#11
![]() Nicely done and great story! Thanks. What is the fixed wing that you fly on the job? |
Michelle P wrote:
I used the E-word today. At 08:30 EDT this morning over the Springfield Mixing bowl just south of Washington DC, I declared and emergency. We had just finished our Potomac River crossing south of National airport and headed south to Woodbridge and back to Springfield, VA. Northbound I was just turning the corner to pick up the beltway and head for Tyson's Corners and the engine instantly started running rough, very rough. I thought we were going to loose it all together at 1000 feet AGL over a densely populated area. I immediately turned south again towards the last airport we had passed and called the tower. "Davison tower, Fetter Three is coming in". Fetter Three what is the nature of your trouble? "Engine running rough", How many souls (I hate that question but the need to know to know how many Ambulances to roll), "2." How much fuel? "40 gallons". Are you declaring and emergency? "Yes" ,Would you like Fire rescue? "Yes". I have pushed the button. I tried the Carb heat no results. Mixture full in, and I used our excess airspeed to climb. This added about 200 feet to our altitude. Oil pressure was reading ok as was oil Temp. I tried different power settings no luck. Here we were at 70 KIAS "full" power and holding altitude. I called on the Company air to air to report I was going down. Our other Fixed wing immediately turned towards our position. I was not sure how long this would last so both my observer and I were looking for a place to land short of the field. I am usually looking for places to land as we are cruising around the beltway. Never hurts. Interstate 95S was lightly loaded and was a real possibility. We also had a couple of "large" fields on our way. The engine held and we were cleared to land, wind calm. As we rolled out we we met by the entire fire crew. Since the event was sudden I had no Idea how bad the damage was and weather we would have a fire upon landing. It turns out we were not leaking any oil or fuel. We pushed the airplane off the runway, they have no tow bars for Small GA airplanes. It was parked with the other fixed wing aircraft on the field. THe airfield manager came out and greeted us. Offered us the use of the DV (Distinguished Visitors) lounge. I called my boss and Maintenance. They were on their way. Our other plane landed about 10 minutes behind me. While I was Cleaning out the plane, My observer climbed in our other plane and went back to home base. While I was waiting for my Boss and the Mechanic to arrived I sat in the DV lounge watching Satellite TV and filling out the mound of paper work from an un-authorized landing. Being made Authorized. I stayed with the plane in hopes we could fix it and fly it out today. The plane turned out to be broken harder than I thought. I originally thought the Mags (Dual Drive) had slipped a gear since the entire engine was running badly. It became very obvious when we removed the cowling that we had a problem with the #3 cylinder. The intake push rod was bent. This seemed strange until we removed the rocker cover. The stud for the exhaust valve had come loose in the head and the rocker was cocked to one side. THe push rod was not even contacting the rocker arm. This trapped the high pressure combustion results in the cylinder. When the intake valve tried to open it couldn't. Too much pressure. The push rod bent. Not only did we have a dead cylinder, we had the rest of the engine pushing against a full Combustion charge that could not escape. The mechanic and I removed the offending cylinder and return to home base. I and my morning observer went out and flew the afternoon Survey run. Everything went smoothly and it usually does. The airplane looks like it will be there until Monday when some of the parts under the cowling were broken by the shaking. Michelle (Two engine failures in 15 years and counting) Great job. You're every man's dream -- you fly, are very competent, replace engine parts and even clean the plane! Was it Andrews AFB where you landed? |
I love a happy ending.
When you told the tower you were "Coming In" how did they know you had trouble? |
On Fri, 28 Oct 2005 01:12:34 GMT, Michelle P
wrote in et:: I used the E-word today. At 08:30 EDT this morning over the Springfield Mixing bowl just south of Washington DC, I declared and emergency. Well done, Michelle. I only hope I am able to be as perspicacious in managing the situation when my turn comes. |
Michelle,
Well done. I wish that I could be as calm and competent as you were in handling emergency situations. Glad to hear of the good outcome. Hai Longworth |
Thanks You,
It was not mine. It was the companies. We run these things to death and they keep on running. (Usually) Michelle Maule Driver wrote: Nicely done and great story! Thanks. What is the fixed wing that you fly on the job? |
Stubby,
Thank You, If I am every man's dream how come i cannot find the right one? I seem to scare a lot off because I am more competent than they in a lot of areas. Modest aren't I? Michelle Stubby wrote: Great job. You're every man's dream -- you fly, are very competent, replace engine parts and even clean the plane! Was it Andrews AFB where you landed? |
We do not land at Davison AAF normally. We use their airspace all the
time. I may have told them we had a problem before they asked. That is one of the reasons I want a copy of the Recording. 5 minutes seemed to last forever. Michelle wrote: I love a happy ending. When you told the tower you were "Coming In" how did they know you had trouble? |
I am not how I would have handled this say 1500 or so hours ago.
Experience has built my confidence. I am a lot more comfortable on the flight deck and abnormal things do not upset me as much as they used too. Michelle Longworth wrote: Michelle, Well done. I wish that I could be as calm and competent as you were in handling emergency situations. Glad to hear of the good outcome. Hai Longworth |
Ok the poster did not do what I expected it to do. I select and replied
to individual messages but it grouped them all together. Michelle Michelle P wrote: I am not how I would have handled this say 1500 or so hours ago. Experience has built my confidence. I am a lot more comfortable on the flight deck and abnormal things do not upset me as much as they used too. Michelle Longworth wrote: Michelle, Well done. I wish that I could be as calm and competent as you were in handling emergency situations. Glad to hear of the good outcome. Hai Longworth |
New Word 'SOARING' | Ray Lovinggood | Soaring | 29 | February 5th 05 12:45 AM |
Read This Carefully please; word for word | Dudley Henriques | Military Aviation | 16 | September 6th 04 02:40 PM |
Area bombing is not a dirty word. | ArtKramr | Military Aviation | 82 | February 11th 04 02:10 PM |
Hiroshima. The final word. | ArtKramr | Military Aviation | 10 | January 12th 04 12:20 PM |
so what is the latest word on Sport Pilot ??? | Gilan | Piloting | 10 | September 5th 03 02:44 AM |
