#21
Don Hammer wrote
The FAA certification requirement for a fuel dump system is a takeoff weight that is greater than 135% (I think) of the max landing weight. They don't add the complexity and cost of a dump system unless it is required for certification. Don, the rules have changed since you and I flew those old Boeings. :-) Section 25.1001: Fuel jettisoning system. (a) A fuel jettisoning system must be installed on each airplane unless it is shown that the airplane meets the climb requirements of §§25.119 and 25.121(d) at maximum takeoff weight, less the actual or computed weight of fuel necessary for a 15-minute flight comprised of a takeoff, go-around, and landing at the airport of departure with the airplane configuration, speed, power, and thrust the same as that used in meeting the applicable takeoff, approach, and landing climb performance requirements of this part. (b) If a fuel jettisoning system is required it must be capable of jettisoning enough fuel within 15 minutes, starting with the weight given in paragraph (a) of this section, to enable the airplane to meet the climb requirements of §§25.119 and 25.121(d), assuming that the fuel is jettisoned under the conditions, except weight, found least favorable during the flight tests prescribed in paragraph (c) of this section. (f) For turbine engine powered airplanes, means must be provided to prevent jettisoning the fuel in the tanks used for takeoff and landing below the level allowing climb from sea level to 10,000 feet and thereafter allowing 45 minutes cruise at a speed for maximum range. However, if there is an auxiliary control independent of the main jettisoning control, the system may be designed to jettison the remaining fuel by means of the auxiliary jettisoning control. Bob Moore ATP B-707 B-727 PanAm (retired) |
![]() "Robert M. Gary" wrote Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. The plane would be able to land at the weight that it was at, but that would have been two negative things. One, it would have meant extra weight on the already overstressed nose gear. Two, it would have meant a faster landing speed, and faster speed that the nose would have been let down. -- Jim in NC |
![]() "Robert M. Gary" wrote in message ups.com... As to why no provision for fuel dump, I suspect it is a cost driver: Of course, everything is a cost driver. Whether or not to have carpet is a cost decision. The real question is what the benefit side looked like in their cost/benefit talks. Why is dumping fuel needed? It can still climb at engine out with full fuel, no need to dump there. If they can get up, and stay up, no need to dump; they are safe. What in this case? Were they in danger, flying around? No? Why dump, then? Could they have landed immediately, in a case of immediate danger? Absolutely. Still, you are asking. Why would they need to dump? They were in no danger. -- Jim in NC |
![]() "Robert M. Gary" wrote in message oups.com... In the case of the A320, or the 737, they can both land with a full load of fuel. Then why did Jet Blue fly around for 3 hours burning fuel before landing back in LAX? It seems like if there is a real reason to want to burn off fuel there would be a real way to get rid of the fuel. I can dump fuel even in my Mooney. The crew is paid by the hour? |
I'm sure the airlines, EPA, and everyone else would rather the fuel be
burnt as normal rather than dumped into the air and sea. I heard that the environmental impact of dumping fuel is not as bad as it might seem. As the volatile fuel is sprayed into the air it tends to oxidize and the result is similar to burning it in the engine. I am not too sure of this when considering the complex chemistry of turbofan combustion in flight. From the combustion chamber, out the nozzle and through the downwash behind the plane the combustion reaction continues. Dumping fuel sprays it into turbulent air without the initial combustion and expansion so it is likely much different. I was a payload integration engineer in support of the NASA DC-8 (which had the ability to dump of course) on the SUCCESS mission to fly planes behind and around each other to sample the exhaust products and characterize the chemistry. The pilots had to be careful not to get caught in the tip vortex. http://cloud1.arc.nasa.gov/success/d...60418.hil.html In the above photo our engineering group installed the canoe sized instrument fairing on the side of the plane just forward of the aft service door. We also installed the pod under the forward fuselage. As the elevator is tab powered and the fairing is in front of it, we were crossing our fingers during the taxi test and flight test. http://uap-www.nrl.navy.mil/dynamics...s2May1996.html http://raf.atd.ucar.edu/~dcrogers/GRL/grl.html http://cloud1.arc.nasa.gov/success/ James |
If you put a fuel dump system in an airplane that doesn't need it, and it
does an inadvertent dump, who is liable for the subsequent water landing? Seth N8100R "George Patterson" wrote in message news:tbl_e.21584$Fh4.12558@trndny03... Robert M. Gary wrote: Does anyone have any insight into why the A320 isn't able to dump fuel. Because it has no need to. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
On 27-Sep-05 13:29, Robert M. Gary wrote:
Does anyone have any insight into why the A320 isn't able to dump fuel. What factors would go into such a design compromise? -Robert It almost sounds as if you would be believing that Airbus is French. :-) It is not. It is rather a product of an international consortium (British, German, French, Italian) in which French does not have the largest financial stake anyway... The making of an Airbus is literally like the caricature about the bureaucracy in the "United Europe." It is a maze of parts and subcomponent tourism (Super Goopies and Belugas are being used.) For example wings for the A320 are being made in Bremen, Germany. Many wing components come from Britain, after which they ship the wings to Toulouse, France in a Goopy. etc etc. You name it, every Airbus model has its own subdivision of manufacturing sites and different logistics. Thomas |
#28
ThomasH wrote:
The making of an Airbus is literally like the caricature about the bureaucracy in the "United Europe." It is a maze of parts and subcomponent tourism (Super Goopies and Belugas are being used.) For example wings for the A320 are being made in Bremen, Germany. Many wing components come from Britain, after which they ship the wings to Toulouse, France in a Goopy. etc etc. and who makes the nose gear specifically? :-) --Sylvain |
#29
What factors would go into such a design compromise? After listening to you in this thread, I'll bet you're one of those people who thinks its a good idea for ATC to be able to take over flying an airplane in an emergency. |
#30
("Morgans" wrote)
What in this case? Were they in danger, flying around? No? Why dump, then? Could they have landed immediately, in a case of immediate danger? Absolutely. Still, you are asking. Why would they need to dump? They were in no danger. Then why not fly on to London, er...NY? I wonder how far they would have gotten at half speed ...Iowa? Montblack |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
