My old project plane has working flap but it appears pin for hinge is
corroded and stuck. Flap needs to be removed for access to rear main gear bracket. I can't get a grip on holding the pin and pulling or twisting. Being cheap , would rather not cut the pin into small removable pieces as a long replacement pin or piano hinge ships at a higher rate. Suggestion would be appreciated, thanks. Dick |
Can you cut ONE loop off an end and get a grasp on the pin that way?
Or, can you, using a small punch drive the pin out the other way? John Dick wrote: My old project plane has working flap but it appears pin for hinge is corroded and stuck. Flap needs to be removed for access to rear main gear bracket. I can't get a grip on holding the pin and pulling or twisting. Being cheap , would rather not cut the pin into small removable pieces as a long replacement pin or piano hinge ships at a higher rate. Suggestion would be appreciated, thanks. Dick |
![]() "Dick" wrote in message ... My old project plane has working flap but it appears pin for hinge is corroded and stuck. Suggestion would be appreciated, thanks. Dick Try " Kano Kroil"... put a drop on each joint and let it set a coupla days... Should then easily drift out... See: http://www.kanolabs.com/ ... located in BNA... Don L. n FTW |
Don Lewis n FTW wrote:
"Dick" wrote in message ... My old project plane has working flap but it appears pin for hinge is corroded and stuck. Suggestion would be appreciated, thanks. Dick Try " Kano Kroil"... put a drop on each joint and let it set a coupla days... Should then easily drift out... See: http://www.kanolabs.com/ ... located in BNA... Don L. n FTW In the Air Force we had some rather long hinges. To get the pins in or out we'd chuck the end into a drill and spin it as it was removed or installed. A properly aligned hinge takes only a few seconds to pin. Dan, U.S. Air Force, retired |
Try some Mouse Milk to help loosen it up.
Patrick student SPL aircraft structural mech "Dan, U.S. Air Force, retired" wrote in message news:qUiWe.20500$dm.10661@lakeread03... Don Lewis n FTW wrote: "Dick" wrote in message ... My old project plane has working flap but it appears pin for hinge is corroded and stuck. Suggestion would be appreciated, thanks. Dick Try " Kano Kroil"... put a drop on each joint and let it set a coupla days... Should then easily drift out... See: http://www.kanolabs.com/ ... located in BNA... Don L. n FTW In the Air Force we had some rather long hinges. To get the pins in or out we'd chuck the end into a drill and spin it as it was removed or installed. A properly aligned hinge takes only a few seconds to pin. Dan, U.S. Air Force, retired |
Hinge pins for Pegasus AD | tooromeo | Soaring | 0 | May 17th 05 02:56 PM |
PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 03:36 AM |
Aluminum hinge | VideoFlyer | Home Built | 2 | May 11th 04 08:39 PM |
Stuck starter solenoid? | Paul Lee | Home Built | 4 | April 16th 04 02:58 PM |
Stuck valve versus plugged injector | Viperdoc | Owning | 6 | April 13th 04 12:15 AM |
