#21
![]() "Ron Rosenfeld" wrote in message ... Never mind, I just found 5-4-3b1b. AIM 5-4-3.b.1.(b) states; "If approach course crossing is imminent and the pilot has not been informed that the aircraft will be vectored across the final approach course, the pilot should query the controller." It does not say "the pilot is required to query the controller" or "the pilot must query the controller". Even if it did, the AIM itself says it's nonregulatory. |
In article , David Rind wrote:
I can recall someone on this group once suggesting that if you're past the localizer and concerned that you may be getting close to terrain, and the frequency is too busy to get a word in, that hitting IDENT is likely to cause ATC to notice. Well, if I'm past the localizer and concerned I may be getting close to terrain, then I *will* be turning back to intercept, and the guy sitting in the dark can straighten out any kinks in the traffic flow. I'm assuming your definition of "concerned" means "I know there's a mountain in front of me that's higher than I am." Luckily, we have no actual terrain in Minnesota, though we do have some radio towers that are pretty impressive near the ILS 14 into St. Paul. Even so, they're well below where you ought to be. Out here I've tooled along for what seems like a long time till the controller remembered us, but I've never gotten testy enough to remind them of my existance. If I did it for a living (or we were in bumpier country) I might feel differently.... Hope everyone--pilots, controllers, and others on the group--all have a nice Christmas. Mike Beede |
![]() David Rind wrote: I can recall someone on this group once suggesting that if you're past the localizer and concerned that you may be getting close to terrain, and the frequency is too busy to get a word in, that hitting IDENT is likely to cause ATC to notice. This seems like a bit of an aggressive solution, but I'd guess the controllers would prefer it to someone breaking off from their assigned heading or altitude because of worries about terrain avoidance. Could any of the controllers comment on this? Not aggressive at all and a good idea. |
#24
Newps wrote:
Not aggressive at all and a good idea. NO, it is not a good idea. Read the AIM. He says he was vectored to intercept the localizer. That means new heading or not, he is to intercept the localizer. I don't see what the problem is. If he doesn't intercept, he is not in compliance with his clearance. Period. That's why he was told the purpose of the vector. If he weere given a vector and not told to intercept, then a question might be in order as the aircraft aproaches the course as to whether the controller wants him to intercept or pass thru (not unusual) |
#25
![]() wrote in message ... NO, it is not a good idea. Read the AIM. What's not a good idea? Identing when you can't get ATC's attention on a busy frequency or breaking off from an assigned heading or altitude because of worries about terrain avoidance? He says he was vectored to intercept the localizer. He said; "Several times, while under IFR flight plan and radar services, I have been vectored to intercept the localizer and the controller was late in turning me into the localizer." He was being vectored to the localizer but not yet assigned a heading to join it and instructed to intercept. That means new heading or not, he is to intercept the localizer. I don't see what the problem is. That was good advice you gave earlier; "Read the AIM". Here's what the AIM says about this very situation: AIM 5-4-3.b.1.(b): After release to approach control, aircraft are vectored to the final approach course (ILS, MLS, VOR, ADF, etc.). Radar vectors and altitude or flight levels will be issued as required for spacing and separating aircraft. THEREFORE, PILOTS MUST NOT DEVIATE FROM THE HEADINGS ISSUED BY APPROACH CONTROL. Aircraft will normally be informed when it is necessary to vector across the final approach course for spacing or other reasons. If approach course crossing is imminent and the pilot has not been informed that the aircraft will be vectored across the final approach course, the pilot should query the controller. If he doesn't intercept, he is not in compliance with his clearance. Period. Actually, in this case, he's not in compliance with an ATC instruction if he does intercept. That's why he was told the purpose of the vector. Do you have a reference for that? I thought the primary reason for stating the purpose of the vector, beyond the simple courtesy of keeping the pilot informed, was for potential loss of radio communications. If he weere given a vector and not told to intercept, then a question might be in order as the aircraft aproaches the course as to whether the controller wants him to intercept or pass thru (not unusual) Why would approaching the final approach course without being told to intercept prompt a question if you'd already been told the vector would take you through it? |
#26
#27
#28
The KSNS (Salinas) ILS 31 approach could be a dicey place to get vectored
past the LOC depending on your airspeed and where you are getting vectored to etc. I am sure there are approaches others out there. I have flown this approach in VFR conditions much above the fog layer where I could see the mountains well. It would be prudent to at least slow down in such instances and try to raise ATC asap. "David Rind" wrote in message ... I can recall someone on this group once suggesting that if you're past the localizer and concerned that you may be getting close to terrain, and the frequency is too busy to get a word in, that hitting IDENT is likely to cause ATC to notice. This seems like a bit of an aggressive solution, but I'd guess the controllers would prefer it to someone breaking off from their assigned heading or altitude because of worries about terrain avoidance. Could any of the controllers comment on this? -- David Rind |
#29
That's one of the places that I just wouldn't fly through the localizer
toward the nearby mountains, period. I've done that approach in clear skies also, and if I'm the safety pilot I have the PIC remove the foggles as we near the localizer on a vector so the point is made. "S Narayan" wrote in message ... The KSNS (Salinas) ILS 31 approach could be a dicey place to get vectored past the LOC depending on your airspeed and where you are getting vectored to etc. I am sure there are approaches others out there. I have flown this approach in VFR conditions much above the fog layer where I could see the mountains well. It would be prudent to at least slow down in such instances and try to raise ATC asap. |
Aeronautical Engineering Help needed | Marc A. Lefebvre US-775 | Home Built | 94 | January 11th 04 12:33 PM |
ILS Critical Area signage: Localizer or Glideslope? | Adam K. | Instrument Flight Rules | 4 | October 30th 03 10:09 PM |
Established on the approach - Checkride question | endre | Instrument Flight Rules | 59 | October 6th 03 04:36 PM |
Localizer Back Course vs. ILS | ilsub | Instrument Flight Rules | 8 | August 25th 03 04:04 PM |
