#11
On Wed, 13 Aug 2003 01:58:48 GMT, "Ernesto Sanchez"
wrote: Do you have any photos yet? Ernesto http://home1.gte.net/res0391z/index.html There are a few photos in the Christavia Yahoo group. I have a few I took of cog and flywheel I'll upload today if I can find the time. Corky Scott |
"Corky Scott" wrote in message ... On 13 Aug 2003 07:38:50 -0400, Gregg Germain wrote: Hey Croky, What airplane is this for? -- --- Gregg "Improvise, adapt, overcome." Smithsonian Center for Astrophysics Phone: (617) 496-1558 A Christavia Mk4. It's a largish four place high wing monoplane with STOL Ahhhh. Swope Farm and Mile Hi Fields beckon. I'm envious, Corky. performance. Empty weight is 1350 and gross wt is 2150. Corky Scott |
Corky Scott wrote:
: On 13 Aug 2003 07:38:50 -0400, Gregg Germain : wrote: :Hey Croky, : : What airplane is this for? : : :-- : : :--- Gregg : "Improvise, adapt, overcome." :Smithsonian Center for Astrophysics :Phone: (617) 496-1558 : : A Christavia Mk4. It's a largish four place high wing monoplane with : STOL performance. Empty weight is 1350 and gross wt is 2150. : Corky Scott Corky, Did a goggle search, saw your web page. Very cool. Good luck with it. --- Gregg "Improvise, adapt, overcome." Smithsonian Center for Astrophysics Phone: (617) 496-1558 ------------ And now a word from our sponsor ---------------------- For a quality mail server, try SurgeMail, easy to install, fast, efficient and reliable. Run a million users on a standard PC running NT or Unix without running out of power, use the best! ---- See http://netwinsite.com/sponsor/sponsor_surgemail.htm ---- |
Barnyard BOb -- wrote: 600 ten thousandths 60 thousandths 6 hundredths .6 tenths.... All the same thing. When talking about inches, all that stuff you wrote equals 60 mils which is a heck of a lot easier to say than "60 thousandths of an inch". Heck, I can't even say the word "thousandths" with any degree of clarity unless I say it really really slow. There ought to be a law against such words. ![]() For the record, one mil = 1/1000 of an inch. And yes, Bob, you are surely correct about the 30 mil overbore and 6 mil piston/cylinder clearance. David O -- http://www.AirplaneZone.com ++++++++++++++++++++++++++++ Indubitably, Dave, indubitably. 8-) Barnyard BOb -- Peter Piper picked a peck of pickled peppers |
Larry Smith wrote:
----snip---- Ahhhh. Swope Farm and Mile Hi Fields beckon. I'm envious, Corky. You're a better man than me. I took a look at the pictures and prose earlier in the thread. Swope farm didn't look too bad since the 134 foot elevation change is worth a little more than 50 knots, by my calculation, that the engine need not contribute; although you'd better be ready when you're ready. On the other hand, I'd rather just watch mile high from a safe distance; or better yet, not in "real time". Peter |
Though "thousandths" is the correct word most of the machinists I've
worked with just say "thousands" -- Bruce A. Frank David O wrote: Barnyard BOb -- wrote: 600 ten thousandths 60 thousandths 6 hundredths .6 tenths.... All the same thing. When talking about inches, all that stuff you wrote equals 60 mils which is a heck of a lot easier to say than "60 thousandths of an inch". Heck, I can't even say the word "thousandths" with any degree of clarity unless I say it really really slow. There ought to be a law against such words. ![]() For the record, one mil = 1/1000 of an inch. And yes, Bob, you are surely correct about the 30 mil overbore and 6 mil piston/cylinder clearance. David O -- http://www.AirplaneZone.com |
"Bruce A. Frank" wrote in message ... Though "thousandths" is the correct word most of the machinists I've worked with just say "thousands" Oddly I always said, "thow" ie. "30 thow" -- .. -- Cheers, Jonathan Lowe modelflyer at antispam dot net Antispam trap in place -- Bruce A. Frank David O wrote: Barnyard BOb -- wrote: 600 ten thousandths 60 thousandths 6 hundredths .6 tenths.... All the same thing. When talking about inches, all that stuff you wrote equals 60 mils which is a heck of a lot easier to say than "60 thousandths of an inch". Heck, I can't even say the word "thousandths" with any degree of clarity unless I say it really really slow. There ought to be a law against such words. ![]() For the record, one mil = 1/1000 of an inch. And yes, Bob, you are surely correct about the 30 mil overbore and 6 mil piston/cylinder clearance. David O -- http://www.AirplaneZone.com |
On Wed, 13 Aug 2003 05:33:03 -0500, Barnyard BOb --
wrote: Could you possibly mean... .028 .030 28 thousandths 30 thousandths Barnyard BOb -- My apologies. I don't use a micrometer much and every time I do I have to study and learn it over and over again. I sympathize, since I did use a micrometer for many years. g [Got that... big mouth Latchless Larry?] I meant to say that the cylinders were rough bored to twenty eight thousandths over, then honed to the final size which incorporated the sixty thousandths piston clearance. If that's .060" clearance, then that's what I meant to say. To throw you another curve.... I'm thinking your piston clearance is really .006 or 6 thousandths. Clare or Bruce may be chiming in on this one. g Standard "rule of thumb" for engines you had no specs for was 2 thou plus 2 thou per inch diameter. Which would be roughly 8 thou. Camground pistons were usually fitted a bit tighter. Like about half or less. Factory spec for a 3.8 is 0.0014 to 0.0028 |
On Tue, 19 Aug 2003 07:23:47 -0400, David O
wrote: "Bruce A. Frank" wrote: Though "thousandths" is the correct word most of the machinists I've worked with just say "thousands" Yes, in the right context "thousands" sounds like a lazy "thousandths" anyway. Given my trouble saying "thousandths", I'll have to remember that. David O -- http://www.AirplaneZone.com Every machinist or mechanic I've ever met just calls them Thous. |
clare @ snyder.on .ca wrote:
Yes, in the right context "thousands" sounds like a lazy "thousandths" anyway. Given my trouble saying "thousandths", I'll have to remember that. David O -- http://www.AirplaneZone.com Every machinist or mechanic I've ever met just calls them Thous. I've heard both used in my somewhat limited exposure to that world. Now if I started saying "thousandths" or "thous" instead of "mils" in my professional work (EE, pc board fab, etc), I'd get strange looks indeed. "Mil" has "of an inch" in the definition which pleases my engineering sensibilities. Along similar lines, before "Hertz" was adopted by SI in the late '60s, most folks just said "kilocycles" instead of "kilocycles per second". Hertz has "per second" as part of its definition which also pleases my engineering sensibilities. A lot of hams, however, were miffed when their beloved "kay cee" was supplanted through a tribute to a dead German physicist. David O -- http://www.AirplaneZone.com |
| Thread Tools | |
| Display Modes | |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Painting is still tough work | Orval Fairbairn | Home Built | 8 | July 23rd 03 05:02 AM |
| Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 09:06 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
