#21
On Mon, 19 Sep 2005 01:12:41 -0700, Ron Wanttaja
wrote: On Mon, 19 Sep 2005 03:47:38 -0400, Roger wrote: On Sun, 18 Sep 2005 23:37:30 -0400, "Gordon Arnaut" wrote: Evan, I don't want to drag this out, I think some good points ahve been made -- however, I don't see why fiberglass airframe construction is going to be less labor-intensive. Once you have the moulds constructed, fiberglass lends itself well to making large compound structures as one piece. There is almost zero opportunity for automation in fiberglass construction, That depends on your thinking. Fiberglass composite also lends itself well to putting pieces together. I dunno, Roger. I've been both to the Glastar factory and the Vans factory. At Vans, a guy feeds a big piece of aluminum into a big CNC machine and Agreed, we'd have to change the way we approach the parts making process particularly with fiberglass, but I think when it comes to mass production much could be automated. OTOH when it comes to mass production, the old automotive approach where one press stamps out a whole bunch of parts ain't a bad way to go. Maybe that was a poor choice of words as I worked in a metal stamping plant many years ago in another life. People left a lot of parts in some of those presses. whango-whango-whango out comes a big pile of RV parts. But then I go see the Glastar's fiberglass fuselage made, and its spray the release agent onto the mold, then the gelcoat, then cut pieces of fiberglass and lay them into the mold, then squeegee on some resin, then apply the foam, then apply another layer Squeegee? They were using really big paint brushes to apply the vinyl ester resin and moving a lot faster than I do. Slop it on, squeegee it out, It's no wonder then have the water line 100 off by only a 1/4 inch on the pilot's side and missed the cut out for the horizontal stab by about three inches on mine. :-)) Looking at the size of one of those fuselage shells, two layers of fiberglass, half inch of foam, and two more layers of fiberglass. Vinyl Ester Resin is not noted for taking a long time to gel and has a notoriously short pot life, unless you work in a refrigerated room. of fiberglass and more resin, etc. etc., lather, rinse, repeat, then let the assembly tie up your every expensive mold while the resin cures. Add heat. It really speeds things up:-)) But, yes, the way we do it now is very time consuming...and expensive. Metal working is a much more mature field while glass/composite is still relatively new. I think "Vans" has done a great deal to speed the production and make the parts go together faster. Speaking of Glasair. I have over 1100 hours into those nice looking parts and they are *almost*, *starting* to look like they *might* be related to an airplane. There's a reason the "jump start" G-III is expensive. sigh. Of course had I started in and kept at it, mine would be flying now, or they'd have fitted me for one of those tight fitting jackets with the long arms that wrap around. The G-III has a lot of possibilities for streamlining the building process and not just by having the factory put a bunch of parts together for the builder. Of course the G-III is one of the most labor intensive kits out there so it has a *lot* of room for streamlining. One time consuming area is the firewall along with the engine mount attach point reinforcements. There are 6 attach points. Between them you are looking at 96 individual lay-ups. Looked to me that manufacturing aircraft parts in fiberglass is a *lot* more effort...though I allow that less-skilled workers can probably be used. I think they were training a new one when they did the shells for mine. As far as skill though, I think the only reason that is possible is the tremendous excess strength built into the designs which make them tolerant of far less than perfect construction technique. After all, I'm building one... OTOH I may never get it finished. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Ron Wanttaja P.S. Wanna hear something *really* scary? My spell checker passed "whango-whango-whango" but hiccuped on "gelcoat." I find mine often fails on relatively common terms. It thinks Gelcoat should be gel-coat.:-)) |
On Mon, 19 Sep 2005 18:43:10 GMT, Evan Carew
wrote: Ron, & yet, when that part comes out of the mold, it is essentially flyable. With the aluminum CNC paradyme, you get predrilled holes in aluminum you then have to bend, & thousands of rivet holes you have to debur. hours, hours, & hours of deburring... Yah, but I've never spent much time "block sanding" on Aluminum airplanes. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Mon, 19 Sep 2005 18:43:10 GMT, Evan Carew wrote:
Ron, & yet, when that part comes out of the mold, it is essentially flyable. With the aluminum CNC paradyme, you get predrilled holes in aluminum you then have to bend, & thousands of rivet holes you have to debur. hours, hours, & hours of deburring... I think deburring isn't quite that much of a time hog. I've never heard an RV or Murphy or Zenith builder complain about the time needed for deburring, while I have heard a lot of whines about sanding from the composite crowd (but many of those are building moldless composites, not molded). If deburring were that much of an impact, outfits like Cessna, Piper, and Boeing would have come up with an alternative 50 years ago. Those rare times where I'm bashing something from aluminum, I just keep an old battery-powered drill handy with a countersink chucked up. Drill the holes, disassemble the part, go zzzz-zzzz-zzzz with the countersink, then start pulling rivets. I think your point is valid in a way, as a metal-airplane builder spends a lot of time assembling the part with clecos, drilling it, disassembling it, deburring it, priming it, RE-assembling it, then driving rivets. But, geeze, 4,000 RV completions. Obviously it isn't that much of a hassle. Ron Wanttaja |
#24
We were talking about an enclosed aircraft with a fiberglass or aluminum
body, 4 stroke engine, and 2 seats with a cruse of ~100 knots. We were? In that case, forget it. You can't sell that for under $60K and make a profit in anything less than quanities of 10,000. Anyway, what's the purpose of that speed? You can't go anywhere anyway. You are limited to daytime flying only, and only in good weather. That's not a practical traveling machine, that's a toy. Er, I just bought mine & even my radio cost ~1k. Portable aviation radios start at $200. And they're not required anyway. See, what we've got here is a mismatch in expectations. LSA's are not supposed to be C-150 lookalikes/workalikes. There's a reason the C-150 and similar modern 2-seat trainers don't fit into the LSA category - they're not supposed to. These are not supposed to be planes that provide utility. They're supposed to be sport aircraft - stuff you fly for the fun of flying. We're not talking aerial Mercedes here - we're talking aerial Harley. So where are they? Where are the UL's and UL trainers being sold as LSA's? When we can make one that sells new for what a Harley costs, we'll be getting somewhere. Michael |
#25
Hello Bill. I hope you know that if you have been denied a medical, you
will probably not be able to get a sport pilot certificate. Anyway, this is what I have been told. Good Luck to you. Ron |
#26
Also, aren't most of these birds made offshore, where labor and parts
are "so much lower than the US?" David M. ls wrote: Gordon Arnaut wrote: I agree. There is probably a very big market of existing pilots who are not airplane owners. I think there are over half a million pilots in the US, but only about half of them own their own airplane. I bet that almost every one of those airplane-less pilots would love to become an owner if it wasn't such a poor value proposition. Notice I'm not saying "if they could afford it." There are a lot of people who could afford to own an airplane but refuse to because it is such poor value that it offends their sensibilities. So they rent instead, or don't even bother flying anymore. I think sportplanes are just the thing for a lot of these people -- a nice little Sunday flyer that is also capable of modest cross-country travel. Cheap to buy and economical to own. Well that was the dream anyway. But with people trying to sell you a $50,000 sportplane for $100,000, you get that same old sinking feeling again and say "why bother?" Regards, Gordon. To my knowledge, when I got my current plane and took my BFR, I was the only functional Sport Pilot in our area (central TX). There may be others by now, but that was back in June, I believe and the rule had been in force since the previous sept. I agree that the bang/buck ratio is the primary difficulty with E/SLSA. Indeed, those manufacturers have a pretty formidable task on their plates - convincing all these pilots to pay 80 grand for $30-40K airplanes and creating an entire industry off doing so. That's a "tough room" for anyone..... Now, going back to the local SP statistics again, I know of zero SLSA that have been bought in the local area. I've not yet seen an ELSA either, and in fact have not even seen a "gELSA" (an uncertificated light plane that doesn't meet part 103 that has been granted an AC under the 'grandfathering' provision good thru 2008). The lion's share are either already certificated light a/c that fit within the SP LSA limitations (champs, and so on) or Exp A/B airplanes that also fit in thos limitations (like my airplane). Well, so far my actual statistic is only one, me, but among the other prospective SP's that I know, the intention is to go the same route. None has any intention of buying an SLSA. So what it really looks like to me is, as a manufacturer, SLSA makes right at 0.00 sense at the current time. You can do a LOT better by simply continuing to make your current kits intended for Exp A/B and selling those to prospective Sport Pilots. Retooling cost == 0.00.... That is apparently exactly what most manufacturers are doing. Those that don't have kits that meet the SP LSA limitations, such as Vans, seem to be toying with the idea of kits only, with ELSA or SLSA far down on the list of priorities. The only cases I can think of where an SLSA would make any sense at all would be rental and training. I think a catch-22 in such a thing has already been noticed by someone in this thread and wrote about it.... And even there, the alternatives still seem to be better, so this isn't going very well either. So I think the task at this point to get something like SLSA to be viable is an onerous one, particularly because only a little research is needed to really discover how much airplane 80 grand can really buy you. For sure, if someone put a gun to my head and made me spend 80 grand of my estate on a flying machine, it dame sure isn't going to be no light sport aircraft. Medical or no, it's going to be an RV 8 or better.... or 3,4 copies of my plane, or... you get the idea.... As I always say, Caveat Emptor..... LS N646F "Jimbob" wrote in message ... On Sat, 17 Sep 2005 23:19:54 GMT, "Lakeview Bill" wrote: Start with this: How many people do you know who own a $45,000 SUV? Light Sport Aircraft are not intended for people who are already pilots. The whole purpose of the Light Sport Certificate is to draw new people, along with new money, into the sport side of aviation. Maybe, but the bright businessman would understand that existing pilots are a far more readily available source of funds until the sportpilots start rolling in. I live in charlotte, #25 in city size and North Carolina was the birth of powered flight. I don't know of ANYONE who is offering sportpilot. And the planes are selling now. Ergo, who are they selling to? In reality, I see SP as a bust until someone gets the price down. The potential market isn't that blame rich. They are upper-middle class. 80K is a lot of scratch. 40-50K is an extra SUV. Jim http://www.unconventional-wisdom.org |
#27
![]() "rons321" wrote in message oups.com... Hello Bill. I hope you know that if you have been denied a medical, you will probably not be able to get a sport pilot certificate. Anyway, this is what I have been told. Good Luck to you. Ron, if you were denied one time, and are able to get the medical back again, that is all that counts. You can get it back, and not try to get it again, then you can do the sport plane flying. No problem; just don't get turned down, -then- try to fly under sport rules. Clear? -- Jim in NC |
#28
On Mon, 19 Sep 2005 10:37:16 -0400, "Gordon Arnaut"
wrote: Ron, That's a good comparison. A Glasair or Lancair kit costs about double what a Van's kit costs and it still takes about the same build time to complete. In fact even the Van's quick-build costs less than a Glasair slow-build and you get probably less than half the build time. Ahhh... The Glasair takes a *lot* longer in build time. You are looking at 4000 plus hours for a G-III or Super II. And what if the Van's kit were designed to be built with pulled rivets? This would cut build time dramatically and that slow-build kit could be built in about the same time it takes to build one of the composite fast-build kits that cost three times as much. I think the Vans series are faster, more powerful, and more highly stressed than the Zenith. It's kinda like apples and oranges. Look at the Zenith 601, and compare its price to some of the sportplane composite kits. The composte kits are usually twice as much money. There are a few planes out there designed around the simplicity of construction with build times on the order of 500 or so hours. OTOH I understand the Jabaru has a relatively short build time and is a combination of composite and metal. The conclusion has to be that composites are more expensive because it costs more to make them. No question about it, composite construction involves lots of hands-on labor. The way we do it now certainly takes a lot of labor. But the way the parts are made, the individual lay-ups, there is a lot of room for simplification (speeding up the construction). Even die cut foam for the bulkheads and firewall would reduce the build time and increase the accuracy. Also composite materials are expensive compared to aluminum. So if there is no advantage in labor costs and material costs are higher, how does composite make sense for a cheap airplane? It doesn't. Again, were we to use a couple layers of fiberglass over a steel tube frame it would be much faster and easier and a lot cheaper than the advanced composite. . When you get into the advanced composite using layers of fiberglass, foam, more fiberglass and resin it can get complicated and messy. In addition, if you've ever worked with fiberglass cloth cut on the 45 degree bias the stuff is like working with a bucket full of worms. You need an outline or form to which it needs to be fitted. Draw the shape on the cloth, cut on the line and then when you wet it with resin fit it to a shape where it goes. The stuff can easily change length and width by as much as 30%. Of course when cut on the 90 or 0 bias the stuff has a tendency to come unraveled with loose threads all over the place. On top of that the thickness varies. The leading edge of the horizontal stab is made up of at least 6 layers of roughly 16 pieces. The are about 2 1/2 inches wide, various lengths, and the ends are cut on a 45. Even with care a straight edge along the leading edge shows many variations, so you fill and sand, fill and sand, fill and sand... Prepreg OTOH costs more, but the thickness is uniform, it uses a minimum of resin, and holds its shape. It doesn't have that annoying tendency to come unraveled either. If you want expensive, the horizontal stab is constructed using foam and carbon fiber. Look that stuff up by the cost per yard:-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Regards, Gordon. "Ron Wanttaja" wrote in message .. . On Mon, 19 Sep 2005 03:47:38 -0400, Roger wrote: On Sun, 18 Sep 2005 23:37:30 -0400, "Gordon Arnaut" wrote: Evan, I don't want to drag this out, I think some good points ahve been made -- however, I don't see why fiberglass airframe construction is going to be less labor-intensive. Once you have the moulds constructed, fiberglass lends itself well to making large compound structures as one piece. There is almost zero opportunity for automation in fiberglass construction, That depends on your thinking. Fiberglass composite also lends itself well to putting pieces together. I dunno, Roger. I've been both to the Glastar factory and the Vans factory. At Vans, a guy feeds a big piece of aluminum into a big CNC machine and whango-whango-whango out comes a big pile of RV parts. But then I go see the Glastar's fiberglass fuselage made, and its spray the release agent onto the mold, then the gelcoat, then cut pieces of fiberglass and lay them into the mold, then squeegee on some resin, then apply the foam, then apply another layer of fiberglass and more resin, etc. etc., lather, rinse, repeat, then let the assembly tie up your every expensive mold while the resin cures. Looked to me that manufacturing aircraft parts in fiberglass is a *lot* more effort...though I allow that less-skilled workers can probably be used. Ron Wanttaja P.S. Wanna hear something *really* scary? My spell checker passed "whango-whango-whango" but hiccuped on "gelcoat." |
#29
Just the labor.
AINut wrote: Also, aren't most of these birds made offshore, where labor and parts are "so much lower than the US?" David M. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Could it happen he The High Cost of Operating in Europe | Larry Dighera | Piloting | 5 | July 14th 03 02:34 AM |
