Flight Level and a half
Old September 24th 05, 03:02 PM
Newps
Paul Tomblin wrote:
You can't do VFR OTP in class A? I didn't know that.
If you want to be OTP in class A you get a block altitude and fly in the
middle.
Old September 24th 05, 04:12 PM
Steven P. McNicoll
"Paul Tomblin" wrote in message
You can't do VFR OTP in class A? I didn't know that. I assumed that
since it was still an IFR clearance, it was still valid. Not that flight
level rules are likely to apply to me any time soon.
FAA Order 7110.65P Air Traffic Control
Chapter 7. Visual
Section 1. General
7-1-1. CLASS A AIRSPACE RESTRICTIONS
Do not apply visual separation or issue VFR or "VFR-on-top" clearances in
Class A airspace.
Old September 24th 05, 04:13 PM
Steven P. McNicoll
"Newps" wrote in message
middle.
Or at the upper or lower limit of the block or anywhere between them.
Old September 24th 05, 04:43 PM
Mark Hansen
On 9/23/2005 4:13 PM, Blanche wrote:
Uh....if you're between 18K and 60K in the US, then you are required
to be on an IFR flight plan, hence only at even number altitudes.
33,500 is inappropriate.
Actually, while in controlled airspace you are required to fly at
the altitude assigned by ATC. The odd/even altitudes/levels is only
when outside of controlled airspace.
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old September 24th 05, 05:43 PM
Matt Barrow
middle.
Not in Class A, you can't.
Old September 24th 05, 05:51 PM
Steven P. McNicoll
"Matt Barrow" wrote in message
Why can't you get a block altitude and fly in the middle of it in Class A
airspace?
Old September 24th 05, 05:58 PM
Newps
middle.
You most certainly can.
  #28
Old September 24th 05, 06:40 PM
Matt Barrow
middle.
Well knock me over with a feather!!
Above 18,000 feet, where the separation is 1000 feet and AFAIK, VFR
operations are definitely NOT allowed? The example given was 33,500
feet...RVSM air space.
Could you 'splain that one?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #29
Old September 24th 05, 06:47 PM
Steven P. McNicoll
Block altitude. "Maintain block FL 330 through FL 350". You can operate at
any altitude within that block and have vertical separation from traffic at
FL 320 and FL 360.
  #30
Old September 24th 05, 07:21 PM
Newps
The separation is a minimum of 1000 feet, no reason I can't just give
you more airspace.
and AFAIK, VFR
You won't be given an OTP clearance but then at 330 you wouldn't need
that since you're hard pressed to find many clouds up there that aren't
already thunderstorms.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
