VFR on top
Old October 11th 05, 09:14 PM
Steven P. McNicoll
"Peter" wrote in message
Why would this be?
Forgive me for looking at this from the Euro POV, but it is true that
if outside CAS one can fly anywhere one likes if VFR, whereas if IFR
one is supposed to fly on ATS routes (published airways).
However, there are countries (e.g. Greece) where *all* traffic (incl.
VFR) is supposed to be on airway routes, and one can also get DCT
clearances when IFR.
Moreover, I can be flying VFR in CAS (say Class C) and be talking to
some IFR (approach or departure) ATC unit, and they will be watching
me (with a Mode C squawk) and in effect separating me and other
traffic, occassionally giving me vectors. This is VFR, but it makes
perfect sense.
So I can't see why ATC would allow more routing leeway if VFR than if
IFR. Does the minimum separation change?
Yes, aircraft operating VFR-on-top are treated as VFR aircraft for
separation purposes.
Old October 11th 05, 11:13 PM
Steven P. McNicoll wrote:
: Clearance to maintain VFR-on-Top does not alter the assigned route. Given
: that separation is no longer an issue it may be easier to obtain desired
: routing, but it's still an IFR operation. If you're going to a destination
: where IFR arrivals require some specified route you're still going to need
: that route.
That's what I meant, not necessarily what I said...
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old October 11th 05, 11:23 PM
Steven P. McNicoll
news
Separation between each other, or separation between IFR traffic and
VFR traffic?
In all cases, as far as separation goes, aircraft operating VFR-on-top are
treated as VFR aircraft.
In Class D and E airspace VFR aircraft are provided no separation, nor are
aircraft operating VFR-on-top.
In Class C airspace VFR aircraft are separated from IFR aircraft, and
VFR-on-top aircraft are separated from IFR aircraft. Neither is separated
from other VFR or VFR-on-top aircraft.
In Class B airspace all aircraft are separated.
Old October 12th 05, 01:14 AM
KP
wrote
Ah, but the main advantage (AIUI) is that the IFR clearance "VFR on top"
gives
you the flexibility of chosing your own routing while still staying in the
system. In
congested airspace, it's often unlikely they'll give you a routing at IFR
altitudes
due to conflicting traffic. With VFR on top they're more likely to let
you through
without a big diversion.
Why would this be?
perfect sense.
Yes, you are looking at it from a euro-POV and I think that's the
disconnect.
In US Class D & E VFR are not separated from IFR.
In the US virtually all airspace is some class of controlled airspace; not
just airways and terminal areas. There is some Class G (just enough to
prompt some gotcha test questions or usenet replies) but for most
discussions it's N/A.
Within all that controlled airspace only one controller provides ATC Service
within any one particular chunk of airspace.
Since there is (virtually) no uncontrolled airspace and only one controller
is responsible for the controlled airspace (and thus should have his Big
Picture) there are no provisions (or really any need) for the ATSORA (RIS
and FIS but especially RAS) that you find in the UK.
When an aircraft in probably 90% of US airspace is VFR or in this discussion
VFR-On-Top, ATC is not responsible for separation.
The two main reasons for IFR re-routes or request denials are separation and
traffic flow/sequencing into the terminal area. Since VFR-On-Top
eliminates separation as a reason and sequencing only matters in the
terminal area the result is more flexibility when it comes to routing.
Old October 12th 05, 03:45 AM
Newps
You must be east of the Mississippi. Look west. We have a lot of
uncontrolled airspace out here.
Old October 12th 05, 03:53 AM
Ron Rosenfeld
On Tue, 11 Oct 2005 14:39:40 +0200, Greg Farris wrote:
I can almost hear the center controller's hair being pulled out!
You may be VFR, responsible for visual separation, but the IFR traffic near
you is not. Suddenly you want ten degrees left! Maybe in wide-open places with
little traffic - try asking something like that to Boston center.
Much of my flying is in Boston Center airspace. I've never been denied a
deviation because of weather.
Old October 12th 05, 04:35 AM
KP
"Newps" wrote in message
not just airways and terminal areas. There is some Class G (just enough
to prompt some gotcha test questions or usenet replies) but for most
I am west.
Everything is relative and should be taken in context.
Compared to europe, and the UK in particular, where controlled airspace
consists of airways, fairly small, congested control zones, and that's about
it, the percentage of Class G in the Western US is insignificant.
Especially when compared to the amount of traffic (IFR and VFR) each
contain.
The civil controllers over there are pretty much hog-tied by a lack of
airspace to put IFR airplanes (which must remain in controlled airspace).
When I left in '92 timed approaches from holding patterns were SOP at
Heathrow. Just about everybody's on an airway; no off-airways directs and
not much in the way of re-routes available (they're all full).
If that's your context the idea that being VFR-On-Top could have any effect
on an aircraft's routing probably wouldn't register. There's no place else
to go regardless of whether you're at a hard altitude or OTP.
Outside of controlled airspace everybody's technically uncontrolled under
see-and-avoid. Whether they're in clear-and-severe or completely Popeye.
There are various types of air traffic services available from military
radar facilities. It's pretty much a free-for-all with multiple facilities
working aircraft in the same airspace. A coordination nightmare where you
must separate aircraft on your freq by 5NM or 5000 Mode C from any
unidentified or uncoordinated radar target.
If you haven't endured it it's a real head shaker :-/
Old October 12th 05, 12:09 PM
Dan Luke
"Dave Butler" wrote:
VFR on top is nevertheless a great favourite (favorite) of FAA IR
examiners
Because few applicants have a thorough understanding of it.
And few controllers. I've quit using it because it just isn't worth
the confusion.
Yeah, no kidding. Just this weekend I overheard someone on the radio
request VFR on top, and the controller responded with "IFR
cancellation received"...
I've never had that happen, though one controller did ask if that was
what I wanted. The trouble usually came on handoffs, where the next
controller would want to know if I was still on an IFR flightplan, etc.
Dan
C172RG at BFM
Old October 12th 05, 11:20 PM
Chris
"KP" nospam@please wrote in message
I am west.
about it, the percentage of Class G in the Western US is insignificant.
contain.
effect on an aircraft's routing probably wouldn't register. There's no
place else to go regardless of whether you're at a hard altitude or OTP.
facilities working aircraft in the same airspace. A coordination
nightmare where you must separate aircraft on your freq by 5NM or 5000
Mode C from any unidentified or uncoordinated radar target.
I would agree its a real belter flying IFR in uncontrolled airspace taking
Radar Advisory Service when a nearby aircraft might be getting a service
from someone else. It become a real relief when you can move into Controlled
airspace usually Class A and have the benefit of London Control looking
after you. But getting into CAS is not easy either even with an IFR flight
plan.
Old October 13th 05, 06:36 PM
Chris
Controlled
after you.
Statistically, the risk of a mid-air in IMC is closer to zero then
most risks we routinely accept in life.
plan.
Could you please expand on this? If you file an IFR flight plan (a
proper ICAO one) which passes through CAS then you will get ATS radar
service all the way. The flight plan, if on a route acceptable to
CFMU, must be accepted. Not exactly as filed but the general route
won't be refused.
I recently went from White Waltham to Jersey.
Even though I had used DCT in CAS to get to Southampton, all the Radar
controllers instructed me to remain outside controlled airspace. This meant
scrambling along in marginal VFR until I got to north of the Solent area and
climbed to 4000 in Class G in IMC and waited for clearance into the Solent
Area (Class D).
I was kept holding outside outside the Southampton Zone for 20 minutes
before being allowed to enter CAS. In fact when I was passed onto Solent
from Farnborough, I was greeted with the statement " remain outside
controlled airspace until I get back to you which might not be today, we are
busy."
Eventually, I was cleared in the CTA and vectored around Southampton to the
Isle of Wight when I was given my airways clearance (Class A) to Jersey and
transferred to London Control where normality prevailed all the way to
Jersey with a STAR and the ILS to 27.
(the stupid thing is that flying the N reg plane my legal minimums on the
ILS approach are way less than if I was flying a G reg using my IMC rating
privileges.
Anyway, what other flight plan is there to file unless its a proper ICAO
one?
