Turbo performance vs non-turbo
Old October 3rd 05, 08:32 PM
John Doe
Default Turbo performance vs non-turbo
Ok, another turbo question:
Can someone please explain to me the performance gain by going above 30" MP
(say, during takeoff) on a turbo'd engine.
How much better performance are you getting from the engine at say 35"MP on
takeoff vs a non-turbo'd engine that's going to max out around 29"?
Is it worth the strain put on the engine? I understand the turbo being able
to maintain power at high altitudes, but I haven't heard it explained to me
why I would need such a high power setting on takeoff/climb (assuming sea
level field).
Old October 3rd 05, 08:59 PM
Newps
Reduce manifold pressure to 23 inches on takeoff and tell me what it
feels like. that's the difference.
Only if you need it.
level field).
For the same reason being able to maintain the sea level power is
desirable, it's more power.
Old October 3rd 05, 09:07 PM
: Can someone please explain to me the performance gain by going above 30" MP
: (say, during takeoff) on a turbo'd engine.
Lots.
: How much better performance are you getting from the engine at say 35"MP on
: takeoff vs a non-turbo'd engine that's going to max out around 29"?
As was mentioned before, try taking off in with a regular engine at less than
full throttle.
: Is it worth the strain put on the engine? I understand the turbo being able
: to maintain power at high altitudes, but I haven't heard it explained to me
: why I would need such a high power setting on takeoff/climb (assuming sea
: level field).
There are two different types of turbo systems. The former that you're
familiar with is a "turbo-normalizer." It allows for sea-level manifold pressure at
altitude. That does not add much more "strain" to the engine, although the inlet air
temperature and cylinder cooling in the thinner air at altitude will still make it run
hotter. That *can* be detrimental to longevity.
The other type is "full-time turbo." With that, the engine is designed to
withstand the additional stress of a larger load of air/fuel per power stroke.
Basically, you get more power per cubic inch of engine. These types tend to run even
hotter than their turbo-normalized siblings since they are producing more power.
Unfortunately, in order to prevent a turbo'd engine from destroying itself due
to detonation, the compression ratio of full-time turbo'd engines must be lowered.
That reduces engine efficiency.
For example, my mechanic's turbo Arrow has an TIO-360 Continental that's rated
at 210hp at something like 35" MP. My carb'd O-360 Lycoming is rated at 180hp. If it
were fuel-injected with angle-valve cylinders, it'd be rated at 200hp. That extra
10hp is all that is gained from 6" more MP because the compression ratio was lowered
from 8.5:1 to 7:1. That's not a tradeoff I would be willing to make for any aircraft
I owned. Turbo-normalized, yes... full-time turbo, I don't think so, but to each
their own.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Robert M. Gary
I live out West were many airways are above 10,000 feet. When I'm at
14,000 in my non-turbo Mooney and only able to pull 18" of power, I can
understand the benefit of a turbo.
-Robert
Old October 3rd 05, 10:33 PM
soxinbox
You should get 35/29 the power.
Subtract a bit from that to account for the increased temperature of the
input air, which is counteracted by an intercooler if you have one.
The horse power increase is minimal, but every bit helps on take off. The
real advantage is flying high. I don't fly over mountains, but I will try to
fly at 14500 on cross countries because the speed gain is so much. On a
standard day my arrow does 150Kts IAS = TAS at sea level. Take it up to
14000 and the TAS goes up to 180Kts and it lets me fly over low clouds
instead of under them.
The trade off in cost is significant. There is not much difference in
initial cost or normal maintenance; It's all in overhaul.
"John Doe" wrote in message
news:2Hf0f.228$L24.111@lakeread01...
Old October 4th 05, 12:30 AM
On Mon, 3 Oct 2005 15:32:04 -0400, "John Doe"
level field).
I'm not sure exactly what you are asking for. If you are taking off @
sea level on a standard day the performance difference between a
turbo-supercharged engine rated @ 300 HP and a normally aspirated
engine rated @ 300 HP is ZERO.
During cruise flight, the performance difference between both engines
at 65% or 75% power is ZERO.
The "better performance" is derived by being able to develop rated TO
power on the turbo-supercharged engine above sea level on a
non-standard day. It also allows you to use cruise power settings at
higher altitudes than a normally-aspirated engine.
As one responder indicated, if your engine is rated @ 300 HP/36"
MAP/2700 RPM, reducing either the MAP or the RPM is reducing the HP
developed.
TC
Old October 4th 05, 02:07 AM
John Doe
MP
on
able
me
level field).
developed.
TC
The previous responder answered my question. You actually have to be at 36"
to get 300HP out of the engine. I wasn't sure how that worked, but the way
he explained it makes sense.
Seems like the turbo-normalized system is a better system.
Either way, it's been good learning....thanks
Old October 4th 05, 03:13 AM
Matt Barrow
MP (say, during takeoff) on a turbo'd engine.
on takeoff vs a non-turbo'd engine that's going to max out around 29"?
able to maintain power at high altitudes, but I haven't heard it explained
to me why I would need such a high power setting on takeoff/climb
(assuming sea level field).
A turbo'ed engine is built more "solidly" than a normally aspirated.
The contrasts/advantages can be learned he
http://www.aopa.org/pilot/bonanza/turbo_primer.html
For example:
"As all pilots are taught, the atmosphere is piled up on the earth's
surface. The weight of the atmosphere is determined by a barometer, or in
airplanes, by the altimeter and the engine manifold pressure gauge. As an
airplane ascends during a climb there is less atmosphere above it so the
weight is less. This is important because it's the weight of the atmosphere
that determines how much ambient air is pushed into the engine during the
intake stroke.
This means that a normally aspirated airplane loses power as it climbs — for
instance, a Cessna 182 engine (a Continental O-470) can no longer deliver
65-percent power above approximately 7,000 feet msl."
and
Advantages
There are a number of advantages. The ability to climb strongly at any
altitude between sea level and 20,000 feet gives the pilot amazing latitude
for operation. First, he can safely operate out West, where there are some
tall mountains. For instance, .the MEA (minimum en route altitude) between
Portland, Oregon, and Yakima, Washington, is 14,500 feet. A normally
aspirated airplane would not have much, if any, climb ability at that
altitude — the turbonormalized (and the turbocharged) airplane could easily
climb up there, and could climb smartly over most weather. The pilot also
can comfortably operate at altitudes that are too high for normally
aspirated airplanes and too low for economical operation of turbine
airplanes — generally this is the 10,000- to 14,000-msl band. This means
less conflicting traffic.
The ability to fly at these altitudes also means the pilot can almost always
find a smooth ride. This makes the airplane more comfortable for squeamish
passengers who interpret every turbulent bump as a nudge from the devil.
The ability to climb strongly means that, should in-flight icing be
encountered, the pilot can usually climb up out of the icing band of
weather. Studies show that the icing band of clouds is generally
approximately 3,000 feet thick. Normally aspirated airplanes that encounter
a quick buildup of ice are often faced with having to descend to avoid the
icing layer, which limits safety options.
Finally, the ability to deliver sea-level power up where the atmosphere is
thin means that the engine can deliver a lot of thrust in a flight regime
where the drag on the airplane is less. Thinner atmosphere = less drag. Less
drag with the same power translates into higher true airspeeds. Tornado
Alley Turbo advertises TAS of more than 200 knots at 18,000 feet. That's
fast."
For sea level and flat landers, there is limited advantage for a turbo,
unless you want to attain high altitudes to climb above weather. For those
of us in the Rocky Mountain west, it's virtually a necessity. People in here
talk about occasionally taking off from high altitude airports (5000 feet on
up); when you do it ALL the times, especially during summer's high density
altitudes, you quickly appreciate it.
Matt
TN Bonanza 36
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old October 4th 05, 03:32 AM
George Patterson
This would not be true of an engine which has had a turbo-charger added, would
it? I see, for example, that the Commander that AOPA is renovating this year
just had a turbo added via STC.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 4th 05, 04:02 AM
Matt Barrow
"George Patterson" wrote in message
news:ZQl0f.5376$MO2.3022@trndny09...
would it?
It would be true for a factory turbo, but not an STC add-on I imagine.
The IO-520 in the Beech F33's is different internally from the TSIO-520 in
the B36-TC. Unfortuantely, it was not ideal, so the best upgrade is the
TNIO-550, especially ones from such engine shops as Superior Airparts or
Western Skyways.
I believe that's a Turbo Alley turbonormalizer, not a Turbo "supercharger".
If not, I suspect the STC might require some "beefing up" of certain parts.
Matt
Matthew W. Barrow
Montrose, CO
Ram Conversion Performance Specs? O. Sami Saydjari Owning 2 May 29th 05 04:37 PM
Why turbo normalizer? Robert M. Gary Piloting 61 May 20th 05 04:33 PM
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Kitfox 7/Rotax 914 Performance Questions Jim Carriere Home Built 2 January 22nd 04 04:55 PM
