It is the way it is because it is part of the TSO.
Mike MU-2 "Wyatt Emmerich" wrote in message ... But the GPS shouldn't suggest that you fly into a tower or terrain. Which is what it does now. As soon as you pass the MAP point, the SUSP button starts to blink, begging the pilot to press it and fly to the hold. What the SUSP should do is blink with the additional message, "no turn until xxxx altitude." Come one. How difficult is that to program? Given Garmin's dominant position as an IFR GPS, it's not too much to expect. "Lynne" wrote in message ups.com... I see your point clearly. However, it appears to me that you want the GPS to do a bit too much for you. Remember, it is still your responsibility as the pilot of the aircraft to fly the procedure as published. Do you suppose if the GPS told you everything you need to know about the approach to fly it safely you'd be less reliant on the approach plate? I do, and I am not certain that's a good thing. Lynne |
When I fly an approach I usually put my King KLN90B in OBS (aka hold)
mode. This suspends waypoint sequencing. I make the FAF the current waypoint and dial in the inbound heading. When I go missed, I just ignore the GPS and follow the written instructions in the chart. Usually a climb and to the holding fix. I make sure the holding fix is in my flight plan, that way it is on the GPS map. I look at the little airplane icon and head to the holding fix. Once leveled out, I can start fiddleing with the GPS to get me onto the next step, whatever that is. I like having the approach on the GPS map when I go missed, that way I know where I am, I have a mental picture of where the missed it in relation to the inbound course. All of this varies from approach to approach, as there are many possiblities. Many GPS approaches and even others have the missed approach fix the FAF, which is a nice arrangement, you don't have an additional fix to worry about. If I use my autopilot to fly the missed I don't couple it to the GPS, I use heading (or in my case wing level) mode. Above all, don't get hung up on the unit. Keep it simple. My way of doing it also means I don't even have to hit a button (and possibly screw things up) after I go missed. I just fly to the missed approach fix using what is on the map. It's been working well. YMMV. |
Andrew Gideon wrote:
Dave Butler wrote: The GNS480 (and maybe all TSO 146 navigators, I don't know) have the concept of a leg that terminates at an altitude, which will be the first leg of such a missed approach procedure. How is that displayed on the map? Does the map automatically shift the next leg to "direct to the next waypoint" from the location at which the altitude is reached? What waypoint is displayed in the climbing leg? http://www.garmin.com/manuals/GNS480_PilotsGuide.pdf (7+ meg download) see p. 66(74 of 158) Leg Types p. 68(76 of 158) Heading to an Altitude p. 80(88 of 158) Flying the Missed Approach The page number is the Garmin page numbering, and the (nn of 158) is the pdf page number. This sounds like an incredibly useful feature. There's a departure procedure at KTEB that's even more complex than this. From runways 1 and 6, this feature would cover it. But from 19, the procedure is runway heading until 800, then right to 280. Maintain 1500 until crossing the TEB R-250 & passing TEB 2.5 DME, then climb to 2000. Note the "TEB R-250 & passing TEB 2.5 DME" "waypoint". Can the 480 handle this? Sorry, I don't have time to check on this right now, but maybe you can answer this question with the information from the references above. I'll try to look at this later. Dave |
From the GNS430 Manual:
[pg71] Note: When viewing the map page, note that the final course segment is displayed in magenta...and a dashed line extends the course beyond the MAP. The dashed line is provided for situational awareness only and should NOT be used for navigation. Follow the published missed approach procedures. Also: [pg72] 2. Follow the missed approach procedures, as published on your approach plate, for proper climb and heading instructions... Seems that they have themselves covered although I am assuming the GNS530 manual has the same language as the GNS430's. I don't think the GNSx30 boxes are allowed to use their altitude for anything official until they get the WAAS upgrade anyway. If they put a simple note as a warning, then they would have to put similar warnings for other operations (e.g. warning the pilot to descend to the proper altitude when it goes into OBS/SUSP mode during an approach with a holding pattern). As other peopl have said, it's up to the pilot. The boxes are in compliance with all TSO-c129 requirements. The issue should be directed at the FAA. Marco Leon "Wyatt Emmerich" wrote in message ... My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Wyatt,
Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. Well, I'm not sure I follow. The Garmin doesn't display the full missed approach procedure. Not sure how explicit the manual is about it, but it is pretty clear from even cursory reading (and looking at the display). That's why it goes into "SUSPEND" - because the nnav information isn't there. The data is simply not in the database. Legs that end at an altitude, not a point, aer not part of the data format used by the 430. Not even the G1000 has it, AFAIK. Only the 480. Im my view, it is the pilot's responsibility to know about the limitations of the gear he is using. All the stuff in the plane has limitations. And we should inform ourselves about them. Nothing to it. And nothing wrong with Garmin about it at all. -- Thomas Borchert (EDDH) |
Wyatt Emmerich wrote On 10/11/05 19:39,:
My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. Why not just a warning label on the front that says "not for use by idiots". |
![]() Mike Rapoport wrote On 10/12/05 07:34,: "Wyatt Emmerich" wrote in message ... My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. The SUSP illuminates to show the pilot that waypoint sequencing is suspended. No more. The functions are the same on all the GPS units and it is part of the TSO. Anyway, it is not Garmin's fault that pilots don't read the manual and don't follow approach plates...its the pilots fault. Has anyone ever crashed because of this? Mike MU-2 I crashed my head into the panel trying to push the button. Does that count ? |
Best suggestion I've seen so far.
On 10/12/2005 3:15 PM, Scott Moore wrote the following: Wyatt Emmerich wrote On 10/11/05 19:39,: My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. Why not just a warning label on the front that says "not for use by idiots". |
On Wed, 12 Oct 2005 02:39:58 GMT, "Wyatt Emmerich"
wrote: My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. I'm not sure why he's upset, that's what the manual says to do. See page 67. Reach MAP, press OBS, follow plate's heading/alt instructions, go to holding point. You do have a responsibility to know the gear you're flying behind, and having a GPS doesn't remove the responsibility to have plates, or fly the plate as charted. Admittedly, I don't hit OBS until I'm ready to go direct to the holding point after climbing and turning as charted, but hitting OBS right at the MAP doesn't appear "wrong" if you're reading the procedure from the manual. |
I guess I'm in the minority, but I still think I'm right. The box ought to
do the job and not leave the pilot hanging. It should not draw a magenta line straight into terrain or a tower, regardless of when the pilot decides to hit the blinking SUSP button. The instructor said every one of some eight pilots made the exact same error. Calling them all "idiots" does nothing to address a very real problem. This is sloppy TSO regulations and lazy programming on the part of the FAA and Garmin. "Peter Clark" wrote in message ... On Wed, 12 Oct 2005 02:39:58 GMT, "Wyatt Emmerich" wrote: My flight instructor is quite upset. He says every single one recurrent pilots is making the same potentially fatal mistake. When they reach MDA or the MAP, they hit the OBS/SUSP button as soon as it lights up. The Garmin 530 immediately paints a magenta line to the hold waypoint. Unfortunately, often the full approach plate lists specific altitudes to which to climb before making this turn. The instructor says eight out of eight of his recurrent pilots are just hitting the SUSP button as soon as it appears and heading to the hold, which could take them smack dab into terrain or towers. We look up in the Garmin manual and it says nothing about making sure to reach the proper altitude before hitting the OBS/Susp button. His point is this: Garmin should have some type of display message that warns the pilot to reach the proper altitude before turning to the hold fix. I'm not sure why he's upset, that's what the manual says to do. See page 67. Reach MAP, press OBS, follow plate's heading/alt instructions, go to holding point. You do have a responsibility to know the gear you're flying behind, and having a GPS doesn't remove the responsibility to have plates, or fly the plate as charted. Admittedly, I don't hit OBS until I'm ready to go direct to the holding point after climbing and turning as charted, but hitting OBS right at the MAP doesn't appear "wrong" if you're reading the procedure from the manual. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin 530 Bearing to fix ? Error ? | Chuck | Instrument Flight Rules | 2 | August 10th 03 07:48 PM |
