Change in AIM wording concerning procedure turn
Old October 4th 05, 05:45 PM
Tim Auckland
On Tue, 04 Oct 2005 08:49:34 -0700, Ron Garret
Tim Auckland wrote:
So, yes, you can do an Immelman if you can keep it within the
parameters mentioned above.
Cool! I've always wanted to try one of those in IMC! ;-)
rg
Don't do it with passengers unless you've got parachutes.
  #82
Old October 4th 05, 05:52 PM
Ron Garret
In article . net,
"Steven P. McNicoll" wrote:
"Ron Garret" wrote in message
In article . net,
I don't see why MENLO..HEMAN should be marked NoPT.
It's marked NoPT to make it clear that you should turn left at HEMAN
instead of right. (Isn't that obvious?)
If you're beginning the
ILS RWY 28R at MENLO you're not going to cross the holding fix DUMBA.
You will if you turn right at HEMAN.
I can't tell if you're joking or not.
I'm not.
Only an idiot would turn right at HEMAN.
Someone might turn right at HEMAN if they thought that 1) the absence of
a "NoPT" designation on the MENLO-HEMAN leg was both correct and
meaningful, and 2) that the AIM's description of the PT as a "required
maneuver" except under specific circumstances was meaningful.
Now, I think that the fact of the matter is that the absence of the NoPT
designation is a mistake, and that that the AIM's use of the phrase
"required maneuver" is meaningless (and no, I'm not joking about that
either). But I don't think that failing to come to those conclusions
makes someone an idiot.
rg
  #83
Old October 4th 05, 07:43 PM
Steven P. McNicoll
Someone that thinks that is an idiot.
  #84
Old October 4th 05, 07:44 PM
John Clonts
I wouldn't
have cleared them direct MINES, I'd have cleared them direct HCH.
Why?
  #85
Old October 4th 05, 07:59 PM
Steven P. McNicoll
"John Clonts" wrote in message
Why?
Because they asked for the "full VOR/DME 22" approach. Pilots request a
"full" approach when they want to do it on their own navigation, almost
always for training purposes. You can't navigate direct to MINES using VOR,
you've got to go to HCH and fly the feeder route.
  #86
Old October 4th 05, 08:15 PM
John Clonts
VOR,
But the aircraft in question was /G, so he could fly direct MINES. And
MINES is an IAF, so an approach beginning there would be a "full
approach" ???
Thanks,
John
  #87
Old October 4th 05, 08:22 PM
Tim Auckland
Steve,
You might have got an intersting response from the army. Chip's
original post implied they were approaching MINES from the east. HCH
is 27 miles southwet of MINES.
Tim.
On Tue, 04 Oct 2005 18:59:33 GMT, "Steven P. McNicoll"
roups.com...
Why?
  #88
Old October 4th 05, 08:43 PM
Steven P. McNicoll
VOR,
approach" ???
Yes, he could use GPS to fly direct to MINES. But if he wanted to use GPS
why did he ask for the "full VOR/DME 22" approach? Check the plate, there's
a GPS overlay, he could have used GPS exclusively to fly the approach.
Requesting the "full VOR/DME 22" approach suggests the objective of their
navigational exercise was VOR/DME approaches, not GPS approaches.
  #89
Old October 4th 05, 08:48 PM
Steven P. McNicoll
"Tim Auckland" wrote in message
I know that. They also requested to hold at MINES for ten minutes. That
tells me they're not in a hurry. It was clearly a training flight and the
training was to be on VOR approach procedures. They requested the full
VOR/DME approach so I'd give them every bit of it.
  #90
Old October 4th 05, 08:52 PM
Ron Garret
In article et,
OK, if you say so.
rg
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
