#51
A lot of 0-300's in the older 172's have fuel pumps, I am not too sure why
though. Maybe because of the 6 cylinders? Tom "RST Engineering" wrote in message ... "The Visitor" wrote in message ... RST Engineering wrote: The OP said this was a 172. Some are. So I have to ask. Without me having to go to the TCs and do a search, can somebody please tell me what series of 172s were injected? Anyhow, if so it may be linked to a problem in the fuel pump. And again the models of 172s that have fuel pumps? Jim |
#52
Carb heat was on for at least a minute or two (applied late downwind, and
the engine quit only in the flare on landing). I'm not trying to say I know what caused it, just that I struggle to understand how it could be carb ice with heat on, at prox freezing plus a couple degrees, and with carb heat apparently working per runup indications. "Denny" wrote in message oups.com... Carb ice, period! If it was a fuel pump, mag, loose throttle stop, stuck lifters, etc., none of these things cure themselves after the engine stops. An iced up air filter might melt off, but not in seconds... Carb ice is the one thing that will clear within seconds inside of a warm engine once the windmilling stops, which stops it pulling more cold air across the venturi... . And a Lycoming will ice up... I had an engine on Fat Albert go limp at 11,500 feet over top of the Detroit B on a winter day, and it was 25 degrees at our altitude... A few years back I lost an old high school classmate from Caro, Michigan when he went for a student night flight in a Cherokee, iced up and then stalled it before he got to the ground... Claiming it couldn't be carb ice because it was too cold, dry, hot, up, down, left, right, is wishful thinking.... In spring and fall get the carb heat on early, lean it out aggressively before pulling the throttle, and goose the engine every 20 seconds to keep it warm... denny |
#53
I maintained low power (maybe 1300 RPM) on final, but not idle. Approaching
the runway (was simulating a short field landing) and clearing the ubiquitous 50 ft. obstacle, I cut power to idle and dropped my last notch of flaps. It was a matter of several seconds from this point to flare and the engine quitting. I would think that at low speed (prox 60 kts approach), moderate temps (just above freezing... all is relative ;-) and 1300 RPM (and carb heat applied) there would be enough heat to ward off carb ice, but I'm admittedly short on experience with this sort of thing. "nrp" wrote in message oups.com... I agree it is probably carb ice & a remelt situation. My 150 hp 172M will actually ice up to a limit quite quickly under the right conditions. Note that OP probably had a very low power approach over his obstacle in which case there would be little heat available for the carb heat stove. Those who say Lycomings won't ice up just haven't encountered the right conditions - yet. |
#54
"Jase Vanover" wrote: Carb heat had been on since downwind. I was taught to put carb heat on as part of my downwind checks every time, when doing manouvers at lower throttle settings, and approximately every 15 minutes during cruise... which I'm pretty faithful to. It is also standard part of my runup (both at 1700 RPM and at idle). This was my third circuit. Carb heat was applied during downwind for all three of them. You make a good point that when I did my shutdown after restarting, I didn't have carb heat on, so the engine not quiting and showing 800-900 could be because carb heat wasn't on... though it didn't quit on my first two landings either. Carb ice is funny sometimes. Was doing a bunch of T&Gs in a 152. As you, Carb Heat on downwind, push it off after pushing the throttle in on takeoff. On my 7th or 8th "GO" the engine lost power and ran rough at about 300' and quit as I made a right 270 back to the intersecting runway. Made the runway, got a restart after a few moments, it ran real rough for a bit then smoothed out. Shop checked it and found nothing wrong, we assume it was carb ice. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
#55
you, Carb Heat on downwind, push it off after pushing the throttle in on takeoff. On my 7th or 8th "GO" the engine lost power and ran rough at about 300' and quit as I made a right 270 back to the intersecting runway. Made the runway, got a restart after a few moments, it ran real rough for a bit then smoothed out. Shop checked it and found nothing wrong, we assume it was carb ice. More likely the engine had loaded up with raw fuel. With carb heat on, the mixture gets pretty rich, and with the throttle closed there is very little airflow through the engine. Fuel can puddle in the intake manifold, and upon opening the throttle all that gasoline is sucked into the cylinders and floods them. It's worse if you shut the carb heat off first, as the cold air reduces the vaporization of the fuel. Don't make long power-off glides when it's cold and with carb heat on. Clear the engine often, and make sure it's ready to run if you need it. Dan |
#56
![]() wrote Don't make long power-off glides when it's cold and with carb heat on. Clear the engine often, and make sure it's ready to run if you need it. That sure is different than the normal advice, isn't it? -- Jim in NC |
#58
"Tom" wrote in message
... An A&P and/or IA made a mistake working on a engine? To hear them tell, they are the "experts" and you should never work on your own plane nor should you be anywhere within 100 miles of the shop when they work on them. AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME Happy landings, |
#59
Sigh.
Jim Comm'l. Inst. CFI Airplane & Glider A&P IA Roses are red Violets are blue I'm schizophrenic And so am I. "Private" wrote in message news:40R8f.336700$oW2.18373@pd7tw1no... AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME |
#60
cheers, ROTFL
"RST Engineering" wrote in message ... Sigh. Jim Comm'l. Inst. CFI Airplane & Glider A&P IA Roses are red Violets are blue I'm schizophrenic And so am I. "Private" wrote in message news:40R8f.336700$oW2.18373@pd7tw1no... AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Engine failure on takeoff | Greg Copeland | Piloting | 0 | May 11th 04 04:59 PM |
In-Flight Engine Failure | O. Sami Saydjari | Owning | 59 | April 30th 04 08:40 AM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Engine failure rates poll | Captain Wubba | Piloting | 3 | December 8th 03 02:44 PM |
