleviation systems (not so much for ride comfort than to reduce structural loads); the B-2 has a similar system. The systems have only limited ability to counter roll but it's not for want of trying -- it's sort of entertaining looking out and watching twitchy spoilers trying to keep the wings level -- or the wingtips from trying to touch. Actuator response times, interactions with the stability of the design and the possibility that the roll rate induced by gust could exceed the roll rate of the aircraft place limits on the magic that you can perform. It's not to say that you can't come close. Think of the electronic suspension systems available on some of today's automobiles*. They are capable of providing a smooth ride over the roughest of roads by sensing body dip, and immediately extending the suspension to prevent further excursions. These corrections happen in milliseconds; it verges on magic. Yet more technology grafted on from Lotus. I was never quite understood why they never commercialized that technology -- save for the fact that it sucked power and had really bad failure modes. Unless you're suggesting that fly by wire could automatically limit the roll rate to limit the acceleration felt by outboard passengers I'm unclear how it would address the problem. I'm confident that an electronic control system could dampen all but the most severe turbulence induced excursions, in addition to seeing that the commanded roll rate was strictly met. That's sort of my point. Unless you limit commanded roll rate to something small you haven't done anything to address the problem of G (un)loading for the outboard passengers, and setting the roll rate limit low creates its own class of problems. There's also the roller coaster effect -- being on the high side and looking down the width of the cabin at what seems like an exaggerated angle -- but I suppose one could deal with that with dividers of some sort. Exactly. First class would be along the longitudinal axis with coach toward the wing tips with obscure partitions separating them. Yeah, that's the notion I was after. There's also the issue of just how one evacuates such an aircraft. Umm... Crashworthyness would be an issue less amenable to resolution than evacuation. Both would be -um- problematic. In the event of an in flight electrical failure disabling the electronic control augmentation, it could get "interesting." What does Airbus use to overcome that issue? They don't. Everything is inputs to the redundant autopilot system; stick and throttle are suggestions, not really commands. Raise your hand if you've had to sit on the ramp while they do a complete engine shut down in order to reboot an A320 series aircraft prior to departure (it's happened to me twice). Of course I'm not too thrilled with the idea of riding in an A380, either. Right. In the event of a 800+ passenger stampede, one would likely be trampled before he could clear the aircraft. :-) That's assuming that you weren't in the middle of a refreshing mud bath with cucumber slices on your eyes (if you believe for a moment the claims of Airbus and Branson that A380s will have such amenities as opposed to high density seating). |
"Larry Dighera" wrote in message I would guess that much of the
inefficient airline fleet would not be competitive in tomorrow's airline industry, and should be relegated to the junkyards. How else will tomorrows airlines be able to be competitive? Here's a question. Will replacing a $3mil medium by-pass jet with a $28mil high bypass jet save money? Lower mortgage apyment of lower fuel bill, which is better? D. (answer to follow) |
#24
On Fri, 16 Sep 2005 02:46:39 GMT, "Capt.Doug"
wrote in :: "Larry Dighera" wrote in message I would guess that much of the inefficient airline fleet would not be competitive in tomorrow's airline industry, and should be relegated to the junkyards. How else will tomorrows airlines be able to be competitive? Here's a question. Will replacing a $3mil medium by-pass jet with a $28mil high bypass jet save money? Lower mortgage apyment of lower fuel bill, which is better? D. (answer to follow) I suppose Boeing would have the answer to that question. I doubt they'd be considering producing the aircraft if air carriers were not going to operate it. |
#25
"Capt.Doug" wrote: "Larry Dighera" wrote in message I would guess that much of the inefficient airline fleet would not be competitive in tomorrow's airline industry, and should be relegated to the junkyards. How else will tomorrows airlines be able to be competitive? Here's a question. Will replacing a $3mil medium by-pass jet with a $28mil high bypass jet save money? Lower mortgage apyment of lower fuel bill, which is better? Depends, "How long do you plan on keeping it?" What is the depreciation schedule? |
#26
![]() "Capt.Doug" wrote in message ... "Larry Dighera" wrote in message I would guess that much of the inefficient airline fleet would not be competitive in tomorrow's airline industry, and should be relegated to the junkyards. How else will tomorrows airlines be able to be competitive? Here's a question. Will replacing a $3mil medium by-pass jet with a $28mil high bypass jet save money? Lower mortgage apyment of lower fuel bill, which is better? D. (answer to follow) Doesn't everyone lease the planes (or powerplants) these days, or at least have some sort of power by the hour performance based logistics maintenance program these days? |
#27
" Blueskies" wrote in message Doesn't everyone lease the planes (or
powerplants) these days, or at least have some sort of power by the hour performance based logistics maintenance program these days? In most jet airlines, fuel is 50% of the cost. One year ago, jet-A was around $1.26/gal for my employer. Now it is just under $2.00/gal (not considering hedges). Replacing an MD-80 with a B-737NG or an A-320 results in 30% fuel savings. Even with the higher lease payments, my employer saves $200,000.00 per airplane replaced in the first year. It's a Catch-22 for the legacy carriers who are stuck paying high fuel costs because they don't have the cash to update their fleet. They don't have the cash to update because they have high fuel costs. Of the discount carriers ringing up a profit, how many are flying high bypass engines and how many are flying medium bypass engines? Everytime I see a Northwest DC-9, I wonder how long before they file for bancruptcy (question recently answered- longer than I expected). Why did Boeing discontinue the B757? I'm not sure, but I do know that the A-321 hauls nearly as many passengers and yet the A-321 has a MGTOW that is 60,000 pounds lower. It takes a lot of fuel to haul around an extra 60,000 pounds. What will the new B-787 weigh? Why did Airbus feel threatened enough to counter with the launch of the A-350 program? It's about saving fuel. As for leasing, there are many ways to structure a lease. Many times, large shareholders will own an aircraft (though the paper trail may be long and convoluted) and lease it to the airline, often at a sweetheart rate. With this method, the shareholder makes money on it's investment in the airline even if the airline doesn't make money. Power by the hour contracts are available for both old and new engine series. The difference is that the newer engine models have fewer life-limited component times resulting in less down time. The same thing applies to other components. Brake overhauls can be contracted for old and new planes. The difference is that the old style steel brakes have more down time, and man-hours required for replacing, than the new style carbon brakes. Contract or not, someone has to pay the difference. D. |
#28
"Larry Dighera" wrote in message In the event of an in flight electrical
failure disabling the electronic control augmentation, it could get "interesting." What does Airbus use to overcome that issue? Airbus's first answer is that it has never happened. If an engine generator drops offline, the other generator picks up the load. The APU generator can pick-up the load if the second engine generator drops offline. The ram air turbine powers a back-up generator if all 3 main generators crap out. Even if the RAT doesn't deploy, the batteries provide at least 25 minutes of electricity. The engines' FADEC units have their own independent generators. Augmentation may be the wrong word. It refers to the levels of protection afforded to the flight envelope. As long as you have a generator or a battery, you will have control. 'Complete electrical failure' is the wording I believe you wanted. Try flying a light twin without touching the yoke. You have throttles, rudder, and elevator trim, but no elevator, ailerons, flaps, or instruments. And the gear probably won't extend. The A-320 stalls like a C-172, lots of buffet and drops straight ahead. With calm winds and a long runway, you can make your dinner reservations at Nanno's. The real danger is if you lose all 3 hydraulic systems. D. |
#29
"Chris Kennedy" wrote in message
They don't. Everything is inputs to the redundant autopilot system; stick and throttle are suggestions, not really commands. This true when operating in normal law mode (99% of the time). However, when degraded to direct law mode, the A-320 operates like a normal airplane. The reboot is not because it can't fly, but because we like everything to work so as to provide the safest flight we can (and we are lazy and don't want to handfly a whole leg). D. (it tunes it's own VORs) |
#30
On Sat, 17 Sep 2005 03:41:46 GMT, "Capt.Doug"
wrote in :: "Larry Dighera" wrote in message In the event of an in flight electrical failure disabling the electronic control augmentation, it could get "interesting." What does Airbus use to overcome that issue? Airbus's first answer is that it has never happened. That smacks of the argument used in assuring security against the September 11, 2001 attacks. :-) If an engine generator drops offline, the other generator picks up the load. The APU generator can pick-up the load if the second engine generator drops offline. The ram air turbine powers a back-up generator if all 3 main generators crap out. Even if the RAT doesn't deploy, the batteries provide at least 25 minutes of electricity. The engines' FADEC units have their own independent generators. At first glance, five levels of electrical power source redundancy would seem safe in guarding against 'Complete electrical failure', however there are other points of failure in electrically operated systems. Each electrical circuit is fed through a circuit breaker. How many circuit breakers are involved in the Airbus flight control system? How many electrical buses? Augmentation may be the wrong word. It refers to the levels of protection afforded to the flight envelope. As long as you have a generator or a battery, you will have control. 'Complete electrical failure' is the wording I believe you wanted. No, that is the phrase that describes the issue you addressed. I'm more concerned about single points of failure. If the circuit breaker (an electrical/mechanical device) feeding the electrical bus supplying the flight control system were to malfunction, regardless of power being available, the bus could be de-energized, and no amount of available power would bring the flight control system back into operation, unless you know of additional redundancy designed in to the Airbus control system that you have not yet discussed. Try flying a light twin without touching the yoke. You have throttles, rudder, and elevator trim, but no elevator, ailerons, flaps, or instruments. And the gear probably won't extend. I've not had that experience, but in a light single engine aircraft with exclusively mechanical controls, its occupants would probably walk away from the "landing." In the event that a mechanical malfunction in its control system, it would only affect the control of a single axis (like the Alaska flight that went down off the Ventura, California coast five years ago :-(), not the entire 3-axis flight control system. But Airbus products do have mechanical elevator trim, IIRC, so in the event of the electrical portion of the flight control system failing, there would still be some control of one (important) axis. The A-320 stalls like a C-172, lots of buffet and drops straight ahead. With calm winds and a long runway, you can make your dinner reservations at Nanno's. So you're intimating that only the ailerons and elevator are electrically operated? The real danger is if you lose all 3 hydraulic systems. Are you saying there are three hydraulic actuators, one from each hydraulic system, attached to each control surface? |
High-tech gizmos propel aviation into the future | Omega | Piloting | 3 | June 11th 05 06:48 AM |
Laser beams being aimed at airliners? | Corky Scott | Piloting | 101 | January 22nd 05 08:55 AM |
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Any planes remotely quiet? | Chris Hoffmann | Owning | 3 | July 27th 03 06:13 AM |
