#111
Awesome job. A soft and smooth as you could hope for.
No argument - I saw it live, and it was perfect. Touched down short, kept the nose up as long as possible, lowered it gently, tracked centerline through the whole rollout. But honestly - would you expect any less? A control problem on rollout might be a challenge to a low time pilot, but these guys have thousands of hours. They know exactly what's coming. I would have been surprised had I seen anything less. A few months ago, I had a guy flying with me - a friend of a friend - in my Twin Comanche. I won't say it's a difficult airplane, but everyone else who has ever tried to fly it in IMC (or even under the hood) had a difficult time with it the first time around. This includes CFII/MEI's who were instrument and multiengine current including one who was a Cessna 310 owner. This guy just took the controls and within seconds he was doing as well as I could - maybe better - and I have nearly a thousand hours in that one airplane. His flying was smooth, controlled, precise - and effortless. Just like what we saw on TV. He was a captain for a major airline. They can pretty much ALL fly that way, excepting the ocasional screwup. They've all had thousands of hours to practice. Michael |
#112
"Michael" wrote
He was a captain for a major airline. They can pretty much ALL fly that way, excepting the ocasional screwup. They've all had thousands of hours to practice. Why, thank you Michael! Bob Moore PanAm (retired) |
#113
![]() you are clueless moron. Of course, I already knew that from your many (far too many) prior posts. - -- IYNH -- - If you're only going to post here to berate everyone and do it anonymously, don't post. Ah, don't worry about guys like him, Greg. I always just assume they were abused as children... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#114
"Matt Whiting" wrote in
Both are irrelevant. You use brakes during a soft field landing unless conditions, rare conditions, prohibit them. Just the opposite. You don't use the brakes during a soft field landing unless rare conditions require them. You typically will have all of the deceleration you need from the drag of the wheels in the soft field. Your practical experience doing this is? What's the length of the field? Again, *most* of them are short (2500'). And most turf strips are firm most of the time. moo |
#115
"Matt Whiting" wrote in message
Turf field landings are soft field landings. Don't forget about gopher holes. You were taught that a turf field landing is not a soft field landing? Yes, I was taught to make normal full-stall landings on the grass at the field where I learned to fly. N38 at that time had both asphalt and grass and we used the grass most of the time as the airport owner, instructor, A&P and DE didn't want to wear his tires out any faster than necessary. If the field was dry and the grass properly mowed, there was absolutely no reason to use soft-field technique on the grass. Except for the gopher holes. I believe you. But I suspect that the majority of instructors would classify a turf landing as a soft field landing. And how would a flight test examiner look at it? moo |
#116
Have you had this reading comprehension problem long? He said soft field, not short field. And he didn't touch the brakes, he didn't say the plane wouldn't slow down due to drag from the soft field. And I didn't say "short field landing". I pointed out that most soft field landing are made on short fields. (And short field technique isn't appropriate.) If you interpreted my post some other way, then you have the comprehension problem. So rain and snow only fall on short runways? Wow, I never know that before. Most soft field landings are made on short fields. Are you disagreeing with this assertion or just desperate to find some way to argue about it? moo |
#117
That doesn't make using the brakes a soft field technique. It is a short field technique. Oh please. It's part of almost every landing technique. The key word is almost and the exception is soft field landings where the use of the brakes is almost never necessary and almost always harmful. Except when they're made on the turf strip *you* land on, right? Then they're short field landings. Do I have this correct? You want to try this on a flight test? moo |
#118
"Newps" wrote in
Turf field landings are soft field landings. Only if you've never been there before. Don't forget about gopher holes. You were taught that a turf field landing is not a soft field landing? It might be. I know of about 50 grass strips here in my local area. Landed on all of them. Unless they are wet because of a recent rain then they aren't soft fields. There's no gopher holes. On landing I brake as necessary for runway length or other operational concern. On takeoff I will get the nose light, but not off the ground, so the strut doesn't hammer up and down on the rough ones So it is a soft field but it isn't. And you lighten the nose on takeoff but not on landing because something different is happening with the relationship between the nose wheel and those "rough ones" during the landing roll. And you are certain that there are no gopher holes because you've been there before. Do I have this right? You want to use this logic on a flight test? moo |
#119
"Happy Dog" wrote in
: But I suspect that the majority of instructors would classify a turf landing as a soft field landing. Not I, and I have been CFIing since 1970. Bob Moore ATP CFI PanAm (retired) |
#120
![]() "Bob Moore" wrote in message . 121... "Happy Dog" wrote in : But I suspect that the majority of instructors would classify a turf landing as a soft field landing. Not I, and I have been CFIing since 1970. Interesting. moo |
Yet another alternator problem | Chris Kennedy | Owning | 7 | July 16th 04 04:28 PM |
Nose gear failure | Greg Esres | Owning | 12 | April 20th 04 11:03 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Naval Aviation | 11 | July 7th 03 03:47 PM |
