Why does a prop ice up so apparently readily?
Old November 7th 05, 11:57 PM
Brian Whatcott
Default Why does a prop ice up so apparently readily?
On Mon, 07 Nov 2005 22:56:42 +0000, Peter
The other day I was talking to a commercial pilot of a big twin
passenger turboprop. He has been iced up a few times and recently was
down to 200fpm climbing flat out through FL150; looking out of the
window he saw a bit of ice on the wings but enough on the prop for it
to be visible while the prop was rotating.
/// At 200kt IAS at FL150 his airframe temperature should be
SAT+9C. At 300kt TAS the TAT should be SAT+12C which nearly puts him
out of the stratiform cloud icing range of 0C to -15C or so.
What puzzles me is the prop. Assuming a SOP of max revs if icing is
likely, much of the prop is going at between mach 0.5 and mach 0.8,
with a temp rise of 15C to 30C, so even on a slow piston aircraft only
the innermost part should ever ice up.
Is this true?
Peter.
Let's run a sanity check.
Lapse rate 2 degC/1000ft (can be less)
Airframe
Cold day = 5 degC MSL
at FL150 = 15 X 2 = 30 degC drop from 5 deg = -25 degC
SAT + 9 to SAT + 12 = -16 degC to -13 degC
Std day = 15 degC MSL
at FL 150 = -6degC to -3 degC
Prop
Cold day -25degC + 15 to 30 degC = -10degC to +5 degC
Std Day -15degC + 15 to 30 degC = 0 to 15 degC
One is warned that glaze can accrete very, very fast.
I oversimplified with the lapse rate, but I conclude that it's easy to
be in an accretion phase at FL150.
Did I miss something?
Brian Whatcott Altus OK
Old November 8th 05, 01:04 PM
Brian Whatcott
On Tue, 08 Nov 2005 08:46:43 +0000, Peter
Yes, I was talking about *aerodynamic heating* of the prop and
suggesting that - over most of its length - it ought to be sufficient
to prevent icing.
....and did I not account for aero heating, using the figures given by
you?
Old November 9th 05, 12:02 AM
Mike Rapoport
You are assuming that you are getting your calculated aero heating even
though the air is full of supercooled water.
Mike
MU-2
"Peter" wrote in message
you?
Yes, but I don't think icing works that way. The reason is that
supercooled water won't (generally) exist below about -15C to start
with, so if the aerodynamic heating increment exceeds 15C one doesn't
get ice.
So, if e.g. the SAT is -25C and the aero heating is 20C, the airframe
part will be at -5C but it won't ice up because there wasn't liquid
water in the -25C air to start with. Any water would have been in
solid (frozen) form, as in e.g. cirrus clouds, but a -5C airframe
flying through that won't accumulate ice because the crystals don't
have time to melt and convert themselves into drops of liquid which
could stick.
That's my understanding, anyway.
Why does a prop ice up so apparently readily? Brian Whatcott General Aviation 2 November 9th 05 12:02 AM
Why does a prop ice up so apparently readily? Mike Rapoport General Aviation 3 November 8th 05 02:52 PM
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 02:52 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
