A few weeks ago there was an extended discussion on improving launch
efficiency. There were suggestions about dropping the tow rope, having another ready with a glider staged, spot marks for the tow plane and glider, etc. Mention was made of a particular soaring site that was especially good at this. I'm tring to retrieve that discussion and my searches have turned nothing up. Can someone point me to this discussion? |
This is a good way to bend break and weaken the weak link not a good practice. |
Mal wrote:
There were suggestions about dropping the tow rope, This is a good way to bend break and weaken the weak link not a good practice. Hmm, is dropping the weak link from 50 feet really make all that much difference, given that it is also subject to being dragged through dirt, bushes, rocks, asphalt, the odd fence, etc., at 50 miles per hour? |
Nyal,
We try to speed up the operation by getting the pilot(s) into the glider off to the side of the paved runway where they can do most of their checks and get comfortable, strapped in, etc. When they are ready to go, we hook a golf cart up and pull them out onto the paved runway. We operate on a public-use airfield so we try to spend as little as time necessary on the paved runway. If the towplane is coming back from a tow and a glider is not ready to go, the tuggie will drop the rope on the runway and someone will run out to drag it over to the side, stretched out for the next hookup. We've done this for many years and haven't seen a problem with extra wear on a weak link or tow rope. This is flying weekends only and on a busy day, we might have 20 tows. We set cones at the side of the runway to indicate where the towpilot should taxi to and stop while the rope is hooked to the towplane. On runway 05, we push the glider to the end of the runway and the towplane taxies to the cone for his position and stops. At this point, most of the slack in the rope is out when the two aircraft are connected. On runway 23, we also set a cone for where the glider should be towed to by the golf cart. This point used to be the end of runway 23, but over the past couple of years, the runway has been lengthened and we are still taking off from where we always did, giving us 3,700' of paved runway. (The lengthened runway will be 5,000' when they open it.) The use of the golf carts to pull the aircraft with pilot to the takeoff spot does speed up our operation. But when using the Grob, you need a lot of people. You need a golf cart driver, a wing walker, and someone to push down on the tail of the Grob to lift the nose wheel off the ground. Things go considerably slower when we don't have enough ground crew. Ray Lovinggood Carrboro, North Carolina, USA At 21:24 24 October 2005, Mal wrote: There were suggestions about dropping the tow rope, This is a good way to bend break and weaken the weak link not a good practice. |
None better then Parowan IMHO-
Glider is pushed out to end of runway...pilot gets in, straps, GPS, logger, etc, etc. Then the second tow rope is hooked up to the glider. The towplane lands with the other rope still connected facing the glider....taxis up facing the glider, drops the rope on the side of the runway, turns 180 degrees, is hooked up to the glider connected rope, tightens the rope and waits for the rudder wag. If done correctly the towplane never stops rolling!! Obviously one needs an airport that can allow this, but Parowan is a public airport. |
Thanks to all who wrote. None of you really answered
my question, which was 'Can you point me to the discussion.' This answer is the closest; I remember now that Parowan was mentioned in that discussion. I would like to retrieve all those posts if possible. If impossible, the posts in answer to my question will prove helpful , and I thank all of you. Nyal At 23:48 24 October 2005, Stewart Kissel wrote: None better then Parowan IMHO- Glider is pushed out to end of runway...pilot gets in, straps, GPS, logger, etc, etc. Then the second tow rope is hooked up to the glider. The towplane lands with the other rope still connected facing the glider....taxis up facing the glider, drops the rope on the side of the runway, turns 180 degrees, is hooked up to the glider connected rope, tightens the rope and waits for the rudder wag. If done correctly the towplane never stops rolling!! Obviously one needs an airport that can allow this, but Parowan is a public airport. |
so which one is operating downwind.. the tow plane landing or the combined
take off BT "Stewart Kissel" wrote in message ... None better then Parowan IMHO- Glider is pushed out to end of runway...pilot gets in, straps, GPS, logger, etc, etc. Then the second tow rope is hooked up to the glider. The towplane lands with the other rope still connected facing the glider....taxis up facing the glider, drops the rope on the side of the runway, turns 180 degrees, is hooked up to the glider connected rope, tightens the rope and waits for the rudder wag. If done correctly the towplane never stops rolling!! Obviously one needs an airport that can allow this, but Parowan is a public airport. |
The weak link is normally at the tug end above the ground so its dragged
through nothing ! I have seen evidence that dropping of ropes with weak links bending the weak link and it breaking, I made it a mini project for a few months to watch the practice as they would tell us they were going to drop the rope when refuelling. I would inspect the weak link prior and afterwards. During this time I observed from a distance a launch that was going to proceed if I had not stopped it were one of the weak links was broken upon examination the remanning link was bent and the link that broke, broke by bending. I have also seen the indent in a wing of a weak link breaking and hitting the wing after hearing the instructors birds eye view I would rather be towed with ropes that are not dropped. I always inspect the rope when hooking up including the weak link. There were suggestions about dropping the tow rope, This is a good way to bend break and weaken the weak link not a good practice. Hmm, is dropping the weak link from 50 feet really make all that much difference, given that it is also subject to being dragged through dirt, bushes, rocks, asphalt, the odd fence, etc., at 50 miles per hour? |
Mal,
In the USA we don't use metal weak links, they are generally made of a rope weaker than the towrope. FARs stipulate the rope must be 80% - 200% of the glider's max gross weight. If the rope is stronger than that, a weak link must be placed at each end of the rope and the towplane one must be stronger but not more than 25% stronger than the glider one. Very different than what it sounds like you're used to. -Tom |
Mal wrote:
The weak link is normally at the tug end above the ground so its dragged through nothing ! Adding to what Tom said, the only place I've ever seen metal weak links, here in the US, is at the glider end... Marc |
