PDA mounting alternatives
Old October 13th 05, 07:27 PM
The nice thing about the flexible gooseneck is that you can move it
around in flight. Mine (9 inch) is attached to the upper right
quadrant of the panel, holds it's position well, even on wave tows, and
can be easily adjusted for glare. I typically move it off to the right
during takeoff and landing.
Ray Warshaw
1LK
Old October 14th 05, 12:08 AM
Jim Kelly
I agree entirely Eric. My point is that the stylus often needs a
lot of room above the unit (for ejection). It is easy to forget
this when mounting (eg) below the lip in a glareshield.
jk
Eric Greenwell wrote:
2. You need to be able to use your pointer finger easily, and
sometimes to eject the stylus.
I suppose this varies with the software you use, as my finger
works fine
in flight using SeeYou Mobile. On the ground, for entering
tasks and
other fiddly things not needed in flight, I do use the stylus.
And using a finger was even easier with Glide Navigator, which I
used
for years before Mobile. Didn't ever use a stylus with it.
Eric Greenwell
Washington State
USA
Old October 14th 05, 12:16 AM
Jim Kelly
Another advantage with the 'stick-on' bifocals is that you can
carefully trim them to make them narrow in width (about 60% of
their original width), thus preserving the ability to look
'outside and down' without their intrusion.
Jim Kelly
Jim Kelly wrote:
Marc makes good points, to which I would add:
1. Remember that it helps to not change your focal length such
that the outside view is out of focus. Folks over 45yrs or so
will apparently have difficulty in this regard.
For a lot of pilots, that puts the PDA quite far away. I don't
need
glasses for distance, but I do need reading glasses. "Sunreader"
sunglasses combine nonprescription sunglasses with bifocal areas
low on
the glasses; additionally, the bifocal area has very little
tinting.
This arrangement is perfect for PDA use in a glider. Cheap, too,
at $25.
Pilots needing prescription sunglasses could get them with the
bifocal
area, preferably with very little tinting. More than $25, of
course!
In any case, definitely look at the PDA you are considering, and
do it
in the sunlight. Their screens differ markedly in visibility, and
some
of the older ones are better than the newer ones. I use a 3835,
which is
noticeably better than the newer 2210 I first purchased.
works fine
in flight using SeeYou Mobile. On the ground, for entering tasks
and
Eric Greenwell
Washington State
USA
Old October 14th 05, 12:27 AM
Bela
Jack Glendening wrote:
Thanks to all those who responded or sent me photos of their setup. I'm
happy to hear that view blockage can be much less than in the two
gliders I had looked at. And I had not previously seen a gooseneck
installation. Sounds like I need to find and sit in a few more gliders
with PDAs. Jack
Speaking for the over 55 pilots, I became much more happy with my PDA
viewing when switched to a tri-focal glass. Why move your PDA inches
when you can change your focal distance with a few millimeters of
eyeball movement.
Bela
Old October 14th 05, 12:35 AM
Eric Greenwell
I used them for several years on Serengeti sunglasses and liked them,
but switched to the Sunreaders when I discovered those even better
because they were untinted in the bifocal area, and because the stick-on
bifocals introduced some glare when the sun hit that area. I think the
two extra surfaces between the sunglasses and bifocals caused it;
nonetheless, they can be a good solution for people with prescription
sunglasses. At ~$20, they are cheap to try, and cutting them down as Jim
suggests is a good idea. You can probably get them to stick better, and
reduce the glare I got.
Eric Greenwell
Washington State
USA
Old October 14th 05, 08:03 PM
Raphael Warshaw
I'm using auto-darkening glasses with a "blend" prescription. Although I've
heard complaints from others that the auto-darkening lenses are still not
dark enough, mine have worked out well and the distance adjustment has
become automatic.
Ray Warshaw
1LK
"Bela" wrote in message
with PDAs. Jack
eyeball movement.
Bela
C150 Wheel Fairing mounting plates Robert Zrim Owning 17 June 16th 05 07:37 AM
Instrument mounting question Rob Turk Home Built 4 July 19th 04 10:33 PM
Skymap IIIC Mounting Options NW_PILOT Owning 15 July 8th 04 01:41 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
fs2002 - traffic & alternatives cruise Simulators 1 September 20th 03 09:34 PM
