Lost comms after radar vector
Old January 19th 04, 04:03 PM
Gary Drescher
One other suggestion in this scenario (apologies if someone has already
mentioned this): even if you have no reception on your radios, you might
still be transmitting, so you should continue to announce your intentions
and your progress as you fly.
--Gary
Old January 19th 04, 07:41 PM
John R Weiss
"Steven P. McNicoll" wrote...
Squawk 7600 briefly, return to my assigned beacon code, fly the approach,
land, clear the runway.
I'd add a bit:
Squawk 7700 briefly (15 seconds?) to get the attention of ATC, and to give
some notice of your intention to exercise your PIC emergency authority to "bend"
the regulations.
Squawk 7600 to let them know the emergency is "just" lost comm, with no
other complications.
I'm not sure whether continuing on 7600 or returning to assigned squawk is
preferable to the ATC guys...
Fly the approach, land, clear the runway, taxi to the FBO, call the tower.
Old January 19th 04, 07:43 PM
Ron Natalie
"John R Weiss" wrote in message news:OpWOb.100956$xy6.181890@attbi_s02...
the regulations.
Not necessary. If squawking anything is working, 7600 will get their attention just
find. You don't need to give them any such notification.
If there's a tower, don't forget to look for the light.
Old January 19th 04, 07:47 PM
Steven P. McNicoll
I'd add a bit:
Squawking 7600 briefly will get all the attention needed.
and to give
"bend"
the regulations.
The controller will treat you as an emergency either way.
no
squawk is
I'm an ATC guy, returning to the assigned squawk is preferable.
Old January 19th 04, 07:48 PM
Steven P. McNicoll
"Ron Natalie" wrote in message
m...
What will you do if there's no light?
Old January 19th 04, 07:54 PM
Roy Smith
In article .net,
m...
Take off, hold at the FAF for an hour, land and check for the light
again. Repeat until you run out of fuel.
Old January 19th 04, 07:58 PM
Newps
John R Weiss wrote:
I'd add a bit:
Not necessary. Any emergency squawk gets the attentioon of ATC equally.
and to give
the regulations.
That will be assumed when you squawk 7600.
In reality most of the time we know before you do that you are NORDO.
You are supposed to squawk 7600 continuously when you realize it it,
however once we know you are NORDO there is no reason for you to
continue the 7600 squawk. It sets off a pretty annoying alarm in the
tower cab that we have to keep silenced with a rubber band that holds
the mute switch down.
Old January 19th 04, 08:05 PM
John R Weiss
"Ron Natalie" wrote...
give
"bend"
the regulations.
attention just
I don't know the current state of the art of ATC radars. However, the 7700/7600
switch was a part of the Navy Instrument Flight Manual as late as 1994. The
rationale was that not all ATC radars had the same level of alerting for 7600
squawks as 7700, and/or that the alert might be manually disabled.
If all ATC radars now have the same level of alert for a 7600 squawk, then 7600
only makes sense.
Old January 19th 04, 08:26 PM
Robert Moore
to give some notice of your intention to exercise your PIC emergency
authority to "bend" the regulations.
John, this used to be true way-back in the old days when only 7700
rang the bell, but several years back, they re-wrote the software
so that now, 7500, 7600 and 7700 all ring the bell.
Bob Moore
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 12:15 AM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 06:56 PM
