Winter Oil
Old November 1st 05, 11:36 PM
Lets Fly
Default Winter Oil
Hi Everyone
I have a Cessna 180H (66), the previous owner used 15W50, i since changed to
SAE 50 W 100 in summer and was looking to go to SAE 30 W 65
Old November 2nd 05, 01:42 AM
zatatime
Default Winter Oil
On Tue, 1 Nov 2005 14:36:30 -0900, "Lets Fly"
Hi Everyone
Depends on the climate you live in. If you live up north that isn't a
bad idea. If you live in Texas 40 should do it for you. Look at the
recommended temperature ranges given for each type of oil. That'll
give you a good idea of what you should do.
z
Old November 2nd 05, 12:09 PM
Denny
Default Winter Oil
I use W100 in the summer and 15W50 in the winter..
denny - in Michigan...
Old November 2nd 05, 01:19 PM
Jim Burns
Default Winter Oil
Same here.
Jim - in Wisconsn
"Denny" wrote in message
Old November 2nd 05, 03:11 PM
Paul kgyy
Default Winter Oil
I'd recommend 15W50 year-round. It provides better fuel economy and
more corrosion protection while giving up no ground as a lubricant.
Old November 2nd 05, 05:46 PM
Ron Natalie
Default Winter Oil
My old engine called for 30 weight in the winter,
but finding 30 weight is next to impossible around
here. I used to use straight 40 (we don't get THAT
cold here).
Old November 2nd 05, 10:46 PM
Jay Honeck
Default Winter Oil
What's your reasoning on that Denny (and Jim)?
We use 15W50 year 'round.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 3rd 05, 12:12 AM
Michelle P
Default Winter Oil
15W-50 Year round, preheat when the temp drops below 50F.
Michelle
Lets Fly wrote:
Hi Everyone
Old November 3rd 05, 12:47 AM
Dave
Default Winter Oil
Same here Jay...aeroshell with the Lyc additive..
(Although additive not needed for our engine, we like the
" insurance")
Dave
On Wed, 02 Nov 2005 22:46:13 GMT, "Jay Honeck"
Old November 3rd 05, 03:41 AM
Jim Burns
Default Winter Oil
Several reasons, most are personal and based on our local ag applicator's
recommendations. 4 A&P A/I brothers that grew up in/on/under Lycoming
engines, mostly 540's. They've pushed them beyond what you or I will ever
do and in conditions much worse. They swear that when run hard and hot, the
multi weight oils will still give you cam problems, even with the additives.
Right or wrong, I don't know, I'm just going on what their experience has
been and using straight weights they get some longggg hours out of the
540's.
I do know, that in our tightly cowled Aztec, that 15W50 will produce more
carbon in the summer than W100. Even with W100, we often have to fly with
the cowl flaps 1/2 or even full open on hot days. The W100 doesn't produce
the carbon in the filter like the 15W50 while maintaining the same temps.
W100 is less than 1/2 the cost of 15W50, especially if you by it by the 55
gal drum. We change our oil at 33 hours and using 6 gallons at a crack, it
adds up to some $$$.
We switch to 15W50 around Thanksgiving and run it until around Easter.
Based in Wisconsin, we normally fly towards warmer weather in the winter, so
the multi weight keeps us covered on the temperature variations. We don't
want to take that mid-winter flight down south and be stuck with say, W80
and end up not being able to keep things cool enough. In the summer, the
W100 handles any temps we run into.
Our newest engine (about 600 hours old) is a Pen Yan overhaul. The front
cover of the log book has a sticker from them saying that all warrantees are
void if any multi weight oil has been used in the engine. The previous
owner used W80 and then switched to multi weights over the time he owned it.
So I guess he voided the warranty before we bought it, for what ever that's
worth.
It's the best compromise that we've come up with. Like I said, most of our
reasons are personal.
http://www.avweb.com/news/maint/182909-1.html
Is an old (1995) avweb article, maybe there is something newer.
[For Sale] Winter Vario Ludovic Launer Soaring 0 March 21st 05 08:40 AM
Learning to glide / soar in winter Oscar Soaring 17 January 28th 05 04:29 PM
Tie-down winter hazards [email protected] Owning 6 January 12th 05 10:23 PM
Winter Flying [email protected] Piloting 36 January 3rd 05 03:19 AM
Training in the Winter - location? JohnGamble Soaring 9 October 24th 04 04:35 PM
