#51
B. Jensen wrote:
You sound like an EXCELLENT advocate for having the ability to dump fuel too!!! Why are you in such a hurry to dump fuel? Doing that starts to limit your time / options available for trouble shooting the problem and diverting to another airport. The first two memory items on any emergency checklist a 1. FLY THE AIRPLANE 2. DON'T HURRY Dumping fuel violates #2. Besides, IF you really need to land in a hurry, the A320 can do that at any weight. These guys took off for NY with a full load of passengers. That means that they had a lot of fuel onboard and a heavy takeoff weight. To land at that weight would have required a much higher landing speed. Since they had the hydraulics (green system) turned off to the nosewheel steering system, (per emergency checklist) this also reduced their braking ability because this same hydraulic system also controls the #1 engine reverse, and normal braking, i.e. antiskid assisted braking. To me it's perfectly clear, that there was no need for the JetBlue A320 to dump fuel. Burning it was a much better option. But I can still imagine emergencies, where one cannot afford to fly around for several hours, yet still a reduced landing weight, lower than the allowable maximum, and less fuel onboard (the fireball thing ..) would be desireable. Say some sort of fire or smoke developing onboard, for example, like the swissair accident, maybe in combination with some structural damage. I would expect that dumping fuel just before the landing would greatly reduce the risk of a big fireball. However, the question is of course again, how likely is an event like this, where fuel dumping even below max landing weight would be an advantage and what is the cost and weight for the device. regards, Friedrich -- for personal email please remove 'entfernen' from my adress |
#52
Why is barbeque lighter fluid banned in many jurisdictions?
You're kidding, right? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#53
Jay Honeck wrote:
Why is barbeque lighter fluid banned in many jurisdictions? You're kidding, right? California. Aspen also had a shot at it, but I think the law failed to pass. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
#54
You're kidding, right? California. Aspen also had a shot at it, but I think the law failed to pass. Wow. Now I've heard everything. Of course, today I learned that people in the Seattle, WA area cannot smoke cigarettes *outside* in public areas -- which seem to be defined as pretty much anywhere in the city. As much as I hate smoking, that is amazing. Why is it that so many areas of the country that pride themselves as being "liberal" and "free" are neither? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#55
"Jay Honeck" wrote:
Why is barbeque lighter fluid banned in many jurisdictions? You're kidding, right? Partially. As California has tightened up its air pollution regulations for automobiles, it is approaching the point where cars are no longer the major source of air pollution in the Los Angeles area. Other types of pollution are starting to come into the crosshairs of the pollution control districts, including such things as barbeque lighter fluid, paint thinners, dry cleaning fluids, contact cement, and exhaust emissions from small engines used for lawn mowers, leaf blowers, and weed eaters. Of particular concern are what they call Volatile Organic Compounds (VOC) They estimate that something like 400 tons of VOCs are released into the air in the San Francisco Bay area each day, down from 600 tons 15 years ago. (Compare that to the amount of fuel in a fuel dump) As such, there have been a number of proposals to ban things that contain such chemicals outright. In fact, commercial production of chemicals like carbon tetrachloride, trichlorethane, and certain types of Freon have ceased by international agreement. Pressure on the manufacturers has been used instead, so oil-based paints no longer use much xylene or toluene, water-based paints like latex are being pushed more and more, contact cement no longer uses methyl ethyl ketones, ink-jet cartridges use thinners derived from soy, and so on. It extends to barbeque ligher fluids as well. The lighter fluid you get today is not what you got 15 years ago. Most people haven't noticed the difference, but teh fluid no longer contains the traditional chemicals like naptha. Instead, low VOC solvents are used. Getting back to fuel dumping. As the quantities of VOCs from other sources drop to lower levels over time, don't be surprised to see the air pollution regulators focus in on such things as fuel dumping. It will become more and more of an issue if it grows in proportion to other types of VOC emissions. |
#56
"Morgans" wrote:
"James Robinson" wrote In fact, commercial production of chemicals like carbon tetrachloride, trichlorethane, and certain types of Freon have ceased by international agreement. Freon is not a VOC, is it? Certain types of Freon are. Those types are no longer used in new air conditioning or refrigeration systems. Older systems will still have them, but you can't replace lost fluid if you have a leak. |
#57
James Robinson wrote:
Certain types of Freon are. Those types are no longer used in new air conditioning or refrigeration systems. Older systems will still have them, but you can't replace lost fluid if you have a leak. Not with the older type of fluid, but you can replace it with the newer types. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
#58
![]() "James Robinson" wrote In fact, commercial production of chemicals like carbon tetrachloride, trichlorethane, and certain types of Freon have ceased by international agreement. Freon is not a VOC, is it? -- Jim in NC |
#59
"Morgans" wrote:
"James Robinson" wrote Certain types of Freon are. Those types are no longer used in new air conditioning or refrigeration systems. Older systems will still have them, but you can't replace lost fluid if you have a leak. I think you are wrong about that. Sure, they are nasty things, in how they combine in the upper atmosphere to eat ozone, but VOC's are things that burn, and were not burned before they were released, right? Volatile Organic Compounds do not have to burn. They simply evaporate quickly, and can change chemically under the effects of sunlight. It all just has to do with classifications, and I believe Freon is in a different classification. It may simply be classification, but the EPA considers certain types of Freon to be VOCs. Here is a link to a couple of web sites that list VOCs, including various types of Freon as examples: http://www.skcinc.com/cff/1676.pdf http://www.airquality.lanl.gov/pdf/N...dVOCTable3.pdf |
#60
"Morgans" wrote:
"James Robinson" wrote Certain types of Freon are. Those types are no longer used in new air conditioning or refrigeration systems. Older systems will still have them, but you can't replace lost fluid if you have a leak. Where did you hear that? That must have been nonexistium that the AC technician put in my AC at home this spring. G The old stuff is still available, but it costs more than the new stuff, and must be used by licensed tecs, and must be pumped out and recovered when conditions demand that it be removed from the system. I think I heard that the old stuff is not being manufactured anymore, but that the existing stockpiles will last for a few more years, but I'm not at all sure about that. I assumed it was gone by now. They stopped making CFC-12 about 10 years ago, and the only stocks were from what was drained from existing cars, plus whatever stocks where in place when production ended. You can also replace CFC-12 with other types of Freon. (like HFC-134a) The replacements aren't quite as effective in older systems as CFC-12. |
Time, running out of fuel and fuel gauges | Dylan Smith | Piloting | 29 | February 3rd 08 07:04 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
