Their theory was that it was carb ice.
Plane was a Dakota. Interesting. If so, that's the first instance of carb icing I've heard about with a Dakota. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Interesting. If so, that's the first instance of carb icing I've heard about with a Dakota. Lycomings rarely suffer from carb icing because the air intake is routed through the oil sump on most models. This keeps the carb warm. Unless, of course, you just started the engine a few minutes ago and the oil's still cold. As of two years ago, Shenandoah Valley impressed me as having a pretty competent shop. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
"Jase Vanover"
I taxied to the maintenance hanger (after being directed there by the FBO via radio notification of the situation), and explained what happened to the maintenance guy. He said that there is a stop on the throttle to keep the idle setting from being too low that probably needed adjustment. Even so, during shutdown (after restarting), idle setting on the throttle was still 800 - 900 RPM, which should be enough to keep the engine running I would think. Anyone else experienced this and can share their thoughts? I'm about a 60 hour pilot, so not much experience. Part of the run-up is a slow idle check. You should pull the throttle fairly hard to see if the idle speed falls significantly below the spec'd minimum. I don't know if that's what happened to you, but it's pretty common. I was flying into La Guardia on Air Canada and I saw a Bonanza rolling out with the engine stopped. By total coincidence, exiting the plane, I got a call from that pilot's instructor who'd briefed the pilot on this X/C. He said that there was a known problem with that plane and, I think, said that it was not an uncommon problem with that type of plane. Odd thing, coincidence. Anyway, engines quitting on final is an occasional story topic. There you go... moo |
I think your mechanic was right. RPM has nothing to do with whether the
engine is getting gas. It will windmill at 800-900 RPM with the engine off. I have seen this problem before. It is not extremely rare. An idle check on runup should discover it, unless you finally managed to loosen the throttle just enough on short final for it to finally stop working. The reason I do not think it was carb ice is that the weather was below freezing, which means that the air was probably relatively dry and it may even have been too cold for carb ice to form (the air would have to have liquid water precipitate out of it to cause carb ice, meaning that the air would have to be warmed in the carburetor, not cooled, and somehow also exceed 100% humidity in the process). This is one reason many instructors are so dead set against their students getting low on final. You can run out of options real fast, and a disproportionate number of engine failures happen there. Engines almost always fail just when you change something: throttle, carb heat, mixture, prop, etc. There can be a lot wrong with an engine and it will keep running if you never change anything, but a configuration change will often be the last straw before she quits. Before making any adjustments to an engine it is good practice to scan the area for emergency landing fields. |
"cjcampbell" wrote in message news:
This is one reason many instructors are so dead set against their students getting low on final. You can run out of options real fast, and a disproportionate number of engine failures happen there. Evidence? Engines almost always fail just when you change something: throttle, carb heat, mixture, prop, etc. There can be a lot wrong with an engine and it will keep running if you never change anything, but a configuration change will often be the last straw before she quits. Before making any adjustments to an engine it is good practice to scan the area for emergency landing fields. Power changes are taught as SOP for climbs and descents. If what you say is true (and I don't know it isn't, but I doubt it) engine outs could be reduced by climbing or descending without power changes. Or at least deferred until landing. moo |
Carb ice, period!
If it was a fuel pump, mag, loose throttle stop, stuck lifters, etc., none of these things cure themselves after the engine stops. An iced up air filter might melt off, but not in seconds... Carb ice is the one thing that will clear within seconds inside of a warm engine once the windmilling stops, which stops it pulling more cold air across the venturi... . And a Lycoming will ice up... I had an engine on Fat Albert go limp at 11,500 feet over top of the Detroit B on a winter day, and it was 25 degrees at our altitude... A few years back I lost an old high school classmate from Caro, Michigan when he went for a student night flight in a Cherokee, iced up and then stalled it before he got to the ground... Claiming it couldn't be carb ice because it was too cold, dry, hot, up, down, left, right, is wishful thinking.... In spring and fall get the carb heat on early, lean it out aggressively before pulling the throttle, and goose the engine every 20 seconds to keep it warm... denny |
In article .com,
"Denny" wrote: venturi... . And a Lycoming will ice up... I had an engine on Fat Albert go limp at 11,500 feet over top of the Detroit B on a winter day, and it was 25 degrees at our altitude... A Lycoming with the carb mounted to the oil pan will ice up, but it is ironically more likely in cruise than in a low-power configuration. The exceptions that I've seen involve extended power-off glides, and extended taxis where the engine has not yet reached operating temperature for the day. JKG |
Here's instance #2 for ya Jay.
A Dakota on our field was owned by a VFR only pilot. Last summer on a trip from STE to GRB and back, he reported having carb ice 3 times during his trip. He questioned that it was really carb ice, but said that each time the engine started to sputter, carb heat smoothed out the roughness in text book fashion. Each time, the engine then ran smoothly for awhile then got gradually rougher until carb heat was applied again. I was at the airport when he returned and reported the problem to the mechanic. To satisfy the pilot, the mechanic looked over the airplane and found nothing wrong. It was simply the effect of a very humid day. Jim |
He did NOT say that the temperature was BELOW freezing, he said that the
temperature was ABOUT freezing, which is a prime candidate for carb ice. He also mentioned nothing about visible moisture (clouds) which would be another clue that the air DID contain sufficient moisture to cause carb ice. And yes, engine restart on the taxiway after a dead stick iced carb is the norm, as the engine compartment warms up with hot cylinders and no cold air moving over them. Carb warms up REAL quick that way. Jim "cjcampbell" wrote in message oups.com... The reason I do not think it was carb ice is that the weather was below freezing, which means that the air was probably relatively dry and it may even have been too cold for carb ice to form (the air would have to have liquid water precipitate out of it to cause carb ice, meaning that the air would have to be warmed in the carburetor, not cooled, and somehow also exceed 100% humidity in the process |
"RST Engineering" wrote: He did NOT say that the temperature was BELOW freezing, he said that the temperature was ABOUT freezing, which is a prime candidate for carb ice. He also mentioned nothing about visible moisture (clouds) which would be another clue that the air DID contain sufficient moisture to cause carb ice. And yes, engine restart on the taxiway after a dead stick iced carb is the norm, as the engine compartment warms up with hot cylinders and no cold air moving over them. Carb warms up REAL quick that way. Jim "cjcampbell" wrote in message oups.com... The reason I do not think it was carb ice is that the weather was below freezing, which means that the air was probably relatively dry and it may even have been too cold for carb ice to form (the air would have to have liquid water precipitate out of it to cause carb ice, meaning that the air would have to be warmed in the carburetor, not cooled, and somehow also exceed 100% humidity in the process Loose nuts on the studs attaching the carburetor to the engine are NOT all that uncommon! I have known of several. That will cause the engine to stop at low power/idle settings! |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Engine failure on takeoff | Greg Copeland | Piloting | 0 | May 11th 04 04:59 PM |
In-Flight Engine Failure | O. Sami Saydjari | Owning | 59 | April 30th 04 08:40 AM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Engine failure rates poll | Captain Wubba | Piloting | 3 | December 8th 03 02:44 PM |
