Using 100LL in a Rotax 912 Engine
Old August 14th 03, 11:01 PM
Yosimite Sam
Default Using 100LL in a Rotax 912 Engine
I know of several kitfox flyers that use this...It's called TCP here is one
site with some info, but there are quite a few sellers.
http://www.alcorinc.com/DOCS/1/tcp.html
Yosimite Sam
Old August 15th 03, 12:37 AM
Kevin McCue
Be sure that you have the updated gears in the prop reduction. As a result
of the engine oil circulating in the PRSU, there was a service letter about
lead build up on the gears causing spalling when running 100LL.
Kevin McCue
KRYN
'47 Luscombe 8E
Rans S-17 (for sale)
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old August 15th 03, 07:51 AM
Martin Hellman
"Terry Ladouceur" wrote in message . ..
I know that the Rotax 912 is to be run on Mogas but I have heard that there
is a gasoline additive you can purchase that will help reduce the lead build
up when being used in a Rotax 912 Engine. Does anyone on this list know what
this additive is called? Have you used it and what kind of results did you
have? Any negative impact on your engine? Thanks.
A bigger issue may be the impact of Mogas and any possible additives
like TCP on your fuel system. I have fiberglass tanks that are coated
with a 3M slosh compound that dissolves (and gums your carburetors) if
there's any alcohol in the fuel. I know alcohol is a no-no in aviation
fuel anyway, but other owners - even those who checked pretty
carefully - sometimes got alcohol and gummed carbs. Not to mention who
knows what damage to the fuel tanks. There have been other incidents
as well where there is evidence that anything other than 100LL (which
the factory tested extensively on the entire fuel system) may be
causing problems. I'd love to use unleaded fuel and make my engine
last longer, but have decided to stick with 100LL for the above
reasons. Some other owners have opted for Mogas, so it's not like my
decision is clearly the right one. But I thought it was worth
mentioning the issue of fuel system damage.
Good flying to you all,
Martin
Old August 16th 03, 05:00 PM
G.R. Patterson III
Kevin McCue wrote:
Easy to check for alcohol in fuel. Put a small quantity of water in a
jar. add some "suspect" fuel. Cap and shake. Let settle. If water has
disappeared alcohol is likely.
The water will not disappear. Put the water in and mark the level. Then add
the fuel and shake. Let the water settle back out. If the water level is now
higher, there's alcohol in the gas.
George Patterson
Brute force has an elegance all its own.
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 01:04 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 09:06 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
