Picking Optimal Altitudes
Old January 7th 04, 11:23 PM
O. Sami Saydjari
I went to Jeppeson's website and looked up flitestar. Looks like a nice
software package. What I could not find is pricing information for the
software or the subscription service to keep the charts updated and
such. Can you give your view on the software and let us know what it
retails for (including any subscriptions). Thanks.
-Sami
McGregor wrote:
Lazy people (like me) ask their computer. FlightStar from Jepp has an
"optimize altitude" function that is pretty handy. Once it has downloaded
DUATs weather it will display groundspeed and fuel burn for all altitudes
and highlight the optimal flight level.
"O. Sami Saydjari" wrote in message
When planning a flight against the wind, how to you pick the best
altitude when trying to minimize flight time?
If I read my performance charts correctly, my aircraft (Piper Turbo
Arrow III -- service ceiling 20,000 ft) seems to gain about 2 nts of
*true* airspeed for every 1000 feet you go up. Firstly, does that sound
about right to folks? I assume that this effect is from the decrease in
air friction at high altitudes (even though the prop also has less air
to "push on").
So, unless there is some other factor, I think this means that if the
winds increase at anything higher than 2 nts per 1000 feet, I am best
off staying at the Minimum Enroute Altitude. Is that right?
My experience thus far suggests that most of the time, the winds aloft
speed increase far faster then 2 nts per 1000 feet, so, in general, it
is unlikely that I will do much better than staying at the absolute
minimum altitude. Is that consistent with other folks' experience?
-Sami
Old January 7th 04, 11:54 PM
Matthew S. Whiting
to "push on").
-Sami
Yes, generally lower is better in high wind conditions such as winter
across much of the US. However, you need to balance speed against
turbulence which also tends to be worse at low altitudes, at least over
mountainous regions.
Matt
Old January 8th 04, 01:41 AM
O. Sami Saydjari
Stan, It guess I was too lazy to try to compute the flight plan several
different ways. Your note, and one other made me dust off the math
knowledge and do some of that there fancy ciphering (hearing "weeeee
dogies" in the background...said with hillbilly accent, of course).
For a mythical plane that climbs 1000 fpm at 100 nm/hr and cruises at
150 nm/hr and a service ceiling of 20,000 ft. Comparing flight at 1000
ft agl versus 18,000 agl....for a 100nm trip one's tailwind would have
to be about 40nm better at 18,000 compared to 1000 ft. For a trip
distance of 200, the tailwind would only need ot be about 14nm/hr more
favorable. For a 700 mile trip (one that I will be making fairly
often), the winds only need to be about 3nm/hr more favorable.
Now, I just hope the mythical heater is powerful enough so that I do not
freeze my butt off at those altitudes.
-Sami
Stan Prevost wrote:
I generally run several flight plans at different altitudes, accounting for
the differences in true air speed, wind speeds, and time to climb and
descend. More often than not, I find that the extra time to climb uses up
the gains in TAS at altitude, and winds are the only factor that make a
significant difference. If the flight is long, say 3-4 hours, then the
climb can be worth it, but for less than a couple of hours, it usually is
not. I fly behind a turbocharged engine and have built-in oxygen, so I can
go anywhere up to 18-20K, but usually stay below 12K or so unless there is a
net advantage due to wind. I like to stay high enough to keep from having
to switch from centers to approach controls all the time and to get above
the haze layer for a smoother ride. But sometimes the high winds just force
you down into the turbulence and traffic at 3-4K.
Stan
to "push on").
-Sami
Old January 8th 04, 01:58 AM
Jeff
I was thinking real hard about that glide distance the other day flying to
phoenix.
when passing over the colorado river area, I felt my plane kinda "surge", never
felt it before, I thought the engine was surging but didnt see any indications
on any of my instruments. I was looking around for a place to land and 8500 ft
just didnt look high enough at the time.
the trip was unevenful tho, I am thinking it was a gust of wind hitting me from
behind making the plane surge forward for a second.
Wyatt Emmerich wrote:
I travel about 8-10 thousand into the wind and 14-20 with the wind. I agree.
Usually the headwind increases faster than TAS with altitude. I travel 8-10
for safety--glide distance.
"Jeff" wrote in message
when I plan a flight against the wind (like a few days ago comming back
from
phoenix) I go with the altitude that gives me the best ground speed.
On my way back from phoenix at 8500 ft I had a GS of 130 kts, I had to go
to
10500 for terrain and my GS went down to 117 kts., so I jumped back down
to
8500 when I had the chance.
Turbo airplanes take advantage of the thinner air up high is why they can
go
faster then normally aspirated planes. you maintain your full 200 HP up to
a
DA of 12,000 ft. So 12000 ft is where you start to lose horse power but
air is thinner allowing you a better TAS and if you play the winds right,
some really good ground speeds. stay low if you have a head wind, get up
high when you have a tail wind.
Sometimes, the wind down low will be higher then say around 10,000 or
12000
ft or about the same. If there is not much difference in the winds, I
would
select the higher altitude because of the thinnner air. Also you dont use
as
much fuel up high.
to "push on").
-Sami
Old January 8th 04, 02:01 AM
Jeff
I was looking at flight star, is it as good as jepp says it is?
to "push on").
-Sami
: I went to Jeppeson's website and looked up flitestar. Looks like a nice
: software package. What I could not find is pricing information for the
: software or the subscription service to keep the charts updated and
: such. Can you give your view on the software and let us know what it
: retails for (including any subscriptions). Thanks.
For me, personally, I don't run Winders, so any downloadable packages don't
help me. That's why I use DUATS... web-based so it works everywhere. Oh, and it's
"free" (for AOPA members). Me the cheap *******...
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old January 8th 04, 02:14 AM
Dan Truesdell
Altitude is your friend. On the way to OSH last summer, we leveled off
at 10,000' (C172) after leaving BTV. A few minutes later, the engine
developed some serious roughness. It went away when I jammed the
mixture control in and pulled the carb heat. Then it came back. I was
about to declare an emergency when it cleared up for good. (I believe
that I had some water in the fuel that didn't hit the port until we were
in level cruise.) An event like that will certainly make you sit up
straight and start looking (my "copilot" had VERY wide eyes for a few
minutes). But at 10,000' (and my trusty handheld GPS), I had a couple
of airports within gliding distance (and lots of recently mowed hay
fields) to choose from. The remainder of the trip was uneventful (other
than the 2-day layover in Dayton to wait out the front).
For my IFR check ride, my DE asked me to plan a trip from CON (Concord,
NH) to HYA (Hyanis, MA). He asked why I selected 9000' feet for my
enroute altitude. Answer was, "In case I lose the engine." IMHO,
unless the headwinds are much stronger at 10-12K', I'd rather take a few
more minutes (OK, sometimes many more minutes) to get there, but have a
few more minutes and miles in case of an engine failure. My time is
just not that important.
phoenix.
from
to
to
go
a
12000
would
as
much fuel up high.
to "push on").
-Sami
Remove "2PLANES" to reply.
Old January 8th 04, 03:31 AM
McGregor
AOPA has an dumbed-down internet version of FlightStar that you can download
for free at:
http://www.aopa.org/flight_planner/intro.html
The Jepp North American IFR version of Flightstar V9.0 costs $239. I'm
running 8.0 and have never purchased the map or chart revision service. My
flight planning skills have atrophied as a result of using this thing. It
calculates flight times very accurately. But I like it best for long
x-country flights. You can draw a great circle between take-off and landing
and then drag your flight path up or down for fuel stops or VOR fly-overs or
to parallel victor airways if the weather sucks.
-Sami
downloaded
altitudes
to "push on").
-Sami
Old January 8th 04, 03:53 AM
O. Sami Saydjari
Yes, I just tried the free version. It is quite nice (compared to the
one at DTC DUATS).
Thanks for the info on flitestar.
-Sami
for free at:
-Sami
downloaded
altitudes
to "push on").
-Sami
Old January 8th 04, 02:16 PM
Dave Butler
Just for the record, you don't need to be an AOPA member to get DUAT for free.
http://www.duats.com DynCorp DUAT
http://www.duat.com DTC DUAT
If you like telnet access: "telnet direct.duats.com". Easy to create a text log
of your DUAT session that you can edit, so it's easier to print selected parts
of the briefing to take with you.
http://www.enflight.com gives you some html post-formatting of the DUAT output
that I find useful. Actually I think this is what AOPA uses under-the-covers.
All are free.
Dave (another Winders avoider and cheap *******)
Remove SHIRT to reply directly.
Optimal Frequency of Lessons David B. Cole Aerobatics 18 October 28th 04 12:50 AM
Sparkplug picking tool Michael Horowitz Home Built 3 November 1st 03 01:51 PM
Center vs. Approach Altitudes Joseph D. Farrell Instrument Flight Rules 8 October 21st 03 08:34 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
