[...] So I guess not all intersections appear on sectionals?
That is correct. Especially those intersections created for the purpose of IFR flight, one may find them only on instrument charts. An example would be an intersection on an instrument approach that defines an altitude step down point on the approach. |
"Newps" wrote in message
news ![]() A small percentage of the intersections appear on the sectional. Looking through http://www.airnav.com/airspace/fix/ shows quite a list of intersections. Most aren't on the sectionals. Are they all on IFR charts? -Greg B. (kinda near MONTZ) |
Mike W. wrote:
And why is it when I file an airway flight plan with AOPA flight planner, it always throws a couple of these in the route? Why not just go from the last VOR direct to your destination airport? Does it assume that I have a GPS with a current database? Or is it assuming that if I am creating an airway route that I am IFR? No, it's because you filed an *airway* plan. It will try to route you via the airways, and most routes involve intersections. Use the "direct" planning option. It will not put in any intersections -- nor will it put in VORs. So, if you want to go from RDU to the Volunteer VOR and then into TYS, you would create a flight plan from KRDU to KTYS and then drag the route over to the VOR on the chart. Or download AirplanLite. I like it a lot better. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Newps wrote:
A small percentage of the intersections appear on the sectional. So here's something I've wondered since I first began IFRing: What makes an intersection worthy of appearance on a VFR chart? - Andrew |
![]() "Paul Tomblin" wrote If you're vfr, nobody cares how you navigate. So you only use the "VFR GPS onboard", if you want to file direct on a IFR flight plan? -- Jim in NC |
N93332 wrote:
"Newps" wrote in message news ![]() A small percentage of the intersections appear on the sectional. Looking through http://www.airnav.com/airspace/fix/ shows quite a list of intersections. Most aren't on the sectionals. Are they all on IFR charts? Yes, and even a few more on STARS and SIDS |
On Fri, 16 Sep 2005 22:25:00 -0400, "Mike W."
wrote: For example, just northwest of my home base airport, KOSU, there is an intersection named DIPNE. It is on the V12 airway between the DQN and APE vor's, but it doesn't appear on the sectional. So I guess not all intersections appear on sectionals? Perhaps an IFR point, which by definition would not be on the (VFR) sectional? -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
On Fri, 16 Sep 2005 22:15:46 -0400, "Mike W."
wrote: Yes that is the fastest way. I just have a hard time putting so much trust in one box. Well, you have the chart, and the line you drew on it. That is your backup system (or the primary system in my case, with a handheld GPS). -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
On Sat, 17 Sep 2005 00:11:33 -0400, "Morgans"
wrote: So you only use the "VFR GPS onboard", if you want to file direct on a IFR flight plan? Well, I don't use it at all! -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
Jeez Dan... In a Cub you can't fly direct for more than 30 seconds
anyway... The vortex off a butterfly's wings will alter your 'direct' route... denny |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___gitqexec | Chris W | Piloting | 0 | November 10th 04 12:39 AM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___ gitqexec | Richard Hertz | Piloting | 0 | November 7th 04 11:45 PM |
