A320 with gear problem over LA
Old September 22nd 05, 01:58 AM
Zulu
Anything of interest heard on Live ATC? I can't connect. Too busy.
Mostly routine, along with a few questions to ATC about how much longer
until 292 tries to land and everybody can get back to their regularly
scheduled lives. Sounds like airport ops are continuing normally until
they're ready to land.
Old September 22nd 05, 02:02 AM
Bucky
Another bit of info is that there are about 140 passengers aboard. Poor
passengers, had to ride for about 3 hrs, must be so stressful.
Old September 22nd 05, 02:07 AM
Bucky
Kev wrote:
Aha. Thanks so much! It never hit me that dumping fuel would be
related to a climb requirement.
Can you explain to a layperson how the climb requirement factors into
whether it is necessary to have a fuel dump function? Couldn't quite
understand the rule.
Old September 22nd 05, 02:09 AM
Skywise
"Zulu" wrote in news:IknYe.21672$h02.17700
@tornado.texas.rr.com:
Thank you. I might try to grab the archives later on.
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Sed quis custodiet ipsos Custodes?
Old September 22nd 05, 02:10 AM
Larry Dighera
On Thu, 22 Sep 2005 00:50:48 -0000, Skywise
wrote in
I'll bet the Aircraft Communication Addressing & Reporting System
(ACARS) traffic is more interesting.
Old September 22nd 05, 02:24 AM
Kyle Boatright
"Bucky" wrote in message
Sure. If the aircraft loses an engine immediately following takeoff, it
still needs to meet minimum climb performance standards so it can clear
whatever obstacles it may encounter near the the airport. It is conceivable
that if an airplane (particularly a twin engine aircraft) loses an engine,
it may need to reduce weight to meet climb standards. Dumping fuel is the
easiest way to quickly reduce weight...
Old September 22nd 05, 02:29 AM
Kev
Yay!
Beautiful job of holding off the gear as long as possible.
The fire was a surprise, although it shouldn't have been. MSNBC had a
pilot on, who'd had the same problem on a different airplane, and his
also skidded down the runway, but he didn't mention flames.
Some mention of the fact that the pilot pretty much kept the airliner
on the centerline... which of course probably doesn't please LAX's
runway maintenance guy grin, who might have to repaint it.
Old September 22nd 05, 02:46 AM
"I just want to let you know.....We're all counting on you."
Old September 22nd 05, 02:58 AM
Jay Beckman
"Surely you must be joking..."
Yet another alternator problem Chris Kennedy Owning 7 July 16th 04 04:28 PM
Nose gear failure Greg Esres Owning 12 April 20th 04 11:03 PM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 05:29 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Landing gear door operation Elliot Wilen Naval Aviation 11 July 7th 03 03:47 PM
