Ttransponder question #3
Old September 16th 05, 12:45 AM
Andrew Sarangan
Ross Richardson wrote in news:kNkWe.8$F94.5
@dfw-service2.ext.ray.com:
What do you do when requested to "recycle" your transponder?
Cycle it off and then on again.
Old September 16th 05, 01:06 AM
Brien K. Meehan
Put it in the green bin on trash day.
.... after making sure that there's a number 1 or 2 inside a triangle on
the bottom.
Old September 16th 05, 02:01 AM
I was told that was the ATC's way of saying, "Hey...you forgot to switch
your transponder to ALT before you took off!" without embarrassing you.
Old September 16th 05, 02:03 AM
N93332
"Ross Richardson" wrote in message
Reply with 'Can't -- Slash X-Ray!'
Old September 16th 05, 02:08 AM
Jay Masino
Newps wrote:
If the transponder is already warm then it will transmit right away.
It's not a process that has to be repeated because the switch was turned
to STBY and back.
That's true if you go to STBY and back, but not neccessarily true if you
go to OFF and back. I know for a fact that my fairly new KT-76A will stop
replying for 30 seconds if I cycle it to OFF and back, even if it's
already warm. I don't think the transponders actually check for
warmth. They just wait the 30 seconds after each power on from OFF.
--- Jay
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old September 16th 05, 04:25 AM
Mortimer Schnerd, RN
Klein wrote:
Also quickly check your altitude vs your assigned altitude. He may be
given you a very, very nice hint that you're not quite where you're
supposed to be. Most of them aren't this nice (except for Newps).
Yes. You cut off the transponder for a moment, then adjust your altitude. You
have 30 seconds to get to where you're supposed to be. G
VE
Old September 16th 05, 04:27 AM
Newps wrote:
Never ever admit to an altitude bust. When asked to veify your altitude
simply reply back with whatever you were assigned. Then mumble
something about having trouble with this transponder while turning the
mode C off. Return to the proper altitude, turn mode C back on and then
ask ATC..."OK, does it seem to be working now?"
Excellent advice. There are enough ways of hanging yourself without handing
them one on a silver platter.
VE
I want to ask you the most important question of your life. Douglas Olson Owning 1 May 22nd 05 05:15 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
