Why no new diesel radials?
Old September 20th 05, 03:21 AM
Cy Galley
Why would one ruin a good virgin for oil?
"dje" wrote in message
I think:
SVO = Straight Virgin Oil
B100 = 100% biodeisel
David
What I'd like to see someone work out a new turbine design with an
injector and hot section suitable for running on SVO or B100. Stick
that on a couple of 747's, diesel trains, and cruise liners and you
save thousands of tons of net-CO2 emissions a year.
Mind explaining what SVO and B100 are?
David Johnson
  #32
Old September 20th 05, 05:01 AM
Dan, U.S. Air Force, retired
Because they outlawed sacrificing virgins for oil.
An elderly woman died a virgin, her tombstone reads "returned unopened."
  #35
Old September 21st 05, 03:11 PM
I'd be interested in reading anything on the practice of using diesel
and biodiesel in turbines your refering too. Did you read this
somewhere, or is that from experience? Have you actually heard of
Biodiesel being used in jets? Or is your reference to biodiesel gelling
related to cars?
Regarding Hydraulic lock I was thinking more preventatively. Like going
to the hanger once a week and walking through a few blades regardless
of whether you were actually going flying. Though I would figure at
15/1 it would require much less oil to frag the engine than at 7.5/1.
I'm probably overthinking the problem. Anybody know how the Guiberson
was mounted in the Stuart tank? Was it on it's back or was it mounted
upright like it would be in an airplane?
Shoot. Somebody ought to just take one out and strap it to Beech 18 and
go flying. Then give us all a pilot report to tell us what the the deal
really is. :-)
-Matt
  #37
Old September 22nd 05, 10:01 PM
me
In article FcpYe.269629$tt5.163046@edtnps90, On-Condition wrote:
No doubt, but I think either ratio will suffice as soon as you start,
especially with one of the inertial starters that just won't stop
once engaged. Walking the props used to be mandatory in the military
where even a desk gets a walkaround twice a day ;-)
Just what is an "inertial starter"?
I have seen references to them, mostly in literature about
airplanes built before the 1940s. But I have never seen a
description of one, or an explanation of how it is different
from any other type of starter.
  #38
Old September 22nd 05, 10:51 PM
related to cars?
The first time I heard of biodiesel was in a documentary about some
Halifax buses. They use fisheries byproducts. They have had to deal
with gelling, though Halifax winters are not all that cold.
To get a little OT, there is a lot of neat stuff being done right now
with biomass hydrocarbons. (veggie oil, fish oil etc.) The bugaboo
seems to be injector coking in direct injection engines, though actual
experienced rate of coking from one motor to the next is a point of
huge debate in the alternative fuel crowd these days. Indirect
piston-pump injected engines will apparently run on straight veggie oil
reasonably well with few ill effects or modifications.
These guys are heating the oil and running straight to the motor.
Apparently the added energy causes the long stranded molecules to burn
cleaner which is what averts the coking. I'd be highly interested in
seeing somebody do that with an allison 250 and what the results were.
No knowledge or experience involving biodiesel in turbines, but winter
diesel is/was being used by DHC6's in the artic about half of the time
since turbine fuel is only available at the main bases. Their PT6's
are in fact derated to 600 shp as
suggested
for another airplane type. I never saw any technical documentation
on this, it being common practice.
My point was that diesels start at 15/1 and gas engines are around 7/1
or 8/1 So oil leakage in a diesel should increase cylinder pressure
way faster than it would in a gas engine. For example: an ounce of
excess oil in a gas engine my increase the cylinder pressure by 10% or
so, the same ounce in a diesel of the same displacement would increase
the pressure by much more than 10%. At a higher pressure the mass of
the air displaced by a constant uncompressable volume (the oil)
increases.
Obviously you don't have to fill the cylinder completely with oil to do
a lot of damage. Just increase the pressure in the jug to the point
were rings crack or bolts become fatigued. With the four strokes you
walk the blades, the valves open and the oil that leaked past the lower
rings dribbles into the exhaust stack. With the Zoche there is no
valve, so once oil dribbles into the cylinders past the rings, how do
you get it out? I would guess the only way to clear a lock or to
prevent an over-pressure from a partial hydraulic lock would be to
remove the injector and cycle the engine. Or perhaps the porting design
prevents it? I don't know.
I saw that there is a diesel CH701 flying with the engine out of a
Mercedes Smart. I'd love to read more about that bird but haven't been
able to find any good info.
-Matt
  #39
Old September 22nd 05, 11:09 PM
If memory serves the term refers to wind up starters. If you have
ever seen "The Great Escape" they had one on the airplane James Garner
and Donald Pleasence flew in.
  #40
Old September 22nd 05, 11:17 PM
Bill Daniels
"me" wrote in message
news:OYEYe.4264$yN1.2550@trnddc03...
Inertial Starter: Flywheel spun up by a geared hand crank then clutched to
engine to hopefully start it before all the energy in the flywheel is
consumed - slightly lighter than a battery, generator and electric starter.
Used on airplanes without electrical systems.
Bill Daniels
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Owning 1 January 4th 04 04:04 AM
