KLN94 LOC DME Source
Old January 26th 04, 04:36 AM
Greg Esres
Default KLN94 LOC DME Source
Anyone have a tip as to the best way to enter the LOC DME source on
the KLN94?
The NRST function won't always pick it up, if there are a lot of
intersections around.
I've tried loading the fix into an alternate flight plan, and then do
a DIRECT operation later, but I couldn't get that to work.
Old January 31st 04, 09:05 PM
Richard Kaplan
"Greg Esres" wrote in message
the KLN94?
Set up a flight plan or go direct and treat it just like any other waypoint,
but be sure to start it with an I, i.e. IAFJ.
Richard Kaplan, CFII
www.flyimc.com
Old February 1st 04, 05:14 AM
Greg Esres
waypoint,but be sure to start it with an I, i.e. IAFJ.
Richard, I know how to use a LOC-DME source; what I'm looking for is
an easy to enter the identifier. Entering in a 4 letter identifier is
a laborious procedure; a DME freq is much easier.
I tried creating a flight plan with the fix in it, but you can't go
direct to a fix in a flight plan unless the flight plan is the active
one. For some reason, I found that objectionable when it occured to
me a while back, but now it seems like maybe a good idea. Just create
a flight plan containing all the fixes you might want to use on an
instrument approach, then make that flight plan the active one and use
the waypoint "scan" to quickly select the one you want to use.
Thanks
Doug
I would want to "stop waypoint sequencing", so the unit doesn't
sequence to the next waypoint in the middle of your approach. Make the
"Ixxx" the active waypoint, then put the unit in OBS (or HOLD) mode.
Putting the unit in OBS mode stops waypoint sequencing. Dial in the
localizer track as read off the plate. This will give you a track line
to the localizer and beyond it. It is usually easiest to have the Ixxx
waypoint in the route.
"Richard Kaplan" wrote in message ws.com...
the KLN94?
Old February 1st 04, 05:16 AM
Greg Esres
Good thought, Doug.
Old February 1st 04, 07:32 AM
Craig Prouse
The KLN boxes have separate APT, VOR, NDB, INT, USR, and NAV pages.
What I usually do, if I have waypoints of interest that aren't naturally
in my active flight plan, is preload them into their respective navaid
pages. So for example, as I prepare for an approach into KMRY, I would
put I-MRY on the INTersection page. Then, when I'm ready for it
(vectors to the localizer), I spin the big knob to the INT page, and
select -D, OBS.
This allows me to step out of my flight plan temporarily. All it takes
to get back to the flight plan (missed approach?) is to clear the
direct-to operation, then the GPS reorients itself onto the flight plan
route. In many cases, I find this is more effective than trying to add
extraneous waypoints to the active flight plan.
Old February 3rd 04, 10:52 PM
Greg Esres
Good thought. I'll experiment with that. Thanks!
4130 sheet source Leon McAtee Home Built 7 May 2nd 04 08:29 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
Tapered Rod Gear Leg Source Dick Home Built 3 January 13th 04 10:10 PM
Source for copper crush gaskets??? Jim Home Built 2 August 22nd 03 09:44 PM
Online source for POH Jim Instrument Flight Rules 3 July 1st 03 06:56 PM
