B-17s in Pacific during WW2 hypothetical
Old October 5th 05, 08:18 PM
Default B-17s in Pacific during WW2 hypothetical
I'm aware that B-17s attacked Japanese Shipping during WW2
(battle of Midway comes to mind), but that they were way too
high and didn't hit anything.
Speaking hypothetically, would it have radically improved anthing
if the B-17 attacked from a much lower altitude?
I'm thinking that the B-17 was a pretty tough plane, as proven
over bombing raids in Europe. And wonder if it could
survive the AA and CAP that the Japanese put up that so easily
downed the Vindicators? Speed and multiple engines come to
mind.
Still, would bombing accuracy have improved to a point that
hitting a Japanses CV would have been possible.
I have this (crazy?) picture of a B-17 lining up with a Japanese
carrier (lengthwise) and dropping a stick of bombs on it. Wonder
what the spread would be at different speeds and the intervals
between bombs. Thanks, to the SBDs, this was not needed, but
just curious.
Come to think of it, the Carriers would and did perform evasive
movements, so skip that requirement that the B-17 would
line up with the keel of the carriers.
Old October 5th 05, 09:09 PM
Targets moving at 25+ kts. are difficult to hit.
Yes.
mind.
So do 8th AF losses over Europe to flak and fighters.
Of course if the ships are inadequately protected or you can overwhelm
the defenses then you might be able to reprise the fate of HMS PRINCE
OF WALES and REPULSE.
Yes, if you were willing to take the casualties.
just curious.
In horizontal bombing of a moving target you aim your bombs where the
target will be, not where it is. (Query: could the Norden bombsight
factor in target speed, or was it designed to only engage stationary
targets?) The captain of the target is watching the bomber and can
see the release. The ship is also manuevering to deny the bombadier
that nice target line that you desire!
Terminal velocity of the bomb is about 800 ft./sec. (per
naca.larc.nasa.gov/digidoc/report/tr/79/NACA-TR-79.PDF ). So for
every 5000 feet of altitude the bomb has to travel the ship's captain
has about 6.25 sec. to get out of the way. Actually, he has a bit
more because the bomb has to fall some distance to achieve terminal
velocity. Then there's aircraft drift, wind, sea state, etc. to
consider. Not a simple problem, eh? :-)
Ayup. :-)
Here's something to test you math skills:
http://www.saltspring.com/brochmann/...Ball-1.00.html
Bill Kambic
Who was pretty good glide bombing in a Stoof using "Kentucky Windage"!
Old October 5th 05, 10:10 PM
Keith W
Only if the crews were trained appropriately
mind.
Get down low and you are much more vulnerable to
flak
just curious.
I suspect the Nordern bombsight wasnt well suited to hitting
moving targets. RAF coastal command and the Fleet Air Arm
used a special version of the Course-setting Bomb Sight
(the Mark IXC) which had ground speed bars calibrated in knots
and were optimised for lower altitude work.
A better approach was normally to drop the stick at
a relatively shallow angle to the ships course so that
at least one bomb would hit the target.
The Lancaster bomber was designed to be able to
attack in a 30 degree dive and had a bomb bay large
enough to take aerial torpedoes although I dont think
were ever actually carried.
Keith
Old October 6th 05, 03:01 AM
Gord Beaman
"Keith W" wrote:
snip
Keith
Perhaps not in anger but they certainly were carried in practice
runs and in peacetime...we used to drop them (unarmed) from
Lancasters on submarines for ASW practice in the fifties...(mk
43's?). we also dropped live mk54 depth charges from Lancasters
on smoke markers in the same timeframe...
Jeeez, those suckers put up one big geyser of water I'll tell
you...we'd drop one (from about 100 ft) then climb rapidly and
wheel around and watch the entry point near the smoke marker
target...all'd be quiet for a few seconds except for the smoke
and a small white splash point where the charge went in...then,
suddenly a big area of white water would appear, maybe 3-400 feet
across and seconds later a humongous waterspout of solid black
water would shoot straight up from the centre of the white area
maybe 100 feet high...
Spec..frickin..tacular!!..WooHoo!!.
-Gord.
(use gordon in email)
Old October 6th 05, 03:49 AM
In the ETO highlevel bombers occasionally hit ships in harbor. But at
sea the bloody things insist on evading once they see the bombs come
out of the bomb bay. BTW wouldn't an artificial wind input to the
Norden bombsight compensate for ship travel? I know you treat target
motion the same as wind in dive bombing and strafe. However, during the
Bismarck Sea episode low-level skip bombing was murderous in every
sense of the word. There were plenty of medium bombers - mostly B25s
with up to 8 50-cal in the nose for SEAD so the heavies weren't needed.
BTW there is a late book out on the Bismarck Sea Battle (q.v.) so root
it out of your local library - very good read.
Walt BJ
Old October 6th 05, 05:56 AM
Peter Stickney
Yes.
A lesser time of fall, certainly.
There were, apparantly some extreme examples. I've hears stories of
B-17s making night skip-bombing raids on Rabaul Harbor.
mind.
It's a big target, and a head-on run at a ship is a zero deflection
shot by its AA gunners.
overwhelm the defenses then you might be able to reprise the fate of
HMS PRINCE
Most of the damage to Repulse and Prince of Wales was by torpedoes,
IIRC.
just curious.
bombsight factor in target speed, or was it designed to only engage
stationary
The Norden worked by tracking the target - the Bombardier put the
crosshairs on the target, and started tracking it manually (Twist
knobs to keep the crosshairs on target) When the sight was properly
tracking, it would keep the crosshairs on target by itself. When the
appropriate release point was reached, as determined by the
airplane's altitude, speed, attitude, (You could be climbing or
gliding with a Norden, within certain limits) the ambient conditions,
and the bomb's ballistic characteristics as dialed into the sight, it
would automatically release the bombs.
There was a minimum altitude, which was driven by how fast the sights
tracking motors could drive the crosshairs.
So - since you weren't squinting at a spot on the ground, but
tracking the target relative to the bomber, it would compute for a
moving target. The Norden was developed by the Navy, y'know. I
think they had ships in mind. Every Torpedo Bomber could carry one,
for use in their level bombing role (Which they rarely did), and
every Patrol Bomber carried one.
The drawbacks are that if the ship jinks, it screws up the tracking
solution, and you've got to re-synchronize and let the sight settle.
captain
That speed depends on the bomb. It's about right for a GP bomb shape,
but an Armor Piercing Bomb would fall faster.
But you're right - that bomb's falling a long time. It doesn't take
much to make it miss.
Ayup. :-)
Windage"!
The other options are skip bombing (A low fast approach, dropping the
bombs well short, and having them skip off the water into the ship's
side down near the waterline. The problems are that you've got to
fly straight at the target, giving his now highly motivated AA
gunners an easy no-lead shot, and the fact that you and the bomb will
be arriving at the ship at the same time. You can get hot with the
bomb, or, if it fuzes early, it blows up underneath you.
The other option is torpedoes. Army Medium Bombers - the early B-25
and B-26 in particular, could carry torps. The only problem, (Other
than the alien notion that the Army would drop torpedoes) was that
those airplanes really didn't like to slow down to the roughly 90 Kt
airspeed that was necessary to keep the torpedo from breaking up.
Pete Stickney
Java Man knew nothing about coffee.
Old October 6th 05, 08:26 AM
Geoffrey Sinclair
wrote in message .com...
Yes. The problem for the bombers is the similarly radical improvement
in the accuracy of the anti aircraft fire.
At the battle of the Bismarck Sea the Japanese force was 8 destroyers
and 8 transports.
On day 1 the B-17s apparently attacked from 6,500 feet, 2 attacks,
one of 8 the other of 20 B-17s, resulted in the sinking of one transport.
It would appear the smaller strike scored the hit(s). The Japanese
account says the height of the strike that sank the transport was 9,000 feet.
The next day the B-17s were "bombing from medium altitude (about
7,000 feet)" according to the RAAF account. The results of these
strikes are not easily distinguishable from the near simultaneous low
level attacks by Beaufighters, A-20s and B-25s.
Overall result 4 destroyers and 8 transports sunk, including a transport
finished off by PT boats and a destroyer finished off the third day.
Around twenty 20mm hits to bring down versus 2 to 3 German 30mm hits.
The light AA gun on the IJN ships was a 25mm piece in a triple mount.
mind.
The B-17s would have survived air attacks better, the simple reality
a bigger aircraft is normally harder to shoot down. The Vindicators
needed to keep their speed down during their glide bombing attack.
The trade off is the improved accuracy of the anti aircraft fire
and greater ease of interception by defending fighters.
This requires some co-operation by the carrier, given the sensible
thing is for it to be continually changing course making it hard to
line up.
Wonder
just curious.
Simply put the higher the speed the greater the spread between
the bombs and the higher the errors.
The tactical diameter of the USS Enterprise, CV-6, is given as
790 yards at 30 knots, or a circle around 2.25 nautical miles,
traversed in 4.5 minutes or a course change of around 80
degrees per minute, while moving 500 yards per minute. A
4 mile bomb run at 240 mph will take 1 minute.
Geoffrey Sinclair
Remove the nb for email.
Old October 6th 05, 09:55 AM
Keith W
"Gord Beaman" wrote in message
"Keith W" wrote:
snip
Keith
Thanks Gord I forgot that the Canadians used them for ASW.
The original spec issued by the Air Ministry envisage them
being used against surface ships.
Imagine doing a torpedo run against the Bismarck in a Lancaster !
Sounds fun
Keith
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old October 6th 05, 11:29 AM
On Thu, 06 Oct 2005 00:56:43 -0400, Peter Stickney
snipped for brevity here and there
HMS PRINCE
IIRC.
You might be right. Of course, the torpedo bombers at Midway suffered
massive casualties because the targets were well protected by fighters
and motivated AA crews. If you can split the defense using a "HI-LO"
sort of attack (which was the tactic, IIRC) then your torpedo aircraft
might fare better.
Thanks for info on the Norden. I was not aware of its roots.
captain
IIRC an AP has to hit a solid target to detonate. A GP bomb would
often detonate at water entry, or could be fitted with a shallow depth
fuse (I don't know if an AP bomb could be similarly fitted). While a
hit is better than a miss, a near miss by a large GP bomb can still
cause significant damage to a ship by weakening or opening seams.
Multiple near misses can be fatal.
Ayup. :-)
Windage"!
Skip bombing was widely used against merchant targets, but it's more
problematical against a warship due to the volume of AA fire the crew
faces. I see it as VERY costly against a high value military target
surrounded by a screen of escorts in an AA formation.
Skip bombing and torpedo attacks have the same difficulty: you have to
get in close to the target, slow and at low altititude. Against
merchant ships this is a doable thing. Against a properly protected
high value target you will loose a LOT of aircraft (a la Midway).
Bill Kambic
Old October 6th 05, 12:35 PM
Guy Alcala
HMS PRINCE
IIRC.
You might be right.
He is. All the significant damage was due to torps. IIRR Repulse suffered
either one or two hits by 250kg.bombs, but the damage was relatively minor.
It was the five torp hits that sank her, and the 7 or so (and no bomb hits
IIRC) that did for PoW.
snip
For a history of the Norden as well as most other pre-war US (and allied)
bombsights, see "America's Pursuit of Precision Bombing, 1910-1945", by
Stephen L. McFarland. The book includes details of how it worked, the
political fight between the navy and the Army over control of production
and access to it, development and production issues, German pre-war
espionage that rendered moot most of the elaborate wartime security
measures (they had a similar tachymetric bombsight of their own), accuracy
achieved in test and combat, statistical studies of the factors that
degraded accuracy, and so on.
snip
Guy
GlobalFlyer -- Pacific Jet Stream Charts? Montblack Piloting 10 March 3rd 05 10:10 AM
Transient visit to the Pacific Northwest sprack Piloting 5 May 5th 04 05:57 AM
Modern day propeller fighter - hypothetical Nev Military Aviation 38 December 6th 03 05:39 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
Attn: Garmin GPS Users with Pacific International Databases - We need your help! Colin Southern Piloting 0 October 29th 03 09:57 PM
