All this talk about pricing, and speculation about Van's -- now I open
my new issue of the RV-ator newsletter and read that they're working on on the RV-12. OK, so it's not a production unit - you still will have to build it yourself. But, it's going to be a genuine LSA, with 2-place side by side cockpit, Rotax engine, the handling qualities that Dick insists on, and easy construction with a minimum of parts and a minimum of special tools required. Oh yeah - removable wings. Did someone else mention this and I missed it? |
On Wed, 28 Sep 2005 20:18:22 -0700, Smitty Two wrote:
All this talk about pricing, and speculation about Van's -- now I open my new issue of the RV-ator newsletter and read that they're working on on the RV-12. OK, so it's not a production unit - you still will have to build it yourself. But, it's going to be a genuine LSA, with 2-place side by side cockpit, Rotax engine, the handling qualities that Dick insists on, and easy construction with a minimum of parts and a minimum of special tools required. Oh yeah - removable wings. Did someone else mention this and I missed it? Yep. http://www.vansaircraft.com/public/rv-12int.htm That was from a spring issue of the RVator, and there had been talk before that. Of course, the REAL seer of the RAH crowd is John Ousterhout: http://makeashorterlink.com/?D21C122EB Note the date of the posting.... :-) Ron "I hold, in my hand, the last envelope...." Wanttaja |
("Ron Wanttaja" wrote)
[snip] Yep. http://www.vansaircraft.com/public/rv-12int.htm Back in production ...with pre drilled holes! http://www.vansaircraft.com/public/rv-3per.htm Check out the RV-3(B) RV-3 (single seat) is LSA ...oooops, except that it flies too darn fast. Solution: Small diesel? Who cares about weight penalty at this point. We're trying to slow the thing down plus we've got much weight to give (well, some of us anyway). Would a 65-75 hp diesel, swinging a (quiet) 3 bladed wooden prop, get us down to LSA 125 mph -138 mph, while keeping us under 1,320 lbs for a Gross Weight? I think it would. If it's anything like that (135 hp x 2) Diamond D42 Twin Star burning *under* 3 gallons/hour/side at 42% power - cruising at 175 mph ground speed [Diamond website] ... ...I'm guessing that my (LSA) Diesel RV-3B's fuel burn will be in the sub 2.0 gallons/hr range. (More weight savings) 10 gallons = 70 lbs diesel = 5 hours = 650 miles (130 mph) 6 gallons = 42 lbs diesel = 3 hours = 400 miles (133 mph) So, now we wait on the RV-3B's diesel engine. 2 place RV-12? No thanks. I'll wait. Montblack Removable wings on the RV-12 is nice. A single 19-ft RV-3B wing would fit in most garages, plus it's as long as the fuselage - for the trailer. Might be too heavy for one person to handle though. dolly wheels |
Gee...that looks JUST like the zenair 601XL quick build kit...
John |
John T. wrote:
Gee...that looks JUST like the zenair 601XL quick build kit... The same thought crossed my mind, not only for superficial things like the layout and engine but details like choice of pulled rivets. Similar technology + similar problems = similar solutions. Sort of a recurring theme in aviation. |
Kinda, but then again the previous RV's looked pretty similar to a
601XL too. The RV does not have the all-flying rudder of the 601 though, and if it follows previous pricing models, it will likeley come pre-drilled and at a lower cost than the Zenith quick-build kit. I'm a big fan of the Zenith; I've got a plan set and have *kinda* started scratchbuilding (I sawy *kinda* b/c the only part I've got fabricated so far is the rudder horn ![]() to wait a bit on progressing too far. |
Jim Carriere wrote in news:194f$433d7660
: John T. wrote: Gee...that looks JUST like the zenair 601XL quick build kit... The same thought crossed my mind, not only for superficial things like the layout and engine but details like choice of pulled rivets. Similar technology + similar problems = similar solutions. Sort of a recurring theme in aviation. Yup, the RV-12 will look like a cross between the 601 & a Sonex... With good reason grin. I wonder about the cg issues with the rear mounted fuel tank though (although obviously I trust Van to work that out...) -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
ET wrote:
Jim Carriere wrote in news:194f$433d7660 : John T. wrote: Gee...that looks JUST like the zenair 601XL quick build kit... The same thought crossed my mind, not only for superficial things like the layout and engine but details like choice of pulled rivets. Similar technology + similar problems = similar solutions. Sort of a recurring theme in aviation. Yup, the RV-12 will look like a cross between the 601 & a Sonex... With good reason grin. I wonder about the cg issues with the rear mounted fuel tank though (although obviously I trust Van to work that out...) It can be done. Katanas have a rear gas tank, and IIRC you can spin them in the utility category. I'm talking about the 912 powered version (lightweight engine doesn't help aft cg). I think the 601 and Sonex both have an advantage in simplicity of construction, although I bet that Vans is putting in a lot of development work in that area before the RV-12 is made available. I mean that in the sense that Vans' repuatation and track record to date indicate that the RV-12 won't be a half-hearted design. Tangent... it'd be great if the RV-12 could be flown with the canopy open ![]() |
![]() "ET" wrote I wonder about the cg issues with the rear mounted fuel tank though (although obviously I trust Van to work that out...) Van's spiel said that the cockpit is well forward of his other designs, with the seat being in front of the main spar, instead of on top of it. With the fuel tank just behind the seats, that would put it only slightly behind the CG, so any weight changes during fuel burn would be small, due to such a short moment arm of the tank's contents. That is what it sounds like to me, anyway. -- Jim in NC |
Morgans wrote:
"ET" wrote I wonder about the cg issues with the rear mounted fuel tank though (although obviously I trust Van to work that out...) Van's spiel said that the cockpit is well forward of his other designs, with the seat being in front of the main spar, instead of on top of it. With the fuel tank just behind the seats, that would put it only slightly behind the CG, so any weight changes during fuel burn would be small, due to such a short moment arm of the tank's contents. That is what it sounds like to me, anyway. The Delta has the fuel tank in approximately the same configuration. The downside is that pitch trim will drift somewhat as fuel is burned off. This can be controlled somewhat by the fuel tank design...shaping the tank so that it is larger in the rear than the front. The CG of the tank moves aft as fuel is burned off. It's not a fix, only an improvement over a square tank. The upside is a greatly simplified fuel system. With only one tank, you can throw out a handful of valves and fittings. And you'll never have fuel starvation with a full tank on the other side. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
