Garmin 530 Fatal Error
Old October 14th 05, 08:27 AM
Thomas Borchert
Wyatt,
What great defenders of mediocrity you all are!
Well, remind us again about your background in constructuing,
programming AND certifying aviation GPS units. Or could it it be you're
just a smart*ss trying to insult a large number of people at once?
Thomas Borchert (EDDH)
  #32
Old October 14th 05, 02:36 PM
Dave Butler
Wyatt Emmerich wrote:
What great defenders of mediocrity you all are! It is unbelievably simple to
program the 530 to flash the message "Do not press send until xxxx feet."
Or, pray tell, it could actually use the GPS to determine the altitude and
not blink the SUSP until you reach it.
What exactly is the point of defending the ancient "let the idiots die"
philosophy. I suspect it's some misguided macho "holier than thou" ideology
rooted more in egotism than desire for safe system.
As pilots, we should be pressing Garmin to do better, not excusing
substandard programming. Chelton and many others have already made this fix.
What is the point of making excuses for Garmin. You want all the pilots
lacking your skills to die? God bless you.
So far Chelton isn't taking much market share from Garmin. Perhaps you should
start your own GPS company, then you can decide how best to spend your
development and certification dollars, and if you do it right, you'll drive
Garmin right out of the market. After all, it's unbelievably simple to program.
As the marketing folks at companies where I have developed software like to say,
it's SMOP, a simple matter of programming.
  #33
Old October 14th 05, 03:09 PM
Dan Luke
say, it's SMOP, a simple matter of programming.
From the "old days" at Honeywell, the Software Order Of Magnitude Law:
Software revisions estimated to take a day will take a week.
Software revisions estimated to take a week will take a month.
Software revisions estimated to take a month will take a year.
Software revisions estimated to take a year will never be finished.
Dan
C-172RG at BFM
  #34
Old October 14th 05, 07:24 PM
Scott Moore
Doug wrote On 10/13/05 18:32,:
What circumstances ? You are flying upside down ?
Let us say you are approaching a waypoint headed due west. You push
direct to and have a course line to the waypoint. Now let us say thay
you move to the south by 1/2 mile. The waypoint is to your right
(north). The CDI reads to the right as it should. Your GPS says your
waypoint is 1/2 mile right. Now you DO A 180 DEGREE turn (to the south
so you are still south of the waypoint. Your CDI still says it is to
the right, indicating it is to the SOUTH!. (Unless you have a Garmin
480 which is the only IFR certified GPS unit that will correct for
this). Some handhelds may correct for this also. ALL the IFR GPS units
that were certified under the old spec (pre WAAS), will reverse sense.
I suppose that was a stupid question on my part. I have never actually
used a CDI except as a novice pilot. I consider them to be about as
technically advanced as a steam powered can opener.
I'm not sure how Garmin would correct for a CDI's faults, but I'll take
your word for it.
  #35
Old October 14th 05, 07:26 PM
Scott Moore
Thomas Borchert wrote On 10/14/05 00:27,:
Wyatt,
Come on. The smartest programmers I know have never written a line of
code :-)
  #36
Old October 14th 05, 07:28 PM
Scott Moore
Wyatt Emmerich wrote On 10/13/05 17:41,:
We are advancing Darwinisim, and thus improving mankind. Its actually a
very noble goal, something akin to handing out shotguns in the deep south.
Oh, wait a minute, too late.....
  #37
Old October 15th 05, 01:57 AM
Mike Rapoport
"Wyatt Emmerich" wrote in message
to program the 530 to flash the message "Do not press send until xxxx
feet." Or, pray tell, it could actually use the GPS to determine the
altitude and not blink the SUSP until you reach it.
Well, the SUSP starts blinking when the waypoint sequencing is SUSPended.
The MSG light illuminates when ther is a MeSsaGe. The "Turn to XXX"
illuminates when the course programmed into the box requires a Turn to XXX.
Seems reasonable to me.
Mike
MU-2
  #38
Old October 15th 05, 02:00 AM
Mike Rapoport
"Peter" wrote in message
Which, presumably, why an HSI is better because one can see at a
glance that the course pointer is pointing the opposite way to one's
heading, so one can clearly see the deflection of the bar is not in
the correct direction.
How does the 480 correct for this? To do anything, it needs to be
aware of the aircraft heading. Does it have a heading input?
It could just use track.
Mike
MU-2
  #39
Old October 15th 05, 07:30 PM
Thomas Borchert
Default Garmin 530 Fatal Error
Scott,
code :-)
A good one :-)
  #40
Old October 24th 05, 02:59 PM
Dave Butler
Default Garmin 480 features (Was: Garmin 530 Fatal Error)
Dave Butler wrote:
Andrew Gideon wrote:
Dave Butler wrote:
The GNS480 (and maybe all TSO 146 navigators, I don't know) have the
concept of a leg that terminates at an altitude, which will be the first
leg of such a missed approach procedure.
How is that displayed on the map? Does the map automatically shift
the next
leg to "direct to the next waypoint" from the location at which the
altitude is reached? What waypoint is displayed in the climbing leg?
http://www.garmin.com/manuals/GNS480_PilotsGuide.pdf (7+ meg download)
see p. 66(74 of 158) Leg Types
p. 68(76 of 158) Heading to an Altitude
p. 80(88 of 158) Flying the Missed Approach
The page number is the Garmin page numbering, and the (nn of 158) is the
pdf page number.
This sounds like an incredibly useful feature.
There's a departure procedure at KTEB that's even more complex than
this. From runways 1 and 6, this feature would cover it. But from 19,
procedure is runway heading until 800, then right to 280. Maintain 1500
until crossing the TEB R-250 & passing TEB 2.5 DME, then climb to 2000.
Note the "TEB R-250 & passing TEB 2.5 DME" "waypoint". Can the 480
handle
this?
Sorry, I don't have time to check on this right now, but maybe you can
answer this question with the information from the references above.
I'll try to look at this later.
I've just had a week off and had a little time to look at this. It appears that
the answer is that this departure procedure is not in the 480's database, same
as for all DPs that are strictly "pilot nav". There is no GPS guidance for this
departure procedure. This DP is all about headings to fly, no navigational guidance.
Dave
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin 530 Bearing to fix ? Error ? Chuck Instrument Flight Rules 2 August 10th 03 07:48 PM
