Hmm. REALLY not understanding circulation
Old September 19th 05, 06:57 PM
Peter Duniho
"Roger Long" wrote in message
[...] if the stagnation line has moved back under the leading edge, there
can actually be a small bit of flow with a forward motion relative to the
wing. This is very localized and only occurs very near the wing and only
at high angles of attack.
That's what I thought you said. And I think it's the same thing Tony wrote.
A stall warning tab could sense the stagnation line in one of two ways.
It can be blown up and forward by the reversed flow or it can simply be
spring loaded so that the switch is engaged when air flow drops below a
certain point as the stagnation line approaches. I'll confess that I
haven't looked at one closely enough to know which way they are set up.
They may even be different on different aircraft.
I haven't gone around inspecting the electrically operated stall warning
tabs, but all of the ones I've seen (on my own airplane, and on the larger
Cessnas) have been the former: a switch held down simply by gravity (and,
while the airplane is in motion, by the relative wind), blown upward as the
stagnation line moves below it. No springs involved.
Pete
Old September 19th 05, 07:01 PM
George Patterson
That's the way the Maule switch works.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 19th 05, 11:32 PM
xerj
Wow, Todd.
Very, very comprehensive. Thanks a lot for taking the time to step me
through it, and everyone else who did the same. I'm working over the
material, and it is finally starting to make sense.
The lightbulbs are coming on!
Once again, many thanks.
Thanks to all: Jim Weir's - October 2000 (Understanding LED lamp indicators) dwbauer Home Built 5 June 17th 05 06:00 PM
Jim Weir's - October 2000 (Understanding LED lamp indicators - Part II) dwbauer Home Built 4 June 9th 05 11:09 PM
About Acellerated Courses for Private Dudley Henriques Piloting 137 July 22nd 04 04:21 AM
Help understanding how to work with prepreg Chris Home Built 4 April 1st 04 02:13 PM
"Understanding Aircraft Composite Construction" Ernest Christley Home Built 2 July 23rd 03 03:18 AM
