I'm looking for an "express" or "sock" style canopy cover for my V2C,
for use when I'm gridded in the desert sun. (I don't even know if they exist, as there may be an issue with closing the canopy over a layer of material.) This cover is more intended for sun screen than canopy protection. I'm also looking for a new "factory" style (heavy dudy) cover to use for overnight tie-downs. I don't like the one that came with the glider because it's thin and doesn't seem to provide much protection, and the way it secures with straps that go behind the wing trailing edges (and get caught in the flaperons), under the wings and over the canopy top is a PITA. Advance thanks -ted/2NO p.s. the S-H rep gave me Iris S's contact info but I have not received a response to the message I left her early last week. I guess she's been busy at New Castle? |
Ted,
If you're trying to keep things cool and want to do so with minimal expense and storage room taken, use my "space blanket" inside sun shield. To make this: Use any space blanket (but the gold ones look cool). Cut a bit large to the approximate dimensions of the inside of your canopy. To do this, one way is to open the canopy, spread the space blanket out over the opening, overlapping the fuselage, then simply close the canopy. Now you can mark around the perimeter with a felt tip. Cut out the sunshield with scissors. On the inside of the canopy frame, place small tabs of Velcro - - the loop side will not grab a cloth while cleaning inside of canopy. Next, attach two hook side tabs to the sunshield, one fore and one aft. Next, reinforce the sunshield by placing larger pieces of white cloth tape on the opposite side of the sunshield film, covering the area where the Velcro tabs are attached. This will prevent the sunshield from tearing, as you grasp the tape reinforced "laminated" area when removing. Repeat, adding two Velcro tabs on each side of the canopy frame along the bottom edge, again one fore and one aft. The resulting sunshield will fold up into just a few inches and will keep the canopy cool. I first heard the basic idea for this from Al Martini - - thanks Al! bumper wrote in message oups.com... I'm looking for an "express" or "sock" style canopy cover for my V2C, for use when I'm gridded in the desert sun. (I don't even know if they exist, as there may be an issue with closing the canopy over a layer of material.) This cover is more intended for sun screen than canopy protection. I'm also looking for a new "factory" style (heavy dudy) cover to use for overnight tie-downs. I don't like the one that came with the glider because it's thin and doesn't seem to provide much protection, and the way it secures with straps that go behind the wing trailing edges (and get caught in the flaperons), under the wings and over the canopy top is a PITA. Advance thanks -ted/2NO p.s. the S-H rep gave me Iris S's contact info but I have not received a response to the message I left her early last week. I guess she's been busy at New Castle? |
Get a car windshield cover of the type that uses a spring steel loop
covered with silvered nylon. Be sure to get the type that has two separate hoops, and not two that are attached. You fold these by twisting the loop and it shrinks down in size to about a dinner plate. Put this on the inside of the canopy using the springiness to press against the plexi just above the canopy rail. Position the front just above the instruments and the rear will be near where your face would be. I've found this covers enough to keep things cool, and in my forward hinged canopy, it even stays put with it open while a breeze blows through. When folded, it fits neatly in the top of my baggage compartment. -Tom |
Franklin Fabrication sells a fitted canopy cover for just this
purpose. It is made of Mylar coated stretch fabric and secures without straps via elastic gathering like a shower cap. Very good heat and sunlight reflection. Quick removal on the grid and easy storage in the glider. Cheryl @ 760) 715-6930 or She has patterns for many sailplanes and I think she is working on one for the Ventus and Discus. |
| Thread Tools | |
| Display Modes | |
| re Canopy Covers | culverflyer | Soaring | 1 | June 29th 05 05:43 AM |
| Canopy Covers | [email protected] | Soaring | 1 | June 29th 05 01:07 AM |
| Canopy crack repair | Pete Brown | Soaring | 0 | May 18th 04 04:09 AM |
| Redundant canopy latching | John | Soaring | 5 | March 16th 04 01:50 PM |
| Canopy and Wing Covers | Reid & Julie Baldwin | Owning | 19 | November 15th 03 01:58 AM |
