check brake pressure in pre-landing checklist?
Old October 2nd 05, 08:49 AM
Ray
Default check brake pressure in pre-landing checklist?
I'm reading a book about general aviation safety that I picked up from
the library: "Flight Safety in General Aviation" by R.D. Campbell, 1987.
The book suggests that for planes with hydraulic brake systems you
should always check the brake pressure (by checking the pedal
resistance) as part of the pre-landing checklist. This is not included
in the POH checklist for any of the planes I fly and none of the
instructors I have flown with have every suggested this. But it sounds
like a good idea to me. Does anyone here have a brake check in their
- Ray
Old October 2nd 05, 12:26 PM
Greg Farris
Interesting suggestion.
It happens I just flew a C-172 the other day that had a "soft" right
brake. When I started to taxi I noticed it, and by pumping it a few times
I regained normal pressure. I tested the brakes several times, and
deciding they were OK, I launched. Before landing, I tested the brakes,a
nd the right one had gone comùpletely soft again. I pumped them a few
times, and all was back to normal. Had I not done this, I may have had a
control issue on landing.
G Faris
Old October 2nd 05, 04:41 PM
Doug Carter
On 2005-10-02, Ray wrote:
... The book suggests that for planes with hydraulic brake systems you
I do it now. About a month ago, brakes were fine on taxi out, three
hours later at touchdown and trying too hard to make the first turnoff
(an MD80 was hard on my heels) the right brake was zilch. In my
excitement I put a flat spot on the left tire before figuring out what
what was going on and letting it roll (11k ft. runway
Pumping it got about half the peddle back; would have been nicer to have
done that in the air!
Doug Carter
C82RG, PTS2
Old October 2nd 05, 04:45 PM
Flyingmonk
You "put a flat spot on the left tire"? Surprised you didn't ground
loop...
Old October 2nd 05, 06:55 PM
Ken Reed
It is on the Cirrus pre-landing check list.
KR
Old October 2nd 05, 07:23 PM
Blanche
A brake check is definitely in the checklist for Pipers, immediately
after "start engine". Get rolling a bit, check hand brake and if
installed, check tow brakes.
Old October 2nd 05, 08:45 PM
LWG
I was taught to check brakes as soon as I was slowly rolling forward.
"Ray" wrote in message
I'm reading a book about general aviation safety that I picked up from the
The book suggests that for planes with hydraulic brake systems you should
always check the brake pressure (by checking the pedal resistance) as part
of the pre-landing checklist. This is not included in the POH checklist
for any of the planes I fly and none of the instructors I have flown with
have every suggested this. But it sounds like a good idea to me. Does
anyone here have a brake check in their pre-landing checklist?
- Ray
Old October 2nd 05, 09:18 PM
Ray
I think most people do a brake check as soon as they start the taxi. My
question was how many people do another brake check as part of their
pre-landing checklist. In my limited experience this is far less
common, but it seems like a good idea that doesn't add any siginificant
time or effort to the pre-landing check.
- Ray
Old October 2nd 05, 09:40 PM
Doug Carter
loop...
Yeah, I suspect that when I applied the brakes and the nose came left I
automatically put in full right rudder and didn't get far enough off of
the right brake.
The Skylane RG has smaller tires than the welded gear version, slides
easier to begin with and doesn't take long to mark up the tires.
I mostly fly a Pitts so ground looping something as docile as a Skylane
wasn't too likely (famous last words!
Doug Carter
C82R, PTS2
Old October 2nd 05, 09:47 PM
Marc CYBW
Testing the brakes is on my own 172 pre-landing check list and has been on
all the rental 172s I've flown with 3 different operators.
Marc
- Ray
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 06:49 PM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Full before landing checklist in the pattern? Tony Roberts Piloting 70 November 15th 03 04:50 AM
