#11
Todd ...
Everybody here is trying to tell you the same thing in different words. You have a "I'll just pull wire and everything will be all right" fetish. Get over it. "Bad wires" have about as much chance for failure as "bad bolts". My advice is to tune in a constant signal ... like an atis or awos and start moving things around briskly. When the signal fails or comes back after failure repeat the jiggle. Narrow down the jiggle area. Jim I'm considering opening all of the intercom jacks (two in front and two in back) and visually inspecting the connectors and wires there too, just for grins. I'll pull new wire for them, if I have to as well... That's good to know... The RG-58 is much cheaper! |
have a "I'll just pull wire and everything will be all right" fetish. Get over it. "Bad wires" have about as much chance for failure as "bad bolts". Okay, so I hear you... but I think where my fetish lies is not with pulling new wires, but in making sure there is proper seating, in anything and everything I can get to. If what I'm hearing is that Coax and wires will have nothing to do with it, I will move on from that thought. I was thinking corrosion, rust, ??? on a coax connector, or connector anywhere (especially connector tray - radio), for that matter. Even you agreed that replacing the coax "may work" and that I would only be out a couple of bucks, worst case. Your description of cutting the coax at a 45 degree angle led me to think that you might be questioning the coax "connector" to radio or antenna or at least be keeping it on a list of suspects. My advice is to tune in a constant signal ... like an atis or awos and start moving things around briskly. When the signal fails or comes back after failure repeat the jiggle. Narrow down the jiggle area. I've been using the ATIS at SAC as my constant signal, and have been forcefully pressing the radio in and shaking it from side to side to see if I can get it to come in, so much so that the LED's dim on the radio as I'm pushing it in. That's never got reception to come back. As far as other things, which I assume you are talking about wires behind the panel, I can certainly give that a try, once I can figure out how to do that without putting my self into an unintentional unusual attitude. I'm 6'2" and about 2 bucks, so I can barely get behind the panel when the plane is parked safely on the ground, let alone 5000 feet and 100 kts. I REALLY do appreciate all of the input, and am not TRYING to be a knuckle-head about all of this! I'm just trying to interplote the input I am receiving and do things that are within my capabilities. And in this case, my capabilities don't seem to cover a very broad spectrum! Thanks, Todd |
three-eight-hotel wrote:
: Okay, so I hear you... but I think where my fetish lies is not with : pulling new wires, but in making sure there is proper seating, in : anything and everything I can get to. If what I'm hearing is that Coax : and wires will have nothing to do with it, I will move on from that : thought. I was thinking corrosion, rust, ??? on a coax connector, or : connector anywhere (especially connector tray - radio), for that : matter. Even you agreed that replacing the coax "may work" and that I : would only be out a couple of bucks, worst case. Your description of : cutting the coax at a 45 degree angle led me to think that you might be : questioning the coax "connector" to radio or antenna or at least be : keeping it on a list of suspects. Coax isn't all that hard to replace, necessarily... BUT it can be a big pain to route. It goes all the way to the antenna... likely a fairly long way. Soldering the ends on (well) requires a pretty good knowledge of a soldering iron... not just "which end to grab." ![]() start with something else. : My advice is to tune in a constant signal ... like an atis or awos and start : moving things around briskly. When the signal fails or comes back after : failure repeat the jiggle. Narrow down the jiggle area. : I've been using the ATIS at SAC as my constant signal, and have been : forcefully pressing the radio in and shaking it from side to side to : see if I can get it to come in, so much so that the LED's dim on the : radio as I'm pushing it in. That's never got reception to come back. : As far as other things, which I assume you are talking about wires : behind the panel, I can certainly give that a try, once I can figure : out how to do that without putting my self into an unintentional : unusual attitude. I'm 6'2" and about 2 bucks, so I can barely get : behind the panel when the plane is parked safely on the ground, let : alone 5000 feet and 100 kts. The problem my mechanic's transponder had couldn't be induced by forcing the radio around in the tray. It was a mechanical stop near the connector. Couldn't really make it come and go. Of course it was further complicated by the fact that the only way to check it was to test-fly it and ask local ATC if they could read ModeC (I don't have a transponder interroagtor). For your COM, it should be easier. Just as a thought... have you tried pulling out the squelch when you're unable to receive? If you don't hear static when you can't receive, it's likely in the wiring/connector from the radio/intercom/audiopanel/jacks. If you hear static but you still cannot receive, then it's much more likely the radio. : I REALLY do appreciate all of the input, and am not TRYING to be a : knuckle-head about all of this! I'm just trying to interplote the : input I am receiving and do things that are within my capabilities. : And in this case, my capabilities don't seem to cover a very broad : spectrum! The biggest thing would be to try and make it happen on the ground so that you can troubleshoot it. I'm not familiar with Narco's trays, but on the King ones, the connector can be disconnected from the tray. Then you could play with that without being stuck with the geometry of the tray. Basically, stop at the top and work down... -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() I was thinking corrosion, rust, ??? Rust is iron oxide and will only form on iron or steel. Corrosion is a different matter, but you can rub or spray corrosion off. The only way coax deteriorates is in sunlight or with water inside the shield. Age is a second order factor. on a coax connector, or connector anywhere (especially connector tray - radio), for that matter. Even you agreed that replacing the coax "may work" and that I would only be out a couple of bucks, worst case. Yeah, as well as throwing salt over my left shoulder has kept me from being trampled by hippopotami all my life, but I don't think replacing the salt shaker is going to have any effect. Your description of cutting the coax at a 45 degree angle led me to think that you might be questioning the coax "connector" to radio or antenna or at least be keeping it on a list of suspects. No, I was telling you to do that so the square-cut coax wouldn't hang up on the grommets as you pulled it. My advice is to tune in a constant signal ... like an atis or awos and start moving things around briskly. When the signal fails or comes back after failure repeat the jiggle. Narrow down the jiggle area. I've been using the ATIS at SAC as my constant signal, and have been forcefully pressing the radio in and shaking it from side to side to see if I can get it to come in, so much so that the LED's dim on the radio as I'm pushing it in. Do you intend to destroy your radio in the fixit process? That's never got reception to come back. As far as other things, which I assume you are talking about wires behind the panel, I can certainly give that a try, once I can figure out how to do that without putting my self into an unintentional unusual attitude. I'm 6'2" and about 2 bucks, so I can barely get behind the panel when the plane is parked safely on the ground, let alone 5000 feet and 100 kts. You CANNOT do troubleshooting at 5K and speed. You HAVE to do it on the ground. THe easy way is to pull the front seats out and lay on the floor. I'm 6-3 and two and a quarter, and this is the only way I can troubleshoot any airplane except a heavy with a radio rack in the belly. I REALLY do appreciate all of the input, and am not TRYING to be a knuckle-head about all of this! I'm just trying to interplote the input I am receiving and do things that are within my capabilities. And in this case, my capabilities don't seem to cover a very broad spectrum! You need to get the airplane to a place where you can get at the radio with a constant signal. You also need access to tools and such when you DO find the problem. I think I've got an old com test set around here somewhere that radiates a constant low level signal on 122.8, powered by a 9 volt battery. If you'd like to come up to Grass Valley and borrow it, I'd be glad to loan it to you ... if I can find it. Jim |
Just a (dumb?) question to the OP: Does the radio tray have a BNC connector
for the coax cable connection? Can you try a piece of short coax connected to a 'portable' antenna attached to some type of ground plane? If this setup works, then you'll know it's somewhere in the original coax connections, if the radio still doesn't receive, then it would be a different connection problem. Are you sure the radio itself is good? If you have already tried this, disregard... |
: The weird symptom that goes along with the not receiving is the
loss of : sidetone, when I attempt to xmit. I'm gettting a bit lost in facts and symptoms here. Anyway, we must bypass intercom to isolate to which box. If the Narco, it does not know receive audio from sidetone in the circuit area of interest, if both those signals are absent. There's audio leveling circuitry in there to which both mic audio and receive audio are fed. The nature of that circuit is such that component drift through heat upsets a delicate balance, and there's many analog swith ICs in there to turn things on and off. The fact that you can xmit w/o hearing mic audio I believe may isolate the fault to a certain area of that circuit. If true that it works for a while and then stops, that's gotta be thermal. A wire or coax connection can theoretically behave like that, but airplanes vibrate. The thermal expansion of metal is like what in comparison? The only wire connection for your symptoms should be phone audio out from the comm. The reason I'm leaning in this direction is that there are simpler circuits in comm boxes where all your symptoms could not happen. In the Narco design it can; it's an electronic Rube Goldberg machine. And the only company on earth who still write code for the MK3870 CPU chip. Fred F. |
UPDATE:
Last night, I went up to the airport and pulled out the radio, and pulled the connector tray as far out/forward as I could. I performed a close visual inspection and noticed something that I hadn't noticed before... The radio and connector union seems to be made through two 24 pin connectors and two BNC connectors. The BNC connectors are an opposing male and female (one each on the tray, and one each opposing on the radio). What I noticed (forgive any improper terminology) is, that the male connector on the tray seemed to be missing one tooth (for lack of a better word) on the outer ring of the connector and the radio, seemed to be lacking two teeth, on the outer ring of it's male BNC connector (that's almost half!) Aside from not being a good thing, is this a likely suspect for some of the symptoms I have been experiencing? Replacing those two male BNC connectors would seem like good common sense, but is this just an unfortunate coincidence of something else being found while troubleshooting another problem? Look... I'm admittedly a couple of bricks short of a fireplace, when it comes to talking circuitry and componentry, so no piling on! ;-) I've been paying attention to all of the posts, but alot of it seems to be going over my head. It's not like I'm not listening... I promise, I'm not going to go pulling any wire! I may, however, take you up, Jim, on a trip to Grass Valley to borrow your constant signal device or bird watt meter you mentioned in a previous post. One step at a time, though, I guess... Thanks, Todd |
"three-eight-hotel" wrote:
... the male connector on the tray seemed to be missing one tooth (for lack of a better word) on the outer ring of the connector and the radio, seemed to be lacking two teeth, on the outer ring of it's male BNC connector (that's almost half!) Aside from not being a good thing, is this a likely suspect for some of the symptoms I have been experiencing? .... Whatever's goin' on there will not cause a loss of sidetone. Fred F. |
Yeah... that makes sense. Thanks!
I pulled everything from the stack this weekend and visually inspected everything I could see... As mentioned in a previous response, every single screw, holding in every tray, had a nut on the back of it, and half of them became part of the permanent W/B! I took an air compressor with me, along with the component/connector cleaner and cleaned every connection I could. I'm going to hold off on putting the trays back in and borrow the tools from my mechanic to do it right, rather than figure out how I'm going to hold nuts on the back of trays for each screw. While I was working on this, I ran into someone up at the Ghost-town (err, I mean Georgetown) airport that I haven't seen in a while. He offered to let me swap out and try his audio panel, to see if that might be the culprit! As soon as I get the trays back in place and can reseat all of the avionics devices, I'll give it a quick check flight to see if I can get it to fail again, then try the replacement audio panel. Thanks for all of the responses, and I'll provide an update when I can. Best Regards, Todd |
I will state again, I had very similar problems with my MK12D and it
went back to the factory. It is fixed and working fine. The side tone is a product of the radio not the audio panel. How I isolated it was swapping the two MK12Ds I had and the problem followed the radio. Therefore not in the trays, coax, audio panel, etc. ------------- Regards, Ross C-172F 180HP KSWI three-eight-hotel wrote: I've read your symptoms per your orig post, and you have one odd collection of seemingly mutually-exclusive symptoms. If you can xmit, but not receive, it's not the coax. The weird symptom that goes along with the not receiving is the loss of sidetone, when I attempt to xmit. That's the part that confuses me, and leads me to question whether I can receive or not... Maybe I am receiving, but just can't hear it??? I don't completely understand how the radio, intercom and audio panel all tie together, so I'm confused at the various symptoms I am encountering. i.e. a) clear side-tone when talking over the intercom (no depression of the PTT) and able to talk and listen to passengers. b) obviously clear transmission (pressing PTT) but no sidetone and passenger doesn't hear me either. (I say obviously clear because ATC acknowledged my transmission, which I was able to confirm over a hand-held) c) Not hearing radio calls (confirmed by listening and hearing them on a hand-held). Sidetone is a function of the intercom, is it not? Meaning, if I were to bypass the intercom and plug directly into the aircraft jacks (which I have tried) I would not hear sidetone, when I attempted to transmit. Either way, I was unable to hear known ATC coms while plugged directly into the aircraft jacks. Scratchiness, followed by silence, isn't likely the connector, nor coax. Is that what it still does? It seems the first time it fails, it tends to fade out with scratchiness. The last time I flew, I was able to turn the radio off for a few seconds and turn it back on, to find it working for a minute or two. This worked a few times, but failed to work, at all, the last two times I tried it. The real ****er is that once I get it on the ground, it seems to work fine! It sounds like a thermal fault in the squelch circuitry. Narco uses a large fancy squelch circuit, squelching in 2 different ways and works on a hair trigger. Bad thermal behavior of a component could cause grief. My Narco comm 120 does similar and obviously a thermal, w/o the annunciating scratchiness. Similar circuit; no time to pull and fix in such nice weather yet. I just had the radio in for some questionable repairs at an avionics shop that is a certified Narco dealer. They ran it up on the bench for 4 or 5 hours, and said that everything was within specifications... Is this something a normal bench runup would be able to detect? You can't pull the tray without dealing with the wires at the connector. If you can do that, you can just visually inspect the stuff for integrity. At some point, before my last two flights, I crawled into that wonderful position with my head between the rudder pedals and reached my arm up behind the radio to see if I could feel anything out of the ordinary (like I would know what ordinary felt like!). I grabbed at the cables and wires and performed a wiggle-and-seat manuver for everything I could blindly grab... My following two flights, each nearly two hours, resulted in no radio failures. I was convinced the problem was gone (okay, I was praying that the problem was gone). However, the last two times I flew, it was back... This is when I decided that I might have temporarily fixed something, but that vibration had caught back up with me and undid what I fixed. My hope was that removing and cleaning all connection points and making sure everything is seated snugly when reinstalled, would fix my problem once and for all. The worst case scenario is $20 of coax cable and pulling back bloody stumps when I try to retrieve my arms from behind the panel. If I take it to an avionics shop at this point, I will be looking at a minimum of $300 to troubleshoot, and I have already dumped nearly $600 for a questionable radio repair and a new antenna, while shotgun troubleshooting. For thermal, did you try flying w/o any box above and below the bad one? That's how I know my 120's a thermal glitch. I haven't tried that, but I did fly with a TKM slide-out loaner and encountered a similar failure. I also put my radio in another plane and the pilot reported that it did not fail during a nearly 3 hour flight. Above my radio is the audio panel, and below it is an ADF. The ADF is inop, so I could remove it... Does the radio require the audio panel to be useable in the airplane? Could I pull out the audio panel and ADF, leave the radio in and plug my headsets into the aircraft (non intercom) jacks and be able to xmit/receive? I'm willing to try anything I can, to avoid throwing good money after bad! It would be one thing if I could explain a set of symptoms to an avionics shop and get an estimate to put this issue to bed, but I can't reproduce the issue at will, unless a tech is willing to go flying with me! :-( Per other post, RG-400 will cure anything, nor do much performance-wise at VHF. I don't completely follow this one??? RG-400 is or isn't necessary, as opposed to RG-58? Thanks for taking the time to respond! Todd |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
