Engine failure
Old October 27th 05, 10:53 AM
Tom
Default Engine failure
A lot of 0-300's in the older 172's have fuel pumps, I am not too sure why
though. Maybe because of the 6 cylinders?
Tom
"RST Engineering" wrote in message
"The Visitor" wrote in message
RST Engineering wrote:
The OP said this was a 172.
Some are. So I have to ask.
Without me having to go to the TCs and do a search, can somebody please
tell me what series of 172s were injected?
Anyhow, if so it may be linked to a problem in the fuel pump.
And again the models of 172s that have fuel pumps?
  #52
Old October 29th 05, 01:07 AM
Jase Vanover
Carb heat was on for at least a minute or two (applied late downwind, and
the engine quit only in the flare on landing).
I'm not trying to say I know what caused it, just that I struggle to
understand how it could be carb ice with heat on, at prox freezing plus a
couple degrees, and with carb heat apparently working per runup indications.
"Denny" wrote in message
Carb ice, period!
If it was a fuel pump, mag, loose throttle stop, stuck lifters, etc.,
none of these things cure themselves after the engine stops. An iced
up air filter might melt off, but not in seconds... Carb ice is the one
thing that will clear within seconds inside of a warm engine once the
windmilling stops, which stops it pulling more cold air across the
venturi... . And a Lycoming will ice up... I had an engine on Fat
Albert go limp at 11,500 feet over top of the Detroit B on a winter
day, and it was 25 degrees at our altitude...
A few years back I lost an old high school classmate from Caro,
Michigan when he went for a student night flight in a Cherokee, iced up
and then stalled it before he got to the ground...
Claiming it couldn't be carb ice because it was too cold, dry, hot, up,
down, left, right, is wishful thinking.... In spring and fall get the
carb heat on early, lean it out aggressively before pulling the
throttle, and goose the engine every 20 seconds to keep it warm...
denny
  #53
Old October 29th 05, 01:14 AM
Jase Vanover
I maintained low power (maybe 1300 RPM) on final, but not idle. Approaching
the runway (was simulating a short field landing) and clearing the
ubiquitous 50 ft. obstacle, I cut power to idle and dropped my last notch of
flaps. It was a matter of several seconds from this point to flare and the
engine quitting.
I would think that at low speed (prox 60 kts approach), moderate temps (just
above freezing... all is relative ;-) and 1300 RPM (and carb heat applied)
there would be enough heat to ward off carb ice, but I'm admittedly short on
experience with this sort of thing.
"nrp" wrote in message
I agree it is probably carb ice & a remelt situation. My 150 hp 172M
will actually ice up to a limit quite quickly under the right
conditions. Note that OP probably had a very low power approach over
his obstacle in which case there would be little heat available for the
carb heat stove.
Those who say Lycomings won't ice up just haven't encountered the right
conditions - yet.
  #54
Old October 29th 05, 01:44 AM
Dale
"Jase Vanover" wrote:
Carb heat had been on since downwind. I was taught to put carb heat on as
part of my downwind checks every time, when doing manouvers at lower
throttle settings, and approximately every 15 minutes during cruise... which
I'm pretty faithful to. It is also standard part of my runup (both at 1700
RPM and at idle).
This was my third circuit. Carb heat was applied during downwind for all
three of them.
You make a good point that when I did my shutdown after restarting, I didn't
have carb heat on, so the engine not quiting and showing 800-900 could be
because carb heat wasn't on... though it didn't quit on my first two
landings either.
Carb ice is funny sometimes. Was doing a bunch of T&Gs in a 152. As
you, Carb Heat on downwind, push it off after pushing the throttle in on
takeoff. On my 7th or 8th "GO" the engine lost power and ran rough at
about 300' and quit as I made a right 270 back to the intersecting
runway. Made the runway, got a restart after a few moments, it ran real
rough for a bit then smoothed out. Shop checked it and found nothing
wrong, we assume it was carb ice.
Dale L. Falk
  #55
Old October 29th 05, 02:12 AM
More likely the engine had loaded up with raw fuel. With carb
heat on, the mixture gets pretty rich, and with the throttle closed
there is very little airflow through the engine. Fuel can puddle in the
intake manifold, and upon opening the throttle all that gasoline is
sucked into the cylinders and floods them. It's worse if you shut the
carb heat off first, as the cold air reduces the vaporization of the
fuel.
Don't make long power-off glides when it's cold and with carb
heat on. Clear the engine often, and make sure it's ready to run if you
need it.
Dan
  #56
Old October 29th 05, 04:43 AM
Morgans
need it.
That sure is different than the normal advice, isn't it?
Jim in NC
  #58
Old October 29th 05, 09:33 PM
Private
"Tom" wrote in message
An A&P and/or IA made a mistake working on a engine? To hear them tell,
they are the "experts" and you should never work on your own plane nor
should you be anywhere within 100 miles of the shop when they work on
them.
AMEs think anything accessible to a pilot is controlled by an idiot.
Pilots think that AMEs are trying to kill them.
A schizophrenic is a pilot who is also an AME
Happy landings,
  #59
Old October 30th 05, 04:14 PM
RST Engineering
Sigh.
Comm'l. Inst. CFI Airplane & Glider
A&P IA
Roses are red
Violets are blue
I'm schizophrenic
And so am I.
"Private" wrote in message
news:40R8f.336700$oW2.18373@pd7tw1no...
  #60
Old October 30th 05, 05:43 PM
Private
cheers, ROTFL
Sigh.
A&P IA
Roses are red
Violets are blue
I'm schizophrenic
And so am I.
Engine failure on takeoff Greg Copeland Piloting 0 May 11th 04 04:59 PM
In-Flight Engine Failure O. Sami Saydjari Owning 59 April 30th 04 08:40 AM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
Engine failure rates poll Captain Wubba Piloting 3 December 8th 03 02:44 PM
