Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
STuck piano hinge pin
Old September 15th 05, 03:53 PM
Dick
Default STuck piano hinge pin
My old project plane has working flap but it appears pin for hinge is
corroded and stuck.
Flap needs to be removed for access to rear main gear bracket.
I can't get a grip on holding the pin and pulling or twisting. Being cheap ,
would rather not cut the pin into small removable pieces as a long
replacement pin or piano hinge ships at a higher rate.
Suggestion would be appreciated, thanks. Dick
Old September 15th 05, 04:36 PM
"Dick" wrote in message
corroded and stuck.
Soak (repeatedly) the length of it with WD-40. Then try again.
Old September 19th 05, 11:04 AM
mah
I've had good success on corroded parts using a product called "kroil".
It's a water thin penetrating oil. Not good for long term lubrication,
but it crawls into crevices nicely.
MAH
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 03:36 AM
Stuck Mike Jay Honeck Piloting 34 October 20th 04 04:32 AM
Aluminum hinge VideoFlyer Home Built 2 May 11th 04 08:39 PM
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 02:58 PM
Stuck valve versus plugged injector Viperdoc Owning 6 April 13th 04 12:15 AM
