Source of Dacron?
Old September 30th 05, 05:57 AM
Morgans
"Smitty Two" wrote
Around here, the purple stuff is the primer, and the cement itself is
clear.
Go to bigger supply houses, and you will find clear. Many times, the purple
stuff is multi purpose.
Jim in NC
Old October 1st 05, 06:52 AM
Dean A. Scott
Does this stuff "weld/melt" Polyesther the same way it does Polyvinyl Chloride?
Roger on the clear stuff. What about the question above?
Thanks.
Dean A. Scott, mfa
School of Visual Art and Design
southern adventist university
http://www.southern.edu/~dascott
Old October 1st 05, 03:19 PM
Robert Schieck
Ernest Christley wrote:
snip
If you go with an uncertified Dacron, would it be prudent to stick with
the Ceconite or Polyfiber glues, or will the substitutes work for that
as well? A.Spruce has a glue in their catalogue that is described as
water based and non toxic. Having worked with the MEK based stuff while
helping a friend, that sound very appealing.
Some of the ULs mfgs have been using 3M latex bond for putting on the
fabric. I used it in my finished basement in the middle of winter and
you wouldn't know you even had it in the house. The big claim to fame of
this glue is that you aren't suppose to have to rib stitch the fabric to
the ribs (I did).
hth
Rob
Dacron vs. polyfiber etc. Adam Aulick Home Built 5 August 3rd 05 04:25 PM
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 06:39 PM
4130 sheet source Leon McAtee Home Built 7 May 2nd 04 08:29 PM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
Source for copper crush gaskets??? Jim Owning 0 August 22nd 03 06:31 PM
