#11
![]() "Smitty Two" wrote Around here, the purple stuff is the primer, and the cement itself is clear. Go to bigger supply houses, and you will find clear. Many times, the purple stuff is multi purpose. -- Jim in NC |
Does this stuff "weld/melt" Polyesther the same way it does Polyvinyl Chloride?
Roger on the clear stuff. What about the question above? Thanks. Dean A. Scott, mfa --------------------------------------- School of Visual Art and Design southern adventist university --------------------------------------- http://www.southern.edu/~dascott |
Ernest Christley wrote:
snip If you go with an uncertified Dacron, would it be prudent to stick with the Ceconite or Polyfiber glues, or will the substitutes work for that as well? A.Spruce has a glue in their catalogue that is described as water based and non toxic. Having worked with the MEK based stuff while helping a friend, that sound very appealing. Some of the ULs mfgs have been using 3M latex bond for putting on the fabric. I used it in my finished basement in the middle of winter and you wouldn't know you even had it in the house. The big claim to fame of this glue is that you aren't suppose to have to rib stitch the fabric to the ribs (I did). hth Rob |
Dacron vs. polyfiber etc. | Adam Aulick | Home Built | 5 | August 3rd 05 04:25 PM |
A Remote Compass- java source | [email protected] | General Aviation | 0 | July 3rd 04 06:39 PM |
4130 sheet source | Leon McAtee | Home Built | 7 | May 2nd 04 08:29 PM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
Source for copper crush gaskets??? | Jim | Owning | 0 | August 22nd 03 06:31 PM |
