Crosswind Landings... But airspeed?
Old September 29th 05, 07:21 AM
Jmarc99
Default Crosswind Landings... But airspeed?
After having read all the posts in the previous thread, no one said a word
about de right airspeed to keep along the final approach... whatever this is done
with a sideslip or crabbing.
I am wondering what should be the right airspeed (calculated or not, 1.3 Vs + wind speed)
to get in a crosswind landing.
What about a straight 90 degrees crosswind, or more?
I wouldn't turn back ON the old "Crosswind Landings" thread!
Just wish to talk about the airspeed to get according different wind speeds and gusts!
jmarc
Old September 29th 05, 08:16 AM
Duncan McC
In article , jmarc99
@sympatico.ca says...
There, yer just said it - wind speeds and gusts (namely gusts).
Nothin' to do with crosswinds (same speed applies).
Admittedly, if you're going to take a slightly longer flare (to get
'crossed up' and lined up), one might consider adding an extra knot or
two to allow for that - as well as the extra drag while yer crossed up.
Duncan
Old September 29th 05, 01:25 PM
GSA
I was learnt to adjust the airspeed in the following way:
(normal landing speed 90 kmh)
- when you need to move your stick more than halfway to the left or
right to keep the plane horizontal, you are flying too slow...
- when you try to fly 90 and airspeed is varying between 70 and 110, fly
110, so airspeed will always be more than 90.
Old September 29th 05, 02:10 PM
Bert Willing
Well, I learned that when I need to move the stick out of center to keep the
glider horizontal, something is wrong...
Bert Willing
ASW20 "TW"
"GSA" a écrit dans le message de news:
- when you need to move your stick more than halfway to the left or right
Old September 29th 05, 02:48 PM
Jmarc99
"GSA" wrote in message
l...
I agree with all that, when the wind is straight on the runway!
But, I wander if this is true whatever the wind direction is 90 degrees,
or worst, let say 180 degrees. Is the rule 1,3 Vs + wind speed still right
to use,
when your final is downwind?
jmarc...
Old September 29th 05, 03:38 PM
Nyal Williams
Your aircraft flies through the air; that's aerodynamics.
Neither your wings nor your ASI can identify crosswind
or downwind; tha'ts geography. They connect only at
touchdown
At 14:06 29 September 2005, Jmarc99 wrote:
'GSA' wrote in message
. nl...
way:
70 and 110, fly
the runway!
is 90 degrees,
to use,
jmarc...
Old September 29th 05, 03:39 PM
Nyal Williams
touchdown
. nl...
way:
70 and 110, fly
the runway!
is 90 degrees,
to use,
jmarc...
Old September 29th 05, 08:27 PM
GSA
With crosswind I land with 'crossed' controls, so the stick is out of
the center... but the plane isn't horizontal then, my fault
Old September 29th 05, 08:46 PM
Andy
Beware of flying indicated airspeed during a slipping approach. The
pitot/static system on some giders will give large indicated airspeed
errors when slipping. As an extreme example my ASW-19 read zero
airspeed in a full rudder slip, probably due to the nose pot pitot.
You need to know your glider and fly the appropriate attitude rather
than the ASI.
Andy
Old September 30th 05, 08:12 AM
Bert Willing
With crosswind, I crab and I touch down with crossed controls. Crossed
controls on final means higher stall speed, unreliable ASI readings and is a
nono.
Bert Willing
ASW20 "TW"
the glider horizontal, something is wrong...
With crosswind I land with 'crossed' controls, so the stick is out of the
A new direction for an old thread: Crosswind landings [email protected] Soaring 96 March 4th 05 01:22 AM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
Strong crosswind landings! Toks Desalu Piloting 12 April 19th 04 07:43 PM
