GPS - losing signal
Old October 19th 05, 05:14 AM
Hilton
Default GPS - losing signal
Hi,
I know GPS works in bad weather, but...
When would a GPS lose a signal due to weather? i.e. do certain clouds (or
huge ones) make a GPS signal go bad? Does rain? If so, how much? What
about snow? If I was in a hurricane, would I lose the signal? Lightning?
What other things can make GPS signals go bad? Any good research papers out
there? I'm sure there must be now that we're going to GPS approaches.
Speaking of hurricanes, would it be possible to take off in the eye in a 172
and fly along with it for hours in the eye?
Hilton
Old October 19th 05, 05:40 AM
N93332
"Hilton" wrote in message
nk.net...
Hi,
172 and fly along with it for hours in the eye?
I'd guess it may be possible to fly a 172 around in the eye if it could
survive getting into the eye.
Old October 19th 05, 10:45 AM
nooks!!
hellO!.. im joross!.try to look on this link,
http://www.tpub.com/aviation1.htm
i believe they got infos there regarding aviation, so the site might be
useful!. i hope that one helps!
Hilton wrote:
Hi,
Hilton
Old October 19th 05, 12:48 PM
Cub Driver
I once had a GPS that did not work at my own home, which is a couple
of miles from the former Pease Air Force Base. If I flew over my house
(or Pease, for that matter) sure enough, it lost the signal. I always
reckoned that Pease had a death ray going. Then I got an aviation GPS
(both were Garmin) and the problem disappeared. (Of course Pease AFB
about the same time became Pease International Tradeport. Maybe the
USAF took the death ray with them?)
I am now two generations past that first GPS. I've never lost a signal
except due to heavy trees (automobile travel, not airplane). I have
however had user-defined waypoints shift position (and in rather
dramatic fashion, from New Hampshire to somewhere on the
Chile-Argentina border--that is, they went from north latitude to
south latitude).
-- all the best, Dan Ford
email: usenet AT danford DOT net
Warbird's Forum: www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old October 19th 05, 05:06 PM
150flivver
My handheld GPS Pilot III has lost sight of the satellite constellation
several times but only while I was cross country. The outages ranged
from several minutes to an hour. In several years of flying locally,
it has never failed to lock on and work perfectly. Even on cross
country flights it has only lost track a very small percentage of the
time. On one of those flights I suspect an antenna farm on the ground
was causing some interference but the other times I have no clue what
could have caused the loss of track.
Old October 23rd 05, 03:50 PM
jc
nk.net...
Hi,
Fuel would be the problem, hope you are over a suitable area when it gets
low.
This crew have done it with a UAV
http://www.aerosonde.com.au/
It has a fair endurance (1st UAV over the North Atlantic) and at a talk they
were looking at using it to fly into cyclones (hurricanes/typhoons). It is
also unmanned and cheap.
regards
jc
LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or
sanity of the author is not guaranteed
EMAIL - and are not valid email
addresses. news2x at perentie is valid for a while.
Old October 23rd 05, 08:18 PM
Stubby
Hilton wrote:
Hi,
I swear overcast cuts down on my GPS signal, but others say it can't happen.
Hopefully you aren't flying beneath tree level, but I do a lot of
geocaching. Pine trees with long, conducting needles can really shut
out the signal. Because they are evergreens, the effect happens in
winter as well.
I'll bet you can find some good info on www.af.mil -- doc center or the
like. Because there is a new GPS system being designed, there should be
some good papers. Find out who the contractor is and approach them.
Only if I completely lose my mind. Phsyically, probably you can, but
not me.
Hilton
"Signal jamming a factor in future wars, general says" Mike Military Aviation 23 August 24th 11 03:17 AM
Laser Pointer as Signal Device? Jay Honeck Piloting 29 December 13th 05 11:00 AM
Losing TIS Sites Chuck Owning 0 July 1st 05 10:28 PM
OT early humour. Losing an Engine Ghost Home Built 7 September 20th 04 02:48 AM
U.S. is losing the sympathy of the world John Mullen Military Aviation 149 September 22nd 03 04:42 PM
